Jerome L.
Rémi D.
N'hésitez pas
Antony C.
Best rapport Qualité/Prix !
patrice f.
KLEI SILVER
Montées sur un Ramm élite 8, le résultat est excellent !
Les respirations de Denitza, entre deux phrases (france musique) sont
bien plus audibles !
Du grave à l'aigu, amélioration notable.
Patrick
patrice f.
câble amadeus 7
Je rejoins tous les avis déposés sur l'amadeus 5 et 7.
Ce câble a réellement amélioré le rendu sonore et permet à mes atlantis lab de s'exprimer pleinement.
Patrick
patrice f.
gaine coton
Très bon produit, solide, épais.
A tendance à s'effilocher, peut être
poser un adhésif léger à son extrémité pour la mise en place.
Eemeli T.
Competent product with minor setbacks
SMSL DL200 is a solidly built, pretty good-looking DAC/HPamp with a nice set of features.
The screen isn't big but it is very clear and easy to see from several meters away, and the sound quality is as good as it gets in this price category. I'm using it as a DAC in my system so I cannot say anything regarding to the headphone amplifier. Among the pros, there are a couple of cons, though.
Firstly, it doesn't have signal-sensing auto-on feature, so you have to manually turn it on (and off) every time. I'm hoping this could be fixed with a driver update. Secondly, the USB-C port is VERY sensitive to slightest movement of the unit or cable and leads to the DAC dropping out of sync with the signal source and a very loud, short hissing noise from the speakers, so do not move it around when playing music.
All in all I've been pleased with the product. It isn't perfect but it comes with a very competent set of features and good build quality.
Marc F.
Solution intéressante et qualitative !
Souhaitant travailler en bi-câblage à partir de l'ampli MPA-S125NC, j'ai constaté que le côté exigu de son bornier rendait peu sûr le raccordement en mode bananes+fourches ; en se desserrant légèrement, les fourches risquent en effet de tourner et de se toucher. J'ai donc opté pour ce modèle Yarbo qui, en permettant deux connexions "banane" en cascade, a résolu simplement et élégamment le problème. Le serrage des câbles est également très efficace et accepte sans problème du 6mm2. Bravo !
Marc F.
Économique, suffisant et... 6mm2 !
J'avais déjà apprécié le modèle Viborg un peu différent choisi il y a quelques semaines ; celui-ci est parfait aussi compte tenu de l'usage que j'en ai. Le double vissage est efficace et le dimensionnement m'a permis d'y loger du câble cuivre OFC de section 6mm2. Comme on dit dans ces cas-là : "Je mets cinq étoiles et je le recommanderais à un ami !"
Marc F.
Simple et qualitatif
J'ai choisi ce modèle qui propose suffisamment d'entrées et en prime la possibilité de sortir sur deux préamplis (pas simultanément toutefois).
J'apprécie la qualité (modèle assez lourd car beaucoup de métal - c'est très bien !), la facilité d'emploi et le caractère "passif" de cet équipement qui ne consomme rien.
pascal B.
cablage hp
excellent rapport qualité/prix pour ce cable abaordable mais de grande qualité ; transmet le signal fidélement et sans coloration
Niek S.
Amazing
I never was into special speaker cables, but I really should have tried this sooner. It really makes a difference, never expected that! I am using these with neutrik 4 wire speakon connector on hypex nc-400 monoblocks with Q-acoutics 3050i. Sounds amazing, much more depth and soundstage, better highs. Using Wiim pro plus with external dac SMSL m500.
Recommended!
Cyrille G.
TOPPING PA7 Amplifier Class D Balanced 2x200W 4 Ohm Black The Topping PA7 is a powerful amplifier, based on a Class D architecture and benefiting from an intelligent and particularly careful design. It is thus capable of developing a...
Bonne impression lors des premières écoutes
J'ai changé mon Harman-Kardon HK670 pour ce modèle. N'ayant pas encore reçu les cables de modulation symétrique, mes premiers essais ont donc été en asymétrique. J'ai un sytème Daphile avec un DAC Topping DX7 Pro et des enceintes JM Lab-Focal 726 S. Le contraste avec mon ancien amplificateur est important : son plus doux et mélodieux, basses mieux définies, mediums moins criards et aigus montant plus hauts. Le PA7 est moins punchy que le HK mais répond très bien aux variations dynamiques des enregitrements. La spatialisation est magnifique. Je ne savais pas avant ce que donner un amplificateur audiophile mais, bien que n'étant pas mélomane j'ai vite perçu la différence avec mon ancien matériel. Je pensais que mes enceintes étaient le maillon limitant mais pas du tout, elles sont encore meilleures maintenant. Le PA7 est encore en rodage mais bientôt avec les cables symétriques ça devrait être encore mieux. La seule question que je me pose c'est celle du préampli : pour une qualité optimale, dois-je utiliser celui du PA7 ou mettre ce dernier en bypass et utiliser le préampli du DX7 Pro, ce qui me permet de régler le volume sonore avec la télécommande ? J'aimerai vraiment avoir une réponse de spécialiste à ce sujet et notamment d'AUDIOPHONICS. Pour le moment, j'ai l'impression qu'en bypassant le PA7 sa puissance à baisser et peut-être aussi sa dynamique.
Cédric R.
IFI AUDIO NEO STREAM Streamer WiFi DLNA AirPlay Roon Ready XMOS Balanced 32bit 768kHz DSD512 MQA The iFi Audio Neo Stream network player has been designed to offer both versatility and excellent sound performance. It combines the latest version of the brand's network...
Bon mais...
L’ergonomie un peu datée. Il faut activer un hotspot pour pouvoir accéder à une interface Web de configuration. Personnellement ça ne me pose aucun problème mais pour d’autres peut s’avérer une galère. Une fois cela passé on peut dire que la qualité y est au coût d’un prix un peu haut.
jean michel G.
Wiring Cable Single Strand Silver Plated OFC Copper PTFE Sheath 0.5mm² Ø1.3mm Black This wire is ideal for internal wiring on DIY projects. It consists of a 0.5mm² silver-plated OFC copper single-strand conductor. This cable is...
Diamètre exact
Il est écrit diamètre du fil 0,5mm, alors que dans la description est précisée 0,8mm.
Quelle est la bonne section svp ?
Lukas B.
There is a washer in the regulator heatsink, that is not capable of taking the heat. Might as well remove it before it starts smoking, it's capable of transporting the heat without being screwed to the heatsink.
Eric R.
XANGSANE XS-008 24k Gold-Plated Spades Ø8mm (Set x4) These XS-008 spades from Xangsane are good quality. The copper alloy contacts are plated with 24k gold. Conductivity is therefore optimal, and the plating ensures resistance to...
Robuste
Un bon produit , fixation solide pour le câble avec même une reprise pour le blocage de l'isolant via le manchon avec 2 vis , soir un total de 4 points de serrage
Le tout pour un prix encore raisonnable permettant de se constituer un ensemble avec des câbles honnêtes sans tomber dans des choses un peu délirantes
Un choix raisonnable a envisager sérieusement
leo h.
Uc330 board plus ultracaps
Extremely good.
leo h.
Powersupply
Incredible good
Rainer K.
1877PHONO FINA-OCC MKII Shielded Power Cable OCC 3x2mm² 1.5m After the success of the now famous Legion, 1877Phono offers a new power cable based on PC-OCC copper and 24k gold plated connectors. The FINA-OCC is made of high purity copper...
Zavino Fina
I saw the cables for the first time at the Hifi Days in Hamburg. I was already convinced of the quality back then. Ultimately I ordered the "Zafvino Fina" for my Goldnote-PH 10 phono preamplifier. An absolute win for my hi-fi system. The quality of the cable matches the device and the price is appropriate. I will use the same cable for my power supply for my Transarotor turntable.
Unfortunately, the cables are hardly available at all in Germany. I was all the happier that I can order the cables (including the larger series) here in France.
Michael N.
Superb mechanical and audible quality
Solid and stable mechanical construction. Everything fits here, easy but efficient. Hugh difference in regard to "gold plated" compared to other connectors!
Tonal very fine, well balanced and detailed - best connectors I ever bought!
Michael N.
Incredible fine and balanced!
Absolute fine dissolving cable , light and well balanced, does not add or subtract anything, natural flow.
Compared to Tunami V2 it is better in resolution - it is finer, incredible balanced in all aspects. The fist cable where I do not miss a thing or find it overdrawing - just perfect!
Joseph C.
Je m’y attendais pas
J’utilisais un Réal câble eca préfabriqué qui jusqu’à présent me donnait entière satisfaction pour connecter mes sources cd/dvd.
Depuis l’acquisition d’un Streamer Atoll Ms120, et malgré une centaine d’heures de rodage, le côté sec et les duretés dans les aigus ne s’estompaient pas..
Au vu des prix pratiqués dans les câbles préfabriqués abusifs, j’ai décidé de me monter celui-ci avec des rca Amphemol.
Sans même être rodé, de suite le son est bcp plus équilibré sans cette prédominance dans les aigus, une fluidité extraordinaire, ça descend très bas même à faible volume !
Apparemment, se marie avec Atoll à la perfection !
Thierry N.
Joli boitier, très bien fini... bien supérieur à des boitiers du même type (1MII, IFI audio...).
Connection immédiate à mon smartphone (pourtant pas très récent) - Codec bluetooth LDAC (en série sur tout smartphone depuis android 8.0). Le son en sortie coax et avec le LDAC est vraiment d'une qualité qui n'a rien à voir avec le sbc, on est vraiment qualité CD et à l'oreille pas de différence en sortie de mon ampli - dac avec mon lecteur cd hifi.
Sortie RCA, signal interprété par le dac intégré, semble tout à fait honorable peut être un peu moins d'ampleur que mon dac hifi mais je ne peux rien affirmer, car pas assez de temps d'écoute...
Pour le prix je suis ravi de pouvoir simplement et sans réseau, véhiculer de la musique sans fil avec une qualité plus que correcte. J'avais peur de la qualité Bluetooth qui ne m'a jamais vraiment séduit mais les codec LDAC, apt-x lossles ou LHDC remettent les pendules à l'heure. Le LDAC et LHDC largement intégrés sur smartphones sont vraiment équivalent au CD si notre fichier source est lui-même correct (Flac...)
jean luc L.
Jantzen Audio Waz Coil 12awg 1mH
Super comme toujours !! Une meilleure définition des timbres, réalistes plus raffinée.
Jean-Pierre D.
Une très belle restitution claire, détaillée et musicale
Jusqu’ici, mon câble de référence était le Cardas Clear Cygnus (deux fois plus cher) en cuivre, ce Neotec m’a conquis avec ses médium et aigu doux et très fins. La scène musicale est très ouverte, il y a beaucoup de micro-détails, je craignais avec un câble avec conducteurs argent de perdre en texture au niveau des timbres, il n’en est rien. La reproduction des voix et instruments à cordes par exemple est superbe, cela me semble dépasser ce que fait le Cardas qui a une restitution sur les voix et instrument assez vive.
Donc, sur les critères habituels, détails, transparence, précision tonale, résolution spatiale, il me semble sensiblement au-dessus du Cardas avec un prix canon. L’image sonore d’un orchestre avec ce Neotec est transparente, spacieuse, communicative, dynamique et tonalement correcte, sans manquer de fluidité.
jean luc L.
le livreur a jeté le colis (carton trop léger a mon gout) par dessus la porte de mon domicile, une des self et légèrement impacté mais pas de différence sur le son.(Jai la vidéo de l interphone) Ouf j ai eu peur !!
sinon les self Jantzen c est vraiment Top , sur le médium cela apporte beaucoup de velouté et réalisme !!
Philippe c.
Y A PAS PHOTO !
Nouvel ampli casque ....j'en suis ravi ! ...après déception sur déception , j'ai enfin trouvé celui qui me convient . Puissance, précision du message, plans respectés . Conseils d'Audiophonics bienvenus ! Merci.
Stephen R.
Soundcare superspikes for Hi Fi electronics
I have used the standard model before on speakers and liked these so I thought i would try these on my DAC. Really impressed and will be getting another set once back in stock.
Really a 5 star unit but no screws included, obvious really as what length would they supply its component dependent so figure that one out if you need to. Plenty of self adhesive options.
Improved sonic's where a definite for me.
Jean-Christophe M.
Une amélioration sonore garantie
Je dois avouer que j'étais très sceptique quant à la différence qu'un changement de câble RJ45 pourrait apporter. Je pensais qu'un simple câble de flux de données binaire de 0 et 1 ne pouvait pas altérer la qualité sonore d'une mini-chaîne, en l'occurrence la CR 612 de chez Marantz.
J'ai donc décidé de faire un test et ai été agréablement surpris par le rendu sonore. Une scène sonore plus aérée et détaillée s'est dégagée, représentant un véritable gain qualitatif pour mon équipement.
Sincèrement, je recommande ce câble, qui est d'ailleurs le moins cher par rapport à d'autres concurrents sur le marché.
Merci à l’équipe de Audiophonics pour la rapidité de la livraison de ma commande.
Christophe D.
100%
Simple et efficace, on trouve plein de tuto partout, un must pour chaque DIYer !
Christophe D.
ARYLIC S10 Streamer RJ45 WiFi DLNA AirPlay Bluetooth 5.0 24bit 192kHz Arylic presents with the S10 a compact and versatile streamer, integrating both WiFi and Bluetooth 5.0 connectivity. It will allow you to broadcast and control your music...
Mitigé... mais 5 étoiles quand même !
Efficace, stable, discret, avec une appli simple ; le DAC d'origine n'est pas extra, normal vu le tarif. J'ai commandé un Sabre, on verra si c'est mieux. La lecture des .flac sur l'USB laisse parfois quelques "blancs", mais ça ne plante pas... Dommage qu'on ne puisse pas mettre un répertoire en favoris. L'accès à mes NAS serait tellement plus rapide.
Frederic G.
J’ai testé de très nombreux câbles haut-parleur, de 2.- le mètre à plusieurs centaines de francs le mètre. Aucun ne m’a apporté autant de satisfaction que ce simple monobrin d’argent pur de 1.3 mm, gainé avec du coton de 1.5mm.
J’ai possédé des câbles argent cryogénisés de 0.5 mm qui sonnaient très rapides et détaillés mais le rendu était clairement ascendant et fatiguant par manque de corps.
Le rendu du 1.3 mm en simple câblage est neutre, équilibré, dynamique et transparent. Tout est à sa place à un niveau impressionnant. Le grave est rapide et puissant.
Avantage supplémentaire: plus besoin de bananes, de fourches, de soudures…Une petite boucle pour le bornier et c’est tout.
1.3 mm fonctionne parfaitement avec mes enceintes de 93db, longueur des câbles 2,50 mètres, ampli 2x200 W.
Vraiment bien !
Pressé de recevoir ce préampli pour essayer mon nouveau gros bloc à tubes, vraiment pas déçu.
Ce serait un comble que mon nouveau preamp à tubes HDG ne soit pas mieux sachant qu'il coûte 40 fois plus cher.
A 30 euros ce préampli est une bonne solution pour test.
La diode rouge sur le bloc de la prise secteur est un phare la nuit, un détail.
Livré en 24 heures chrono après une modif de commande, la version argent-silver n'étant finalement pas dispo, je l'ai eu en noir, vu ce que je vais en faire...
Top Audiophonics, comme d'hab !!! Merciiiiiii.
Top anti-vibrations.
Et ça colle fort, impossible de le replacer après application.
Super plaque de bitume pour intérieur d'enceintes, caissons de basses et même platine vinyle ou lecteur CD.
Découpée au cutter c'est vraiment bien.
Plaques livrées en 24 heures chrono !!
Marc T.
Remarquable
Surprenant, ce petit appareil. Il n'a peut-être pas la meilleure fiche technique, mais voilà : il FAIT de la MUSIQUE ! Et avec une précision telle (je l'utilise comme dac-préampli) que je distingue nettement le caractère des divers câbles que j'utilise en sortie. Un très bon RCA, par exemple, "sonne" mieux qu'un XLR courant.
On frôle le haut de gamme pour un prix très abordable.
Grand coup de chapeau au Japon et à la Chine !
DECEVANT...
Possesseur d'un Aiyima A07 et d'un "A07 PLUS", il faut reconnaitre que cet Aiyima A07 MAX est déroutant et décevant. Certes la transparence est très bonne mais les timbres sont monochromes, gris, sans saveur. Cordes acides et piano manquant singulièrement d'harmoniques. tweaké avec différents Ampli Ops (TLE2142 CP, 1612, ou LM4562), rien n'y fait! L'Aiyima A7 (simple) ou "l'A07 PLUS" équipés d'AOP LM4562NA font beaucoup mieux.
Ferenc M.
effective
I use it for dampening the metallic noise of the top/bottom of my amplifier chassis. It went completely silent after the modification.
PAS MAL ...MAIS PEU PUISSANT.
Restitution de bonne qualité avec une bonne définition et absence d'agressivité. Les basses manquent un peu de tension, cause probable d'une puissance trop modeste (il faut en effet régler le volume entre 75 et 90 sur une échelle de 100 pour avoir un niveau réaliste sur enceintes de bon rendement (90 db))
Olivier C.
FOSI AUDIO P3 Tube Preamplifier 2x JAN5654W Headphone Amplifier Bluetooth 5.1 aptX aptX HD The Fosi Audio P3 is a compact, high-performance preamplifier. It features two JAN 5654W tubes and a QCC3031 Bluetooth receiver chip. A...
Ouverture du son
Je viens d'une préamp FX-AUDIO TUBE-03 à Tubes 6K4, et je trouve une nette différence d'ouverture de son.
Par contre, moins puissant j'ai l'impression, le volume faut le pousser !!
Par contre, quel son supérieur !!!
Seul bémol, le bluetooth qui n'est vraiment pas excellent, et je le compare au bluetooth du AIYIMA A08 PRO qui, je trouve, reste meilleur.
Sinon, très bon son et j'aime son esthétique avec cette petite lueur bleue des tubes ...
Matt M.
Big Surprise!
Paired with Ian's IV board, this modest trans is a serious contender for best money spent in audio for me. Upstaging a Twisted pear Mercury IV. Got a free board from Ian and just wanted to see how this topology sounded. Big Surprise!
Matt M.
Tamed Dylan's Harmonica!
Great Clock, especially for the money. Nice upgrade from the stock FifoPi Q7 clocks. Sound is calmer and recordings with harsh treble (sorry Bob) are much improved ;-) Benefits from lengthy break-in period.
František B.
BEATECHNIK x LHY AUDIO LPS-A6 220V MK1 Linear Power Supply Module for EverSolo DMP-A6 Gen 1 The LPS-A6 linear power supply module has been specially designed to enhance the power supply stage of EverSolo DMP-A6 and DMP-A6 Master Edition network players by replacing the...
František Baran
Děkuji za rychlé dodání BEATECHNIK x LHY AUDIO LPS-A6. Po výměně napájecího zdroje se zvukově moje audio sestava skočila o třídu víš .Vřele doporučuji. Super obchod a prodejce moc děkuji . Baran
pascal T.
Correction acoustique très efficasse en hifi et facile a mettre en oeuvre. Basses beaucoup plus propres et punchy,je voulais aussi l utiliser en passe haut pour supprimer des infra parasites sur certains enregistrements ,c est fait..
Joseph J.
Remplace très avantageusement les HP "grave" d'origine sur enceintes de bibliothèque Yamaha. Bons graves pour la taille de l'hp.
Patrick R.
Bien moins cher que la FI50, elle semble faire le job pour avec une très belle qualité des matériaux et facilité de montage.
Patrick R.
Qualité du produit
Très belle qualité de fabrication. Qualités sonores sur un Furutech S55N très satisfaisantes pour alimenter les équipements réseau.
Patrick R.
Lieu conçue et meilleure facilité de montage que la GX16 classique.
Le diamètre élargi est appréciable avec gaine coton par exemple. Qualité globale du produit.
Incroyable !!
Ce minuscule préamp à un son incroyable, il faut juste mettre des bons tubes NOS ( j'ai mis des Sylvania ) et remplacer le potar voir comme dit plus haut " En réalisant un pont diviseur avec une résistance 47 kohms série et une 1.5 kohms parallèle "
Je ne sais pas jusqu'où il peut aller ... en remplaçant des condos ou des résistances qui sont sur le trajet du signal ... à tester ... !!
Aussi une alim linéaire ou sur batterie ...
Je pense que le potentiel in finé est très très élevé ... pour un prix modique ... !
Raphael K.
10 années !
je ne noterais pas 5 car il faudrait qu'il dure plus de 10 ans pour mériter la note ! (comme de bon vieux appareil vintage !) cependant je ne peu pas dire de mal sur la qualité de cette alimentation car 10 années s'est pas forcément mauvais pour du découpage ! , voila je passe commande de nouvelles alim après 10 années d'utilisation des ncore 400 , je précise que j'étais équipé des 1er versions et les appareils restais presque tout le temp sous alimenté !
Excellentes fiches bananes
Une nette amélioration du rendu sonore (elles remplacent les Viablue ts qui sont pour le prix excellentes).Elles sont plus naturelles, et le grave est plus précis.
Système d'auto serrage très efficace, les connecteurs ne bougent pas et le contact est optimal.
Seul bémol, le prix...
Didier C.
Amélioration notable
Installé entre ma box Orange et un streamer 3D Lab nano platinum V5. Donc écoute uniquement en streaming et avec Qobuz studio. L'amélioration s'est faite sentir au bout d'une semaine : une musique qui donne l'impression d'être plus fluide, avec moins d'aspérité, une plus grande sensation d'espace et avec un placement plus précis des musiciens. Dans l'ensemble, les disques moins bien enregistrés passent mieux qu'avant et les bons sont encore meilleurs !
Un apport important à mon avis sur un système résolvant.
Kulcsar A.
GOOD
Moondrop is the best IEM, sound ok clear.
