peter S.
peter S.
peter S.
Customers reviews - There are 19605 reviews.
Sami K.
Robust and stylish connector
This connector is very robust with pretty nice buid quality and performs well even with a thicker cable. I have built a few cables with this connector together with 15917, 2059 and 3001. The connection terminals are robust enough to allow thicker cables to be used with secure connections.
These connectors are roomy enough to allow a led illumination being built in (at one's own risk), which looks particularly good with these connectors. I wish these could be a bit cheaper, although they are worth the price.
Sami K.
This connector is very robust with pretty nice buid quality and performs well even with a thicker cable. I have built a few cables with this connector together with 16686, 2059 and 3001. The connection terminals are robust enough to allow thicker cables to be used with secure connections.
ANDREJ S.
Andrej Sporin
The connectors seem to be of good quality. I don't know what their effect is on the sound, because I still haven't replaced them with the original installed connectors on the cables due to the missing screw. I ordered two sets, one of which arrived in damaged ( broken) box with 7 instead of 8 screws.It looks like a returned shipment that was then sent to me.
[GRADE A] XDUOO XD05 PLUS Battery-Powered Portable Headphone Amplifier AK4493EQ XMOS 32bit 384kHz DSD256 Black Refurbished product  - Grade A Direct successor to the XD-05, the xDuoo XD-05 Plus headphone amplifier with built-in DAC, it takes over the best features of its big...
Nécessite un adaptateur pour une utilisation sur IPhone
Assez satisfait du produit mais utilisateur d'IPhone, j'ai été dans l'obligation d'acheter un adaptateur caméra (+/-50€) d'où une étoile en moins.
Helmut M.
WIIM Pro plus
fast delivery
I'm using the WiiM Android App
WIIM Pro plus is analog connected to my Amplifier.
I tested successfull DLNA streaming from minimserver
with a lot of flac-files (16 / 44.1). Connection via Ethernet.
gapless playback works very well.
browsing through my flac-library works fast.
very good!
the WIIM Pro plus is also detected from other DLNA control-software
"Audionet Remote Control Point RCP" for windows 10 or Android
gapless playback works here as well.
I have also the WIIM Pro device
since the latest firmware update (12.09.2023) both devices run in a stable mode
with the Audionet client (no more disconnects of the WiiM Pro)
I like the Audionet client more than the WiiM App (for DLNA streaming) because of its good playlist handling.
Pascal B.
AUDIO BASTION TITAN SILENCER Dampening Spike Foot Pad Titanium Steel Aluminum Silicon Ø78x33mm (Unit) Made from polished stainless steel, GR5 titanium alloy, T6061 aluminum, and a silicone cushion with extremely precise tolerances, the Audio Bastion Titan Silencer is a very...
le must de la contrepointe ?
Contrepointes de grande qualite au concept original terriblement efficace pour mon systeme hdg .
Elles supportent mon meuble hi fi d'une bonne centaine de KG par l'intermediaire de Viablue spikes QTC . Apres une bonne semaine d'installation , afin que tout se stabilise , je suis particulieremnt satisfait de cet achat . elles aident à définir une scene sonore que je n'avais encore jamais entendu sur mon systeme jusqu'à présent ! Bravo à Audio Bastion pour la qualite et l'efficacite de leur produit , et merci à Audiophonics pour avoir commercialisé cette marque américaine .
Makis g.
great budget rca
Combined with Sommer SC Straros gives very nice results.
Wolfgang S.
TOPPING D70 PRO OCTO DAC 8x CS43198 XMOS XU316 Bluetooth 5.1 LDAC aptX-Adaptive 32bit 768kHz DSD512 Silver The D70 Pro OCTO Topping DAC is packed with the refinements of a high-end audio product. With its high-performance chips, ultra-low jitter clocks,...
Topping D70 Pro Octo
Great DAC and the sound is just great, I use it with Neumann KH 310a and Sommer Cable Epilog
Pascal B.
VIABLUE QTC SPIKES Metal Spikes Black (Set x4) These Viablue QTC Spikes metal decoupling pins prevent vibration transmission from your speakers or devices to the lower surfaces. Their acoustic properties also contribute to...
Je cherchais des pointes de qualité pouvant supporter une bonne centaine de Kg pour mon meuble audio . C’est chose faite avec ces pointes Viablue .Conception irréprochable, réglages et montage très facile ! Attention à bien commander les vis TCHR si l’on souhaite les visser sur des inserts !
Par contre je n’ai pas utiliser les «  mini contrepointes » livrées avec . Je les aies remplacées par des Titan silencer Audio Bastion!!!
L’amélioration pour mon système HDG est évident et sans appel ! Comme quoi la lutte contre les perturbations liées aux vibrations est primordiale.
Michael L.
Switched Mode Power Supply 100-240V AC to 32V 10A DC This AC adapter takes an input voltage of 100-240VAC to output 32VDC 10A. The components are integrated in a robust aluminum chassis that dissipates the heat generated by the...
Makes a difference
Used a cheap 24v 10 a laptop power supply (which is better than the stock 32v 5a power supply) with my Fosi Audio TB10D, wanted something better and a little bigger (more power) so this it was, since 48v might be able to make my amp play louder but also alot hotter, i didn't want to go all in.
More clean sound, less grainy highs,cleaner midrange,tighter better controlled bass, fast delivery, no pop sound turning m,y amp on,off
I wish it could be had with a black front
Renaud G.
Un bon p'tit ampli !
Acquis il y a maintenant deux mois, je laisse un avis express sur ce HTA100.
J'en suis content : accompagné d'une paire d'Elipson et d'un petit subwoofer class D, ça sonne. Bien à volumes bas et moyen, sans distortion à fort niveau. Les deux vu-mètres analoqique aident bien à respecter la puissance de l'ampli en évitant de dépasser anormalement le 0/+3dB. Pratique. Bien pourvu en entrées diverses analogiques et numériques, il accepte mon iPad en USB permettant une lecturede qualité lossless.
De surcroit, il est compact, élégant et de bonne fabrication.
Un rapport qualité/prix excellent.
Merci à Audiophonics d'avoir importé ce petit ampli bien agréable.
Claude I.
Très bon produit.
Le son est très détaillé, beaucoup de présence. Manque d'"aération" par rapport aux meilleurs DAC, mais le rapport qualité prix est excellent. J'ai préféré l'entré SPDIF, l'optique est un peu en retrait (faiblesse de ma source peut être !), L'USB est détaillée mais manque de relief comme souvent. J'ai enlevé une étoile car le mode DAC pur n'existe pas sur le E30II Lite (Audiophonics, attention aux copiés/collés). C'est bien dommage, je privilégiais ce fonctionnement. Très bon produit dans l'ensemble. Testé sur un système à haut rendement (101 dB) actif. Utilisé pour sonoriser un bureau.
Bon streamer
Couple en optique à mon dac eversolo z6, il remplie son rôle de streamer efficacement. L' application wiim est bien faite et simple.
MSC1 Multifunction Cutting Clamp This multi-function cutting Clamp can also be used to crimp terminals or strip cables. It accepts terminals from 0.75 to 6mm², and cables to be stripped from 1.5 to 6mm².
Ça coupe, dénude, sertie sans effort.
Très bien, jolie, esthétique.
Belle qualité
Je n'ai pas trouver d'autre moyen que de les utiliser en posant mon ampli de 17kg dessus. Pas moyen de les fixer tel quel. Mais ça fonctionne..
Pointe légèrement réglable. Jolies et bien fabriquées.
Les tampons adhésifs fournis ne sont pas double face.. a visser donc, ou acheter du double face.
Valdemar P.
Recommended for the sound quality and connections
It clearly improved the sound quality and the gain of my setup.
I'm using it with a pair of active monitors. First connected by RCA and then using the balanced 6.35mm TRS jacks.
The USB quality is great.
Via Bluetooth is also very good (the DAC seems to detect the best codec for each connection. In may case used Ldac with Android and ACC mainly with iOS. It works at leat up to 10 meters even with walls in between.
It has a huge volume range that allows maximum detail.
The screen, apart from the source and out connections, shows the kHz rate quality and the volume when in use.
It would be great if, when possible, it showed the bit rate of the track.
The built looks good, of quality and solid for the DAC itself and for the remote. But I found a couple of minor issues with the materials: The base of the DAC is not perfectly straight, and the device does not sit well on the table, wobbling a little. A small non-slip feet pad fixed the problem.
It was not possible to fully adjust the Bluetooth antenna, preventing it from maintaining its vertical position. Again, a piece of duct tape did the trick.
I like the integrated energy transformer but it makes the device bulkier.
The remote is solid although for it to work it must positioned directly pointed to the DAC and without any obstacles. The minimum intrusion or side positioning will prevent it from work.
Take into account that it does not include AAA batteries for the remote and you will need them for it to work.
As cable it comes with the energy cable and the USB-C to USB 3.0.
Bof..
Sur un dac eversolo z6, le son est plat, perte dans la bande passante, ennuyeux.peut être trop gros pour cette configuration. Sinon, le câble est de belle fabrication et facile à mettre en oeuvre. Le câble d' origine est plus performant. Un rodage devrait l' améliorer mais le manque à gagner est assez important. Dommage... une fois n' est pas coutume
Christopher B.
Amazing New Product
First, before I say anything else, in case you are looking for such a thing, the WIIM PRO+ _does_ convert analogue to digital and stream it. I am using this remarkable new product, a real advancement in the world of audio, to stream an audio signal from my phono preamplifier to my Audiophonics DAW-S250NC, which does not have an analogue input.
Again: The WIIM PRO+ is streaming my phono signal to my modern Class D amplifier at a better-than-CD sampling rate. The sound is startlingly good.
At the same time, as you would expect, it also streams digital streams to my Audiophonics DAW-S250NC excellently well. There is no surprise there. For me, as a person with treasured records that I accumulated myself over my lifetime and 78-rpm discs and early LPs that I inherited from my father, the WIIM PRO+ has solved a problem that current advanced audio technology introduced to me.
I now have the option of listening to my records directly through my headphones or via the WIIM PRO+ to the speakers connected to the excellent Audiophonics DAW-S250NC amplifier. The WIIM PRO+ is a remarkably versatile element of my audio system and I think is well worth considering if you are looking for a streamer.
Tout d'abord, avant de dire autre chose, au cas où vous recherchez une telle chose, le WIIM PRO+ _convertit_ l'analogique en numérique et le diffuse en continu. J'utilise ce nouveau produit remarquable, une véritable avancée dans le monde de l'audio, pour diffuser un signal audio de mon préamplificateur phono vers mon Audiophonics DAW-S250NC, qui ne possède pas d'entrée analogique.
Encore une fois: Le WIIM PRO+ diffuse mon signal phono vers mon amplificateur moderne de classe D à un taux d'échantillonnage supérieur à celui d'un CD. Le son est étonnamment bon.
Dans le même temps, comme on peut s’y attendre, il diffuse également très bien les flux numériques vers mon Audiophonics DAW-S250NC. Il n’y a là aucune surprise. Pour moi, en tant que personne possédant de précieux disques que j'ai moi-même accumulés au cours de ma vie et des disques 78 tours et des premiers LP hérités de mon père, le WIIM PRO+ a résolu un problème que la technologie audio avancée actuelle m'a présenté.
J'ai désormais la possibilité d'écouter mes disques directement via mes écouteurs ou via le WIIM PRO+ sur les enceintes connectées à l'excellent amplificateur Audiophonics DAW-S250NC. Le WIIM PRO+ est un élément remarquablement polyvalent de mon système audio et je pense qu'il vaut la peine d'être pris en compte si vous recherchez un streamer.
Christopher B.
Very Good Quality
These are very satisfactory interconnects. The quality is excellent. I am glad to have them and will probably get them again when I need RCA interconnects in the future.
All of the Audiophonics equipment I have purchased has been excellent, in quality and design and also in aesthetics. Audiophonics combines quality with superb design at a very good price with fantastic customer service. For any equipment I need I will always look at Audiophonics first.
Raymond M.
Quelle qualité !!!
Avec ces 5m d’ElecAudio CS-361B et un connecteur Viborg VE512R, j’ai confectionné une ‘rallonge de luxe’ pour raccorder mon installation PC-HIFI à la terre. La prise de proximité en étant dépourvue. Mon ‘problème de riche’ c’est que j’ai tellement investi en matériel (pc, hifi, câbles) ‘high-end’ que je crois avoir atteint un tel niveau difficilement améliorable… Mais au moins ce qui est sûr c’est qu’une telle ‘rallonge’ ne peut pas faire l’inverse, car c’est superbe au niveau qualité. Curieusement j’ai la sensation que la visualisation de mes photos s’est améliorée avec des tons plus contrastés… Côté audio… Mais au bout d’un moment on rentre dans le subjectif…
frederic a.
TONEWINNER AT-300 EXT 5.1 AV Processor / Home-Theater Preamplifier Dolby Atmos 16 Channels 9.3.4 / 7.3.6 The Tonewinner AT-300 is a 16 channel audio/video processor and preamplifier, ideal for home theater integration in 9.3.4 or 7.3.6 configurations. It supports all current audio...
agréablement surpris
commende parfaitement traité par audiophonics rien à dire !
En ce qui concerne le processeur je sor d'un Yamaha CX 52àà a 2700 euros et quand j'ecoute celui ci il sonne mieux plus detaillé plus doux le systeme de calibration plus efficafe surtout au niveau des basses a condition de prendre l'option micro EM 2 bref je n'en revienns pas et je doute qu'a ce prix il y est beaoup de concurence
A.H. d.
A hell of an amplifier
This my first Class D amplifier, I enjoy it now for 15 months. And oh boy what a clean, powerfull and beautiful device it is! Well built, beautiful design. No remote contol but it has tirgger in/out so... no worries. Still one remark about the design related to ones health: Lifting it up be advised because the cooling fins are sharp, one could cut oneself.
Audiophonics did a great job building this amplifier and the very custom friendly approach is superb! Delevery was perfect as well.
Salvatore R.
exceptional cables
exceptional cable, remarkable 3D image, the instruments appear more in focus and great musicality.
Excellent audiophonic in very fast shipping.
joffrey J.
Transparence
Câble qui remplace un audioquest qui vaut 2x le prix.
Le canare est meilleur, car plus transparent, moins flatteur. Un scène sonore plus large et des aigus et mediums plus nets et clairs. Des graves moins boursouflés également. J'ai eu bien plus cher encore en modulation (atlas hyper), le canare est meilleur que celui-là aussi.
N'achetez rien d'autre, vous gâcheriez votre argent.
Audiophonics est d'une réactivité aux mails qui mérite d'être souligné. Bravo pour le service impeccable.
Excellents !!
Les condensateurs Mundorf méritent leur réputation.
Ces deux-là ont remplacé deux condensateurs 1uF MKT de sortie de mon préampli phono, amélioration immédiate.
Commandés un jour et reçus le lendemain, on ne peut pas être plus rapide, bravo Audiophonics !!
ETI BP-50C Speaker Terminal Gold Plated Pure Copper Ø19mm (Pair) The ETI BP-50C are very high performance speaker terminals at a contained price.  Made of a 1100 Series Hardened Copper conductor with an IAC of 102%...
Son magnifique et transparent
Je confirme c'est top
Cuivre only
Rosario Roberto S.
SMSL AO200 MKII è un ottimo amplificatore in classe D
Pensa all'AO200 MKll come a una versione premium dell'A300. È come la relazione tra AO200 e DA-9.
SMSL realizza modelli speciali a seconda del canale di vendita. AO200 MKll è un modello progettato e venduto per Aoshida HiFi.
Il case e il display dell'AO200 MKll sono notevolmente migliorati rispetto a quelli dell'A300, conferendogli un aspetto lussuoso.
La configurazione interna è la stessa dell'A300, ad eccezione dei diversi tipi di ingresso. Il chip dell'amplificatore è Infineon MA5332MS e JRC NJW 1194 viene utilizzato per il volume elettronico e l'equalizzazione e ha esattamente la stessa configurazione.
Il volume elettronico dell'NJW1194 commuta elettronicamente dall'esterno l'attenuatore di gradino del resistore ladder all'interno dell'IC. Inoltre, è integrato anche l'EQ e vari pattern possono essere configurati tramite programmazione.
L'unità di alimentazione è la stessa sia per A300 che per AO200 MKll, ed è composta da due sistemi di +32V -32V.
L'A300 ha due ingressi RCA sbilanciati, ma l'AO200 MKll ha ingressi XLR bilanciati e RCA sbilanciati.
L'A300 può passare a una configurazione mono, ma l'AO200 MKll no, ed è dedicato al funzionamento stereo a 2 canali.
Per quanto riguarda l'uscita SW, l'A300 mixa R/L internamente e lo emette, ma l'AO200 MKll emette R/L separatamente in stereo.
BT e USB sono funzioni completamente bonus e l'unico codec per BT è SBC in modalità base. USB utilizza la funzione DAC del modulo BT e funziona solo a 48kHz/16bit.
Quanto sopra è la differenza tra A300 e AO200 MKll. Poiché la configurazione interna è quasi la stessa, penso che non ci sia quasi alcuna differenza nella qualità del suono.
Grandiose !
Après le re- tubage de la partie pré amplification de mon Cayin cs55a avec des tubes PSVANE qui avait bouleversé les caractéristiques sonores de cet ampli, voici le tour des tubes de puissance.
Je ne savais pas vraiment à quoi m’attendre, tout au plus à une petite augmentation de puissance.
Je confirme donc les avis laissés plus haut de Laurent H et Robert V.
Chez moi, j’obtiens un système énorme avec un son d’une ampleur inédite.
Mes petites DALI Menuet chantent comme des grandes Utopia. Je ne sais pas comment décrire autrement la sensation d’un son, à l’échelle 1/1. Les instruments sont pour le coup véritablement incarnés. Les timbres sont parfaitement retranscrit avec toutes les nuances possible avec une taille réaliste.
Ça manque un peu de profondeur et de largeur ; un peu…
Évidemment ça donne envie de tester les PSVANE KT88-T2 vendues dans cette même boutique.
Je pense que pour avoir le meilleur des deux monde, il faut passer sur des amplificateurs plus onéreux avec des tubes exotiques de type 845 - 805 ou autre 300B.
Manfred G.
Burson
alles super geklappt, sehr guter Verkäufer, gerne wieder
Eric R.
8 ampères, mais attention pas vraiment 1800W
Utilisé pour mettre en marches des amplis d'un Home cinema. Sur le papier les 8X230, c'est à dire 1800W ne sont pas atteins. J'ai 1100W avec du classe D (800W) et 300W avec du classe AB. Mais cela c'est le max en utilisation, non pas à l'allumage. Cela doit faire en instantané probablement beaucoup plus. Donc au bout de 2 ans 1/2 le Trigger est "collé" en contact. J'avais déjà eu des soucis ponctuels à l'extinction en prémices...
Dominic D.
Mr.
Great product! Has all the bells and whistles that you would expect from a good LPS. High grade parts are used. Good value for the price.
Thank you!
NICHICON KG GOLD TUNE Audio Capacitor HiFi 80V 10000µF Nichicon electrolytic capacitors from the KG Gold Tune range are specifically designed for high fidelity audio applications. They can be integrated into many devices in your...
Excellent condensateur
Fantastiques !
Fantastique!
Re-tubing CAYIN cs55a EL34
Enceintes DALI Menuet
Sources : DAC Hugo2 CHORD
Tuner Magnum-Dynalab (triode)
Platine vinyles ClearAudio (performances DC- MC Melody sur T5) pré ClearAudio
Test à froid immédiatement après branchement.
Les tubes de puissance, sont toujours ceux du constructeur d’origine (EL34)
Si il n’y a pas de différence maintenant, alors après ça va être très léger…
Je me doutais que le changement des tubes au niveau de pré amplificateur pouvait modifier considérablement la signature sonore de l’ampli tout entier. Je précise que j’étais déjà assez satisfait du résultat sonore de ce Cayin.
Mais là c’est carrément holographique tout est meilleur.
Les timbres, les harmoniques, la scène sonore. Les sons ne se marchent plus sur les pieds. Le headroom comme disent les ricain, extinction des notes et des voix grandioses.
Même le ressenti de puissance est augmenté mais le son est brutal, ça casse la tête, difficile de monter le volume…
Test à chaud toujours sans rodage.
Retour de déjeuner…
Le côté casse tête a disparu.
Du coup je monte le volume !
Les hautes fréquences sont d’un naturel confondant. Les médiums sont moins en avant. Les basses sont solides et lisibles. Grosse métamorphose du système, et que du bon à venir, surtout que demain je reçois les tubes de puissance EL 34 aussi en PSVANE.
Encore plus de douceur, un grave plus profond, un petit gain en puissance ?
Je ne sais à quoi m’attendre…
Maintenant, il y a plus qu’à rôder tout ça .
Bien à vous.
Fantastique !
Retour de déjeuner…
Bien à vous.
Manuel F.
DAYTON AUDIO PC105-8 Speaker Driver Full Range 40W 8 Ohm 86dB 80Hz - 15kHz Ø10.7cm A full range speaker, compact and beautiful finishes. Ideal for building / repairing a small audio system or as a building block for more complex assemblies requiring multiple...
Dayton PC105-8
The speakers have a good quality/price ratio.
gilles t.
Bien, mais...
Bonjour, acheté pour remplacer un FX 01, parfait pour mes besoins, mais dénué d'une prise casque, j'ai donc opté, sur les conseils toujours avisés, compétents et aimables d'Audiophonics pour ce dac/ampli casque qui vaut quand même près de trois fois le prix du FX 01. Mes premières expériences ont été très décevantes, autant sur mes enceintes amplifiés que sur les différents casques ou écouteurs branchés dessus.
Volume faible et métallisations des aigus qui vrillent les oreilles, bref rien d'agréable. Frustré, j'ai eu l'idée de remplacer le câble USB fourni avec le DX 1 par celui de l''antique et modeste FX 01.
Surprise : le volume était deux fois plus fort, mieux défini, beaucoup plus fin, quelle que soit la définition du son d'origine et la qualité des écouteurs... Morale de l'histoire : c'est un très bon appareil, mais livré avec un câble de grille-pain. Même si vous ne croyez pas qu'un câble informatique n'a aucune incidence sur le son, puisqu'il n'est censé transmettre que des données informatiques, mon expérience me prouve le contraire.
Je m'étonne que le câble blindé fourni avec le DAC le moins cher au monde, le FX01, soit infiniment meilleur que celui fourni avec un appareil très bon mais trois fois plus cher.
Sinon, pour ce qui est de la qualité du DX 1 en lui-même, et sur le service Audiophonics, rien à dire, ou alors que du bien.
Amicalement.
Pierre D.
Bon produit tout métal, contact optimal entre le câble et la fiche, très bon maintien mécanique dans le bornier
Petit bémol un marquage trop discret rouge et noir
Parfait!
Une fois pigé la façon de passer la gaine sur le câble, le résultat est top!
Bonne communication avec Audiophonics!
Tournade E.
qualitée du DAC
le partie streamer et juste parfaite, mais la partie DAC n'est pas en reste, j'ai décidé aprés un test avec un M400 de ne pas rajouter de DAC. application génial. vraiment un produit parfait.
Si le budget n'est pas un problème n'hésiter pas, car la partie streamer devient exceptionnel.
Jacques T.
Produit de très bon rapport qualité prix, livraison rapide.
Marnix M.
Excellent mini-dac for very affordable price.
Simple, cheap but excellent and very versatile mini-DAC with HDMI-Arc input. Power over USB which every modern TV has. 24 bit resolution and 192khZ sample frequency by far enough for any home theatre. Limitation to only 2 channels.
Henry G.
Digital Caliper Stainless Steel +/-0.01mm 150mm This sturdy stainless steel digital caliper allows a measurement up to 150mm. It ensures high accuracy, with a tolerance of ±0.01mm. It is also capable of measuring in inches.
Bon outil
Outil de bonne facture. L'affichage, fort heureusement, ne se coupe pas automatiquement ce qui évite de perdre la mesure.
A noter: se met en route, sans activer le bouton on/off, dès que l'on active la coulisse.
olivier B.
AUDIOPHONICS T2 Preamplifier Vinyl player (MM) NJM2068 Black This AUDIOPHONICS T2 preamplifier is designed exclusively for use as an output from a source with a mobile magnet phono cell (vinyl player).
Petit boîtier solide,bien construit,avec façade en alu.
Fait le job.
Merci Audiophonics de nous proposer ce type de produit de bonne qualité avec un tarif avantageux.
Jacques B.
Superbe produit
Qualité de fabrication irréprochable permettant une haute qualité de contact et d'assemblage avec le câble secteur. Transparence et qualité de timbrage superbe par une transparence hors norme. A mon sens, plus neutre que les connectiques Furutech, sans nier leurs qualités également. Superbe mariage avec le secteur DPS 4.1 Furutech avec un apport concret dès la mise sous tension. Bravo !!
Jacques B.
Superbe produit
Jacques B.
La classe !!!
Remarquable produit avec une qualité de construction et un niveau de conductivité de très haut niveau. Dès le départ, il se passe quelque chose sur la restitution sonore malgré le fait reconnu que le rodage est très très long sur ce câble. Que cela va être après celui-ci ?? Large bande passante avec une beauté de timbres et une vigueur peu commune sans assécher le message. Bravo Furutech.
Joris J.
Addition
This text in the description above: “ The DAC connected to the module will then receive the audio signal on its optical input." this is only true when a optical cable is used between reclocker and DAC. This reclocker can also be used as a optical to coax converter. Both optical as coaxial output sockets of the reclocker give the output signal.
Mike d.
Fast delivery. Excellent device.
Suggestions:
1. offer a black faceplate as alternative
2. the psu is over dimensioned for a single intel nuc or intel-nuc-based-audio-device. Consider providing a second 19v output and second cable (as a bookshelf option?).
