XDUOO MX-02 Bluetooth Transmitter
The xDuoo MX-02 is a high-definition Bluetooth audio transmitter designed to transform your wired audio sources into a high-quality wireless experience. With its versatile connectivity (USB, optical, coaxial, and line), it easily integrates into your existing setup, whether it's an audio system, TV, or game console.
4.7 / 5
Reference : 21275
109,00 €tax incl.
90,83 € tax excl.
Shipping date: 17-11-2026.
xDuoo MX-02 Émetteur Bluetooth 5.4 LE Audio aptX Adaptive
xDuoo MX-02
The xDuoo MX-02 is a high-definition Bluetooth audio transmitter designed to transform your wired audio sources into a high-quality wireless experience. With its versatile connectivity (USB, optical, coaxial, and line), it easily integrates into your existing setup, whether it's an audio system, TV, or game console. Equipped with a next-generation Qualcomm Bluetooth chip, the MX-02 supports Bluetooth 5.4, offering extended range, reduced latency, and increased stability. It is compatible with advanced audio codecs such as LE Audio (LC3), aptX Lossless, aptX HD, and aptX Adaptive, ensuring sound quality close to that of a wired connection
Its aluminum alloy casing provides optimal protection against electromagnetic interference, while offering a robust and elegant finish. The MX-02 is ideal for those looking for a reliable, high-performance solution for streaming high-resolution music without compromising on quality or signal stability.
xDuoo MX-02 : Une grande polyvalence
Le MX-02 se distingue par sa capacité à s’adapter à une grande variété de sources audio grâce à ses entrées USB, optique, coaxial et ligne (RCA). Cette polyvalence permet de le connecter à presque tous les appareils audio, qu’ils soient modernes ou plus anciens. La prise en charge des codecs LE Audio, aptX Lossless, aptX HD et aptX Adaptive assure une transmission audio de haute qualité, adaptée aux audiophiles exigeants.
xDuoo MX-02 : Performances de codecs Bluetooth
xDuoo MX-02 : Bluetooth LE Audio
Le MX-02 supporte aussi le format LE Audio et les codecs LC3 et aptX Lite. Ceux-ci, en plus d'offrir une qualité audio élevée, permettent d'assurer une très faible latence, inférieure à 20ms. Ils sont donc idéaux notamment pour le jeu vidéo.
xDuoo MX-02 : Design et robuste
Le boîtier en alliage d’aluminium du MX-02 allie esthétique et durabilité. Il protège efficacement les composants internes des interférences, tout en assurant une dissipation thermique optimale pour une utilisation prolongée.
La façade du MX-02 affiche un bel écran TFT couleur. Celui-ci affiche non seulement le mode de fonctionnement de l'appareil (comme les appareils connectés ou le format Bluetooth utilisé), mais également d'accéder rapidement aux différents paramètres.
xDuoo MX-02 : Écran
xDuoo MX-02 : Installation rapide, utilisation facile
Simple à installer, le MX-02 se connecte en quelques minutes à votre source audio et à vos enceintes ou casques Bluetooth. Son format compact et sa construction solide en font un accessoire discret et facile à intégrer dans n’importe quel environnement audio.
Type de produitÉmetteur Bluetooth
Entrées1x USB-C
1x Optique Toslink
1x Coaxial
1x RCA stéréo
SortiesBluetooth
Version Bluetooth5.4
Codecs Bluetooth supportésCodecs classiques : SBC, aptX, aptX HD, aptX Adaptive, aptX Low Latency, aptX High Quality, aptX Lossless
LE Audio : LC3, aptX Lite
Latence de transmission< 20ms (encore inférieur en mode "Jeu")
Portée de transmission~ 50m (hors obstacle)
Alimentation5V 0.25A via USB-C
Dimensions120 x 102 x 42mm
Poids360g
CouleurGris
Package1x Xduoo MX-02
1x USB-C power cable (note: AC adapter not included)
OutputBluetooth
DAC / ADC ChipNC
ColorGray
Supported Bluetooth codecsaptX Adaptive
Supported Bluetooth codecsaptX Lossless
Supported Bluetooth codecsaptX High Quality
Supported Bluetooth codecsLC3
Supported Bluetooth codecsSBC
3 reviews
Parfait pour mon usage
Je me sers du XDUOO MX-02 pour raccorder un casque Focal Bathys à mon ampli. La liaison est optimale même éloigné de la source (2 étage de séparation dans une maison individuelle).
Par contre, il y a un détail qui est un peu agaçant. Il ne dispose pas d'une option pour désactiver le clignotement du gros bouton quand il n'est pas appairé. L'appareil clignote en permanence d'une façon peu discrète. Il faut débrancher l'appareil pour arrêter le clignotement. A revoir.
This review has been posted for XDUOO MX-02 Bluetooth 5.4 Transmitter LE Audio aptX Adaptive
A défaut d'une meilleure solution
Mon besoin : un casque sans fil pour de l'écoute (autant que possible) "Hifi" (et sans artifice) à partir de 2 entrées numériques (pour y connecter à la fois un Nativ Vita et un PC).
Mon casque Sennheiser RS220 (qui n'avait pour lui que sa connectique et sa qualité sonore ...dans un rayon de 5m) ayant rendu l'âme.
A défaut de transmission dédiée Hifi, voire Wi-Fi, j'ai opté pour un émetteur Bluetooth.
N'ayant pas trouvé d’émetteur LDAC qui convienne, je me suis rabattu sur l'aptX Lossless (aptX AD dans les faits) via un casque Cambridge Melomania P100 SE.
Et donc ce XDUOO MX-02, dont le boitier d'aspect robuste est plutôt compact (tout en disposant d'un écran largement dimensionné).
Au premier abord, son utilisation m'est apparue un peu déroutante.
Comme le fait qu'il n'affiche aucun choix de codec (pas même en "grisé") s'il n'y a pas de périphérique connecté (puisqu'il n'affiche que les codecs compatibles).
Il n'est pas non plus toujours très réactif à l'appui sur le bouton multifonction.
J'ai aussi constaté quelques errements conduisant à devoir le redémarrer. Parfois, en cas de changement de source à la volée (par l'intermédiaire du menu) non pris en compte. Plus systématiquement lors d'une reconnexion du casque en sortie de veille, l’émetteur ne semblant plus savoir quel codec utiliser.
Il est appréciable de pouvoir régler le volume de sortie (par rotation du bouton).
Je n'ai jamais pris la transmission en défaut (sur une distance de 10 m).
Le résultat sonore n'est pas époustouflant (n'ayant toutefois pas testé le casque sur une autre source).
Si le XDUOO MX-02 accepte le 24 bits/192 kHz en entrée, c'est en sortie que ça "coince".
J'ai pas mal de musique en 24 bit/96 kHz (de fait). Or, passé le 16 bit/44,1 kHz, l'aptX Lossless semble dépassé (l'aptX AD tentant de ...s'ADapter, j'imagine ?).
La version 16 bit/44,1 kHz d'un morceau (dont je ne dispose pas toujours) me parait ainsi mieux restituée que sa version 24 bit/96 kHz.
Sans être parfait (pour mon usage), il me dépanne, à défaut d'avoir trouvé meilleure solution.
J'ai acquis cet appareil pour rendre ma chaine Hifi compatible avec un casque Bluetooth (un Focal Bathys).
Mon branchement est simple. Le XDUOO MX-02 est relié par un câble RCA à la prise Jack/casque de l'amplificateur afin de couper le son des enceintes lorsque j'écoute au casque Je peux ainsi écouter toutes les sources reliées à mon ampli (lecteur CD, Eversolo DMP-A6 ...).
Attention de bien prendre un câble de qualité. Pour faire un premier essai j'avais pris un câble Jack/RCA de base (type informatique), et j'entendais un sifflement lorsque mon dac ou mon streamer était allumé. Après changement du câble par un QED tout est nickel.
En résumé très bon appareil facile à connecter, très neutre dans le rendu sonore. Je recommande.
The xDuoo MX-02 is a high-definition Bluetooth audio transmitter designed to transform your wired audio sources into a high-quality wireless...
