Nicolas B.
Steve D.
Dayton spa300-D
Genalex
Bert D.
Heel handig
Voelt betrouwbaar aan vanwege stevige afwerking en prettige bediening. Lekker veel ingangen.
Bert D.
Very diverse and good looking
It's a very handsome and diverse device and above all very good sounding.
Bert D.
Good quality
Build quality is very good for its price.
Bert D.
DYNAVOX Gold Plated Banana Plugs Ø5mm (Pair) These low-cost Dynavox banana plugs allow a simple and quick connection to the terminals of your speakers and amplifiers. The contacts are gold plated to ensure good signal...
Robust
Good connecting and installation quality for little money.
Bert D.
Alright
It does the thing it has to do, without spending much money.
Gabriel V.
TONEWINNER AT-7300HD AV Processor / Home-Theater Preamplifier Dolby Atmos 13 Channels 7.2.4 The Tonewinner AT-7300HD is a 13-channel audio/video processor and preamplifier, ideal for home theater integration in configurations up to 7.2.4. It supports all current audio...
Super content ,comme toujours audiophonics ma expédié la commande super rapidement. Le produit a un bon packaging et il respire la qualité. Je posterai un deuxième avis dans quelques temps quand j'aurais assez de recul sur sont utilisation
Claude G.
Prise shuko
Posée sur un câble secteur de qualité standard, apporte plus de matière et de poids au son... bon produit
Silvo P.
Very satisfied
Fast delivery, quality service.
Fabrice j.
very satisfied
good results against the sticky static effect when handling your vinyl and choice between a sharp dry sound on the cork side or a deeper subtle bass on the black side
M A.
nice product, exactly what I was looking for.
works perfectly with the volumio audiophonics on/off plugin.
just a question, there is a connection for an infrared sensor, how does this work? can't find anything about it.
IFI AUDIO GO BAR Portable USB DAC Headphone Amplifier XMOS 32bit 384kHz DSD256 MQA With the Go Bar, iFi Audio offers its most powerful USB DAC and ultraportable headphone amplifier. With its particularly compact size, it can accompany you on all your travels...
Si petit, et pourtant....
Bien fini, encombrement mini, caractéristiques de premier plan font de ce Dac portable une alternative à beaucoup de Dac de bureau.
Du grave à l'aigu en passant par le médium, la clarté, la finesse du message sonore procure un réel plaisir d'écoute.
Assez puissant pour dans mon cas piloter un casque de 250 Ohms sans problème.
Très content de cet achat.
Bien fini, petit encombrement, mais son sublime, du grave à l'aigu en passant p
FERRUM HYPSOS Hybrid HiFi Power Supply 5V-30V Adjustable The Ferrum Hypsos is a high-end power supply, offering exceptional technology and performance to give your HiFi audio system an extremely clean power supply for optimal sound...
Bel appareil
Pour couplage avec mon ampli casque Oor fait très bien son travail d'alimentation. On peut l'utiliser avec de nombreux appareil pour une meilleure alimentation, le voltage étant réglable.
Bon achat
FERRUM OOR Balanced Preamplifier Headphone Amplifier Ferrum's OOR is a high quality balanced headphone amplifier and preamplifier, capable of accompanying all types of headphones, including the most demanding, while preserving the...
Bel objet
Appareil aux qualité d'écoute indéniables procurant un plaisir certain couplé avec un bon dac et bon casque.
Une fois le casque sur la tête, le prix élevé se fait vite oublier.
Content de mon achat.
FERRUM FPL DC Power Cable for Ferrum OOR / HYPSOS 50cm The Ferrum FPL is a proprietary DC power cable for connecting the HYPSOS high-end power supply and the OOR headphone amplifier/preamplifier. The cable has four conductors: two...
Beau câble
Câble très bien fini pour couplage de mon Hypsos avec mon Oor
Pour remplacement
En remplacement des tubes d'origine de même marque (8 ans) de mon ampli casque.
Ai retrouvé les caractéristiques originelle de mon ampli.
Jean Claude L.
Excellente
Fiche de belle qualité
J'en ai monté quelques de marques différentes, celle ci est la meilleure de toutes tant en qualité qu"en rendu sonore
Jean Claude L.
Qualité
Bon pouvoir de rétractation.
Bon grip sur le câble pour un aspect très pro
Une des meilleure essayée jusqu'à là
Jean Claude L.
Idéal pour un câble de 0.5mm
Facile grandement le travail
Jean Claude L.
Parfaitement adapté pour du câble de 0.5mm
Glisse parfaitement dans la gaine.
Jean Claude L.
Qualité de fabrication et rendu sonore au top
Jean Pierre A.
DAYTON AUDIO PHT1-6 Speaker Driver Planar Horn Tweeter 80W 6 Ohm 105dB 2500Hz - 18kHz Planar tweeters offer a rich and transparent sound reproduction but do not always have the robustness or reliability necessary for professional use. This Dayton Audio PHT1-6...
reception colis
aucune alerte de colissimo paquet jeté par dessus le portail .
Pas de sms aucun suivi de l'envoi ??????????
Sans aucune précaution? A vérifier lors due la mise en route du produit si tout fonctionne normalement.
Laurent F.
rapport qualité/prix excellent
fil interne rigide
a permis de transferrer la box tv ,avec 15ml de ce cable , de la box internet
Philippe S.
Super finition
La finition est très haut de gamme pour le prix mais le son n'est pas aussi bon qu'une furutech 24 au rodhium, malheureusement, cette dernière vos deux fois plus cher.
Philippe S.
bon rapport qualité prix
Fait le job pour les petits budgets, ne peut pas rivaliser avec du furutech FI 38 mais qui est tout de même deux fois plus cher.
Philippe S.
attention au mariage !
Sur mon système, j'ai préféré la 28 en gold qui me parait plus homogène, les aigus et haut médiums sont très définis sans être agressif mais cela se fait légèrement au détriment du grave, si vous recherchez à amener un peu plus de clarté dans votre écoute alors c'est le bon choix.
Philippe S.
entrer dans le son furutech
Par rapport à une FI 11, le gap est très significatif, je l'ai monté sur du câble furutech 32 et le mariage me convient très bien. C'est à la fois chaud et détaillé, cette prise me parait plus homogène que la 38 au rhodium.
P.S : un sacré bon en avant quand je l'ai monté sur du nordost red dawn.
Laurent C.
Esthétique, serrage des deux vis c du costaud, excellent maintien dans les borniers et aucune coloration du son. Que demander de plus à ce prix là !!!
Jeff H.
Significant upgrade from my older USB DAC
Initial impression is great clarity and very even tonality. This has excellent performance at a very good price. I am very satisfied. I can't compare with more expensive models as I don't have one to compare with, but this a very significant upgrade from a similarly priced DAC of a few years ago.
Philippe S.
Une loupe pleine de douceur
Monté en remplacement d'une fi 34 gold sur un câble furutech 32, et après une bonne vingtaine d'heures de rodage (obligatoire sinon attention les oreilles) le gap est significatif, les aigus sont légèrement plus présents tout en restant soieux, j'ai aussi gagné en présence. Je suis satisfait de mon achat.
Julien O.
Ce à quoi l on s attendait
Rapport qualité prix excellent, fait bien son job avec un bon son.
Le BT est très correct.
Seul bémol livré sans cordon d alimentation ni pile dans la telecommande
Excellent comme toute la gamme Néotech
Utilisé en upgrade câblage interne avec de trèèès bons résultat l'idée a été de tester en câble de modulation Xlr, le résultat est simplement d'un rqp extraordinaire monté avec des fiches EIZZ achetées ici, ouverture détail image magnifique, a tester absolument sur vos systèmes.
Hans L.
Really punching over its price range,
Used unterminated between an Luxman L509x and the new Mission 770 the result is really an eye opener.
Wonderfull open and spacious midrange that reaches well out in the room. A really smooth and open sound signature .
Makes the Van Den Hul THE INSPIRATION HYBRID sound grainy and sharp in comparison. And that's a cable to 100€+/m.
The Ortofon SPK-3900Silver sounds thin and congested in comparison. And they are both great cabels in their price range.
The ELECAUDIO HP-250CC betters both cabels in naturalisme and soundstage by a large margin.
A benchmark cable in my mind. and even if the cable was 100€+ it would still be a steal.
It has my highest recommendation!
Claude B.
Boîtier hifi eco 200
Boîtier bien fini. Utilisé pour réaliser un sélecteur de source. Il faut juste faire attention lors du forage des trous pour les embases RCA car le foret à tendance à ovaliser la tôle aluminium de faible épaisseur.
Claude B.
ELECAUDIO RC-1450 RCA Connectors Gold Plated Ø14.5mm (Pair) These oversized ELECAUDIO RC-1450 RCA connectors accept cables up to 14.5cm in diameter, enabling you to use very large conductor cross-sections, and ensure excellent clamping...
Connecteur RCA
Connecteur de belle qualité mais malheureusement le diamètre côté câble trop important et impossible à connecter sur bornes préampli.
Claude B.
Excellente embase RCA
Utilisées pour réaliser un sélecteur de source pour 2 frontales + un caisson (LFE) pour basculement entre un préampli hifi et un ampli AV. Soudure facile, résultat impeccable.
Claude B.
cosse à oeillet
Excellente qualité. Utilisé sur interrupteur à bascule type aviation, mais j'ai ajouté une rondelle car diamètre oeillet trop important.
Charles S.
ETI KRYO Silver Plated Tellurium Copper 3 Way Male XLR Connector Ø12mm (Pair) These ETI Kryos are high-end XLR connectors designed with exceptional components. There are Tellurium Copper contacts with Silver plating for maximum conductivity and durability.
ETI KRYO Connecteur XLR Mâle 3 Pôles
Aussi incroyable que cela puisse puisse paraitre à l'écoute, ce Connecteur XLR est de loin le plus musicale que j'ai branché sur mon installation. Depuis les ancestrales Neutrik en passant par Furutech et consort , la technique ETI KRIO c'est du très niveau la soudure est facile, l'isolation en téflon supporte aisément la température de la panne du fer à souder . Un peu cher mais le résultat est au rendez vous .Hautement conseillé pour les audiophiles et les mélomanes
Frank j.
singxer su2
my no. 2 singxer su2
should it use that experiment
changed Capacitors to os-con
and changed the 5 volt power supply to ifi power elite
and a 10mhz master clock
sounds more like 3d
much better treble and midrange
singxer su2 sounds fantastic in itself
one of the best usb interface
Dimitris D.
It is was used in my home cinema and pluged in a subwoofer Velodyne.
It enhances the sound ,with low costs .
Dimitris D.
I am very satisfied ,because of the low price and the quality of sound.
IFI AUDIO NEO STREAM Streamer WiFi DLNA AirPlay Roon Ready XMOS Balanced 32bit 768kHz DSD512 MQA The iFi Audio Neo Stream network player has been designed to offer both versatility and excellent sound performance. It combines the latest version of the brand's network...
super streamer
En complément de mon avis. Cet appareil remplace un digione signature. La différence de prix est totalement justifié. Le neo est supérieur en tout point
excellent streamer
Le look est original, l ergonomie est moyenne. Les boutons sont très petits , les réglages par la molette sont peu intuitif. Mais les qualités sonores sont. indéniables ,clarté .precision .dynamique ,les filtres d alimentation courant et rj45 fonctionnent à merveille au point de surclasser mon bon cd drive Musical fidelity.la connectique est plus que complete.Tidal pré-installé fonctionne parfaitement.
En résumé de telles qualités de restitution à ce prix c est à ne pas manquer.
Jan S.
Whaoo!
Now I understand the thing about R2R. The music comes alive. Well spent money to the system.
Juan C.
La musique, comme une evidence
Ce DAC Gustard est absolument parfait et indéniablement supérieur à mon ancien dac. Il offre profondeur, espace et détails et tout cela sans fatigue. La musique avec lui devient évidente.
Néanmoins, je dois ajouter quelques informations supplémentaires. Je lis la musique depuis un NAS via un pc utilisé comme streamer. Le R26 comporte un streamer intégré et permet donc de s'affranchir du pc, mais je ne suis jamais parvenu à obtenir le niveau de qualité (et la différence reste importante) que j’ai avec le pc via l’entrée USB. Cependant, et c'est important, pour obtenir cette qualité, je dois malgré tout nettoyer le signal de sortie du pc (suppresseur de bruit électrique et isolation galvanique). Avec ces moyens de filtrage, les résultats sont impressionnants, descente du grave, espace et profondeur accru, douceur et réalisme des timbres. Contrairement à ce que j’ai souvent pu lire, l'entrée USB du dac ne permet pas d’éliminer toutes les cochonneries transmises par le pc.
Avec ces modifications, ce dac Gustard chante comme jamais.
Mediocre qualité
Matériel à fuir . Il y a beaucoup mieux pour le même prix.
Arnas K.
Beautiful cable
Sound is slightly more dynamic, weighty and quieter over my Audioquest Forest.
Differences arent huge, but connectors are thing of beauty and the wire is very thick. All in all: difference is there and price is fair, im satisfied.
P.S Blue crystal is left channel and red crystyal is right?
Julien R.
Service top et très bon produit
David S.
Utilisé pour recâbler un bras REGA/Michell OEM T2.
(je ne sais pas pourquoi rega persiste à proposer des câbles un peu low-cost).
Travail méticuleux qui m’a pris tout un samedi après midi pluvieux.
À noter quel les photos d’illustrations ne sont plus trop contractuelles.
Zavphino s’est enfin décidé à remplacer leur pince crocodile pour la masse par une fourche plate beaucoup plus pratique.
Dans le pack se trouve également un fil de litz supplémentaire pour gérer la masse du bras.
J’ai utilisé l’étain à Souder FURUTECH S-070 Soudure Argent 4% 25g vendu ici pour les soudures sur des fiches CARDAS en Rhodium pour la cellule.
Avec une cellule AT33PTG/II, un son mieux défini surtout dans l’extrême grave et des micros détails supplémentaires. L’ensemble est très silencieux, presque aucun souffle et aucun son parasite.
Un rapport Q/P top, pour ceux qui ont la patience et les outils.
Ne pas oublier de commander une pâte qui va bien pour attaquer le vernis des fils de Litz avant soudure ;)
Pour ceux qui veulent se lancer dans l’aventure du recâblage d’un bras Rega, il y des informations très utiles sur le forum vinyle engine.
