Omar Y.
Amazing Hype 4 OG & great service
The Hype 4 Original are simply outstanding. Coming from my 10 years Fiio FH5, these Hype 4 has a better instrument separation,...
Guy P.
Parfait pour mon usage
J'ai acquis cet appareil pour rendre ma chaine Hifi compatible avec un casque Bluetooth (un Focal Bathys).
Mon...
joel G.
Où est la doc ???
Réception impeccable, câble fournis. Mais ou est la notice ? et même pas un site où se connecter pour une notice en ligne....
Customers reviews - There are 20869 reviews.
Peter L.
Ver nice DIY plug and play device
Works best with Volumio, in my opinion. With Volumio and the audiophonics-volumio-plugin, it is possible for me to skip tracks, control volume and shutting down proper with the remote control. Sound is very good - better than Topping DX3pro+, imo.
I paired it with pi3B+, 1GB RAM. Works fine! I build a case out of thin wood plates. Now, got a very good all-in-one STREAMER/DAC for 260 Euro!!! Nice!
But please Audiophonics-Team, make a big HINT in Github, that the old procedure of changing the kernel of raspy in order to get the I-Sabre-driver working, is NOT necessary anymore, because it is implemented in the newer os versions. That costs me hours of work, when i prepared a OS for plexamp!!!
Gerard T.
NEOTECH NEVD-2001 Coaxial Cable 75 Ohm Pure Silver Quad shielding Ø7.6mm The NEVD-2001 is an excellent Coaxial cable with an impedance of 75Ω, offering a wide bandwidth to reduce jitter and ensure maximum resolution. The cable benefits from an...
Magnifique...!
Installé sur rca canare 75ohms.
Avec dernier blindage raccordé que d un côté.
Ce câble sonne très analogique et naturel.
On ne se pose plus de question.
Gerard T.
Le câble
Bien respecter le dernier blindage que d un côté.
Musicalement ce câble est simplement "parfait"
Naturel et analogique.
Bravo
Sina M.
Look no further! Best performance vs price
Very powerful and clean amp. This is the best amp module out there for such a price range. Hook it up to a powerful PSU and take care of the wiring, you should have a great class D amplifier that can easily compete with the Big names for a fraction of their price.
Sina M.
MORNSUN LOF550-20B48 SMPS Switching Mode Power Supply Module 550W 48V 11A PFC This LOF550-20B48 switching-mode power supply module delivers 48V and 11A for 550W of power. The module features high-quality components and is...
Great Amp - Extreme low noise and proper heat dissipation
I assembled this UPS for a power amplifier project using the recent 3e stereo module. The result is very satisfactory. It has enough juice to power up 2 ELAC Tower speakers and the noise floor is non-existence to my ear. I didn't hook up a fan to the setup firstly because I didn't notice a change in the output power (it is advertised 11 Amps using the fan) and secondly the large heatsink at the bottom does a great job dissipating the heat. Keeping the setup running for hours the housing is warm to touch (32 C) and the transistor heatsinks are not too hot (40-45 C). I am very happy with the result
Hubert S.
TINYSINE TSA6017 Bluetooth 5.0 Receiver with Microphone Input The Tinysine TSA6017 adds Bluetooth 5.0 reception to a conventional HiFi system or headphone. The TSA6017 has a line output and a microphone input on a Jack 3.5mm. When using a...
Utilisé pour donner un accès Bluetooth à un ampli HiFi classique d'environ 20ans d'âge. En test audio depuis 3 jours. Parfait : le niveau d'entrée est bon, un peu plus faible mais bien. Le son est excellent. Comparé à un bon DAC à 200€ (très bien noté dans les critiques) sur une chaine HIfI de qualité classique, c'est très proche : même rendu des graves et des aigus, même présence des voix et des instruments, sonorité un poil moins ronde. Excellent rapport Qualité-Prix. L'avenir dira si la durabilité est bonne.
Hocine H.
Magnifique
Utilisé pour bretelle RCA de 60 cm, ce câble est bien un Mogami, détaillé, pur, précis, compléte parfaitement les câbles d'enceintes 3103 de la même marque. J'ai utilisé des connecteurs RCA Xangsane à 10 euros les 4 et je me retrouve avec une paire de câble de très grande qualité pour moins de 15 euros. Merci
Hocine H.
Pas mal
Bons connecteurs, de bonne qualité. Dommage que la soudure soit un calvaire si on souhaite souder le point froid car il est trop proche du point chaud (5mm environ). Ce même connecteur avec plus d'espace aurait été parfait car il est top pour ce prix.
michel m.
DAYTON AUDIO DSA115-PR Passive Radiator Aluminum 30.9Hz Ø10.2cm The Dayton Audio DSA115-PR is a passive radiator that can be used in a wide variety of installations, whether as a speaker or as a replacement for a similar defective model. A...
Renforce nettement les graves dans un caisson petit volume.
Guillaume V.
une très bonne surprise
je suis agréablement surpris par ce cable, je dois avouer que j'ai un faible pour les cables plaqués argent qui privilégie les aigus et médiums, ce qui permets des basses trés propre mais légèrement en retrait.
première paire de cable montés avec des fiches rca de la marque, trés satisfait de cet essai, je vais essayer une paire en xlr.
Guillaume V.
pas vraiment concluant
l'effet de pince est trop faible, du coup les fiches flottent un peu sur les connecteurs, pourtant les matériaux inspirent confiance et les soudures se font trés facilement, pas le cas de nombreuses rca.
par ailleurs l'utilisation avec le cable de la marque est vraiment satisfaisant pour ce qui est du son.
Dario G.
Dépanne bien, commode et pour un prix dérisoire.
Bravo audiophonics
Eric C.
FOSI AUDIO DA-2120C Amplifier Class D TAS5352A 2x90W 4 Ohm Bluetooth 5.0 Black With the  DA2120C , Fosi Audio offers a versatile and affordable  Class D amplifier . Its amplification stage allows it to deliver a power of  2x90W under...
Tres bon rendu.
Couplé avec des Spektor2 (Dali)
J'étais méfiant envers ces FDA.
Très bonne scène en Optique; du Volume et des basses que je suis obligé de moduler en fonction des enregistrements.
J'avais peur de basses électroniques, d'un rendu des aigus trop froid, trop clean-ique. Non, Impeccable.
Possible qu'a un volume au-delà de 65, ça sature. (suivant qualité de l'enregistrement) Je monte guère au delà des 40.
je ne me sers pas du Bluetooth; RCA décevant.
L'USB est surprenant en précision. L'optique: parfait (câble fourni relié à mon ordi)
Christophe H.
JANTZEN AUDIO COMPACT MKT 001-8080 Axial MKT Capacitor 160V 6.8µF Jantzen Audio's Compact MKT capacitors are made from the highest quality metallized polyester film available. Jantzen Audio has succeeded in making these capacitors more compact...
Pour remplacement des médiums aigus sur filtre enceintes Cabasse Doris M2, en lieu et place des condensateurs d'origine Wishay MKT 1822 (verts). Le résultat est très bon. Les médiums et aigus retrouvent leur place. Les voix initialement criardes retrouvent leur ton (surtout les voix masculines, qui n'avaient pas de caractère et manquaient de texture). Les instruments et voix sont mieux placés et respirent. Ce n'est serte pas aussi dynamique, explosif et aéré qu'avec des Jantzen sup Z que j'ai monté sur des Dali Zensor 7, mais je dois dire que je suis assez surpris par la qualité. Pour ma part je trouve supérieure aux Jantzen cross cap et z cap. Ils sont plus neutres. leur valeur est exactement celle indiqué à 0,01micro farad près gage de qualité de fabrication. Cerise sur le gâteau si vous ne voulez pas vous torturer pour trouver une place sur le filtre, ils sont de taille modeste. Environ la même que ceux qu'ils remplacent.
Arnaud B.
Excellent ampli
Merci Audiophonics pour les conseils m'amenant à ce choix d ampli !
Le resultant est bluffant
Cédric R.
SENDY AUDIO Balanced Jack 4.4mm Extension 6N OCC Copper Gold Plated 1.5m This Sendy Audio balanced extension cable consists of a Jack 4.4mm female connector and a Jack 4.4mm male connector. It offers an excellent design quality with insulated and...
Bien mais onéreux
Ça pourrait être le câble d’origine livré avec le casque sivga p 2. Cher pour la longueur je trouve mais bon. Je n’ai pas trouvé de câble de 3 m pour le sivga.
Jose l.
TOPPING DX9 DAC AK4499EQ Headphone Amplifier NFCA Bluetooth 5.1 AptX LDAC 32bit 768kHz DSD512 Silver To celebrate its 15th anniversary, Topping unveils a high-performance DAC / Headphone Amplifier: the DX9. In addition to its very high performance, Topping has given it a...
très belle scène sonore
c'est un dac très bien construit , avec une très belle connectique . pour le son, c'est un plaisir musical. testé depuis 2 mois et comparé avec un smsl su-10 double dac sabre 9038 pro qui est très bon aussi, mais moins musical et moins équilibré .très belle réussite de la part de topping bravo.
Petit ampli qui tient ses promesses
Malgré mes craintes au sujet des FDA et de leur absence de boucle de rétroaction avec pour conséquence un faible facteur d'amortissement, cet ampli dépasse mes espérance en terme de qualité sonore (malgré des enceintes bibliothèque relativement basiques)
L'utilisation via Bluetooth. aptx-hd est vraiment très bonne même si les entrées numériques sont permettent une diffusion encore plus qualitatives.
Il est installé dans une résidence secondaire et c'est juste parfait.
Je l'ai également testé sur des enceintes colonnes et avec un streamer node, le son est excellent.
Xavier C.
Boîtier lourd et massif (1kg !), tôle d'acier épaisse et façade aluminium anodisé. Ça inspire confiance et c'est stable.
Pour mon usage j'aurais préféré 6 entrées ...
Cet appareil remplace un préamplificateur inutile (sauf pour la platine disques analogique évidemment) pour attaquer les amplis de puissance via un simple potentiomètre de volume.
Bon fonctionnement, c'est bien le moins.
Un défaut, le sélecteur d'entrées est assez désagréable et "râpeux" dans sa rotation.
Emballage et expédition sans défaut, très bien.
Pierre F.
Excellent "petit" ampli.
Pierre F.
VMV d2
Un mot !
FANTASTIQUE.
Hocine H.
Top produit
Je devais splitter un câble Mogami 3103 de 12 mm avec 2 conducteurs 4 mm. J'ai pu poser les 4 splitters en moins de 5 min en appliquant un peu de vaseline sur les conducteurs, ça passe sans effort. C'est efficace et tellement plus jolis pour termier les câbles HP. Je recommande vivement !
Hocine H.
Des frissons
Après quelques heures à dénuder, gainer, thermo coller, graisser, visser pour obtenir 2 câbles de 2 m, je me faisais une joie de les tester.
Quelle n'a pas été ma déception, je pensais vivre une histoire d'amour avec ces câbles, mais ils n'avaient pas de vie.
Alors j'ai vérifié une deuxième fois la construction, mais ils étaient corrects ; j'ai alors relu les avis élogieux et j'ai constaté cette fameuse période de rôdage...
J'étais sceptique sur le rôdage des câbles, mais après 15/20h continues (sans les écouter, j'ai laissé tourner en boucle un titre) ça a été le coup de foudre.
Ces câbles sont exceptionnels pour le prix, détaillés dans le haut du spectre, des médiums précis et, beaucoup de basses à mon goût (c'est subjectifs et ça se corrige).
Ce câble est comme une fleur qui a besoin d'éclore et une fois l'éclosion faite c'est un pur bonheur à en donner des frissons ; je ne regrette pas cet achat. Foncez à ce prix !
Thomas H.
NEOTECH NEX-OCC RH XLR Connectors Male / Female 3 Poles Rhodium Plated UP-OCC Copper Ø13mm (Set x4) Neotech NEX-OCC RH XLR connectors, sold in sets of 4, benefit from Rhodium-plated UP-OCC copper contacts to offer perfect conductivity and resistance to oxidation. These...
Fabulous Connectors
Perfect in every way, at each end of the audio spectrum. Small break-in time, in fact new sonic details emerged as well. Used as a primary set from my DAC to Preamp, they are well worth the higher entry point. Thanks Audiophonics!
François C.
IBASSO DC06PRO Portable DAC / Headphone Amplifier 2x ES9219C 32bit 384kHz DSD256 MQA 16x Ibasso unveils a new version of its DC06 portable DAC/headphone amplifier, the DC06 Pro. Compact, it features 2 ES9219C DAC chips and volume control knobs, new advanced features...
IBASSO DC06PRO DAC
Apporte un gros + sur iPAD. Son de meilleure qualité. En revanche rien de mieux sur un Samsung S23 Ultra.
NEUTRIK NC3MX-BAG 3 Way Male XLR Connector Silver Plated Ø8mm (Unit) This 3-pin XLR male Neutrik NC3MX-BAG connector allows quick and easy assembly, consisting of only 4 pieces and no screws. It benefits from a compact design, a sturdy Zinc shell...
Comme sa version femelle, bonne fiche qualitative et neutre .
Fiche de bonne facture avec un rapport qp très bon. Facile à mettre en oeuvre.
Cote son, elles me semble assez neutre .
zeljko j.
Good wire. Very fast shipping . I will buy from you again.
Jochen M.
LHY AUDIO BATT-USB Regulated Linear Power Supply on Battery 5V 2A This LHY Audio BATT-USB regulated linear power supply module uses four 21700 batteries with a capacity of 4900mAh (a total of 9.8Ah) and an ultra-low-noise LDO LT3042 linear...
Basically a fine thing
I bought two devices. Both have an audibly positive effect on music playback with the devices now supplied with clean power (rpi/WiiM/Dac). The first device is flawless. The batteries of the second device are weak. The batteries are empty after approx. 3 hours. Two green LEDs still light up, then the device switches off. On the first device, the batteries last for at least 5 hours without any problems until all LEDs go out.
Marc L.
Ces fiches sont parfaites. Très faciles à mettre en oeuvre et le système de vis permet au câble d'être parfaitement attaché.
olivier P.
Pour HF en actif
Utilisé pour driver une compression 114db en actif asymétrique afin de supprimer le souffle.
Essai transformé, l'oreille à 20cm de l'embouchure du pavillon plus de souffle il reste juste un très faible bruit électronique inaudible avec un peu de recul.
Léger ploc à l'extinction suivant ordre d'arrêt et chauffe quand même malgré la faible puissance demandé mais moins que mon ancien classe A.
Donc je préconise cet ampli lilliputien pour cette application et pour le reste je croise les doigts
Stephane N.
Acheté pour un second système, c’est un très bon ampli, bien fabriqué et aux qualités musicales réelles.
Stephane N.
Mise à niveau réellement audible
En remplacement d’un MCap standard dans le filtre d’une paire de JERN AUDIO 11s, l’opération n’est pas si simple, la taille du Suprême est 4 fois plus importante !
Mais l’entreprise et le temps passé en valent le coup.
Tout est bien plus homogène, certaine crispation des aiguës ont disparue ( câbles Nordost sans pitié ).
L’investissement financier est fondé.
Ravi de ce produit.
Ralph L.
Vielen Dank an das Audiophonics Team!
Seit 35Jahren ist HiFi für mich ein Hobby. Viele Geräte sind seit dem gekommen und auch wieder über den Gebrauchtmarkt gegangen. Was soll man sagen? Ab und zu braucht man
halt wieder was neues … Dieses Mal sollte es ein Class D Amp werden um in meinen langen
Hörsitzungen nicht so viel Strom zu verbrauchen. So groß würden meiner Meinung nach die Unterschiede nicht sein wenn man doch nur die Endstufe tauscht …dachte ich. Doch nach dem Audiophonics mir 2 verschiedene Class D Endstufen geschickt hatte wollte ich schnell wieder meine alte Endstufe zurück … doch die war bereits verkauft. Dann sind 2 von diesen kleinen LA 90 d angekommen … Und jetzt bin ich wieder sehr glücklich mit dem Klang in meinem System. Die Maximale Lautstärke ist sowieso nicht wichtig für mich und nur wenn es laut sein soll sind hier Abstriche zu machen … klar mit den kleinen Verstärkern kann man keine Bäume ausreißen. Einen LA 90 d würde ich nicht für Lautsprecher unter 88dB empfehlen … Und zwei auch nicht für Lautsprecher unter 86 dB Wirkungsgrad. Ansonsten können die alles was ein Verstärker um 5000 Euro kann … die Frage ist also nur wieviel möchten Sie ausgeben? Wie laut hören Sie? Und welche Lautsprecher haben Sie?
Stephane N.
Excellente qualité et très bon résultats sous un AUDIOMAT Arpège Référence.
vincent g.
FOSI AUDIO V3-48V Stereo Class D Amplifier TPA3255 2x225W 4 Ohm The V3 from Fosi Audio is a compact and powerful amplifier at a very affordable price. Despite its simplicity, the V3 amplifier uses high-quality audiophile components such as a...
Trés satisfait !
Il vient remplacer un vieux Technics SU-V460. Le Fosi est alimenté par un préampli DAC Tangent et alimente des Focal Chorus 705v.
Tout s'accorde très bien, un son clair et précis comme ce que je souhaitait.
Jyrki K.
Jyrki
Dry and precise. No Color the sound. Hard, not soft.
I recommend.
Jyrki K.
Jyrki
The transformer was loose and allowed to move and rattle inside. Just a little tightening of the screw and the problem is gone.
The power supply supplies power to the Volumio Rivo network player and the Pro-Ject Pre Box S2 Digital DAC.
The power source opens up the sound and brings more separation. It feels like there is more power and the dynamics increased. Hears more details in the recording.
I recommend.
Gilbert H.
Bon Connecteur, mais...
Un bon connecteur d'un prix tout à fait raisonnable. Seul regret, la partie métallique du connecteur n'est pas reliée à la broche centrale par une vis comme sur les autres connecteurs de ce type, elle n'est donc pas reliée au chassis , dommage... donc une étoile en moins
jean michel G.
Belle surprise
Après avoir longuement utilisé un Audio GD 19 SINGULARITY qui m'a donné de belles écoutes, ce Topping est un passage pour l'écoute du DSD. DAC très musicale, apporte une belle précision des notes. Passage directement en mode NOS des sa mise en route.
Emmanuel A.
Un excellent câble qui ne paye pas de mine malgré un prix bas
Pas besoin d’autre chose
Yassin B.
j'avais l'ancien modèle dont j'étais très satisfait.
Suite à sa panne, j'en ai profité pour une mise à jour.
Encore mieux.
Pour ceux qui o,t une imprimante 3d, je mets à dispo un boitier :
https://www.thingiverse.com/thing:6473605
bonne écoute,
Un câble secteur impressionnant
La taille du câble est énorme et la fabrication est vraiment de qualité. Branché sur un ampli casque Audio GD, le résultat auditif donne une belle musicalité. Du grave à l'aigu tout semble parfaitement équilibré. Pour un prix raisonnable c'est un très bel équipement.
Mauro M.
AUDIO-GD R-27HE R2R DAC Balanced Class A Headphone Amplifier Preamplifier 32bit 384kHz DSD512 Silver A new creation from Audio-GD, the R-27HE is a balanced R2R DAC ladder with a built-in headphone amplifier and ACSS preamplifier. This improved version of the R-27 now features a...
Definitivo
E' improbabile che, se non si guasta (ma la mia esperienza con gli apparecchi Audio-GD è positiva dal 2014) io pensi di cambiare questo all-in-one semplicemente meraviglioso.
Il suono è melodia pura, la flessibilità elevatissima.
L'unico difetto, se vogliamo trovarne uno, è l'imbarazzante sistema di menù per le regolazioni, anche le più semplici come gli ingressi e le uscite.
Miroslav B.
VMV D2R
The DAC has excellent sound, detail and space.
The aluminum body and remote control make the device an elegant addition to the audio set.
Crackling when changing the sample rate of the track being played.
In variable mode, the DSD signal is at full volume. Need to convert the signal DSD to PCM!
When turn on DAC and start playing, transmit the signal for 1 second in full power! Only in Variable mode !
DAC is ideal to connect it to a preamplifier.
Jérémy G.
Bluffant
Associé au bt20a pro de fosi audio, ça devient plus intéressant. Ce qui surprend le plus, ce sont les graves, très présent, il faut pouvoir régler le gain.
Fait parfaitement le job et sa petite preamplification est vraiment très appréciable pour des enceintes à faible rendement donc difficiles à driver.
Olivier L.
Fonctionne très bien avec le wifi 5, streaming très facile, stable, interfaces multiples qui reconnaissent même les autres appareils, très bien pour le multi-room. Améliorable avec un DAC extérieur ce qui me semble une meilleure stratégie qu'un modèle de la même marque avec un meilleur DAC interne (Pro Plus). Et quel tarif rikiki !
Edgar T.
XDUOO TA-26S Tube balanced Headphone Amplifier / Preamplifier 6N8P 6N5P The TA-26S from xDuoo is a tube headphone amplifier, with a nice design that reveals a smooth, warm and accurate sound. It embarks for that a 6N8P tube for the preamplification...
The magic of electronic tubes
An inexpensive headphone tube amplifier with a great audio quality out of the box.
It improves as the time goes by.
A great amplifier that puts all my high impedance headphones singing with authority.
Probably my best bargain in Hi-fi.
Outstanding.
pascal B.
TRIANGLE OPERA OS100C Speaker Cable OFC Copper 2x1.5mm² Developed by Triangle, Opera speaker cables guarantee excellent electrical signal transmission quality. To achieve this, they incorporate braided OFC copper conductors, each...
cable HP
excellent rapport qualité/prix pour ce cable au mètre en cuivre étamé
pascal B.
prise din
très pratique avec son serrage à vis latéral ; rare de trouver des prises din doréees
