Milan G.
Milan G
Milan G.
Milan G
Milan G.
Milan G
Customers reviews - There are 19620 reviews.
FURUTECH FP-TCS21 OFC (Alpha) Power Cable Ø12.8mm A very high performance 3-conductor mains cable dedicated to uncompromised audio applications, the FP-TCS21 is a high-quality, high-quality, high-end technology. This mains...
Essai validé !
Acheté pour remplacer un Elecaudio CS32 qui alimentait mon lecteur CD (MT CD One), c'est quasiment un copié-collé du commentaire précédent. Impératif : attendre au moins une cinquantaine d'heures avant de se faire une idée ++. Effectivement le maitre mot c'est précision , pleins de petits détails apparaissent , ils existaient avec l'Elecaudio mais ils étaient "noyés dans la masse" . Le Furutech donne une scène spatiale beaucoup plus précise , et beaucoup de délicatesse aux aigus. Monté avec des fiches Furutech Cu simples.
Alors si au bout d'un mois c'est encore meilleur...
Rene C.
Little upgrade, helps to lower the overall noise floor
Straight ahead, the plugs looks and fits nice.
I believe they the make a difference in the noise floor, like and together with the RCA caps I also use.
florent n.
Very impressed
I have supravox 215 RTF 64 in TQWT so good efficient speakers. I compared it to my Yamaha ca-1000 II and Monstre Hiraga 8W who are both class A amps...and I have to admit that it's on par. It's just that good. It's made all the more convenient with its analog and digital inputs. I'm really impressed independant of the price.
2 negatives:
- no balance control
- the back on/off button makes it go into standby mode instead of powering it making impossible to use a relay trigger to turn it on/off automatically
Not sure how can ncore amps improve on this. Might have to buy one just out of curiosity to compare. certainly not out of dissatisfaction. very well done
Christophe M.
SOMMERCABLE EPILOGUE OFC Copper RCA Interconnect Cable Shielded Gold Plated 0.5m (Pair) Sommercable's RCA Epilogue modulation cable has been designed to contribute to neutral and faithful sound reproduction, promoting a wide sound image thanks to excellent signal...
Bon RCA
Câble de bon rapport qualité/prix (99 €).
Rémi D.
Totalement transparent
J'ai beaucoup hésité avant d'intercaler ce commutateur entre mon ampli Ennium A 25 ou mon ampli NAD et mes enceintes Triangle Austral EZ par peur d'une perte de qualité sonore. Je ne regrette pas si il y a une différence je suis bien incapable de l'entendre. Un seul reproche en position neutre le bouton n'est pas tout à fait centré.
Christian L.
KHADAS TONE2 PRO DAC Headphone Amp ES9038Q2M 768kHz DSD512 MQA Full Decoder Black Meet the famous digital to analog conversion circuit (DAC) based on 32 bit ESS ES9038Q2M chip with PCM support up to 768 kHz and native DSD512 and even MQA. New headphone...
Commencez par oublier toutes vos références de réglages et comprenez l'appareil.
Quand c'est fait, .... profitez.
Redécouvrez vos enceintes, votre ampli, votre discothèque!
L'écoute au casque en symétrique est époustouflante avec un Meze 99.
Jean-christian C.
TOPPING SR2 HiFi Rack 3 Levels Aluminum 289x238x188mm Black / Silver The Topping SR2 HiFi rack will allow you to integrate your HiFi equipment in your living room. Entirely made of aluminum, it is particularly robust. Counterpins are also...
Petit meuble de qualité, superbe design et packaging. Très content de
mon achat. Vivement recommandé!
SABAJ A30A FDA Amplifier 2x STA516BE AX5689 Bluetooth aptX HD LDAC 2x200W 4 Ohm Sabaj unveils with the A30a a beautiful Class D integrated amplifier, capable of delivering great power while offering a rich and precise reproduction. Its connectivity makes it...
Cata en 2.1 - chauffe et se met en protection
Le son est très bon. J'en suis tout surpris venant du monde de l'analogique.
Sur le site audiosciencereview, un défaut est mis en avant et il n'est pas des moindres.
Si l'on branche un caisson de basses actif (c'est mon cas), ce dernier crachouille (bruit blanc + toc toc) et ça ... c'est pas possible. Surtout en absence de musique, le caisson bruite la pièce.
Ensuite, sur mes enceintes difficiles (Martin Logan), le Sabaj chauffe et se met en protection. Assez rapidement. Le volume va à 99, dès 80, ça coupe et franchement le niveau n'est pas si fort que ça.
Le SMSL A300, juste ampli, va beaucoup plus loin en puissance sans disjoncter.
Donc, une machine très bien pour des enceintes à bon rendement et sans utilisation de caisson.
Pas d'appli smartphone de prévu pour piloter du canapé.
Il faudra vous équiper d'une longue vue.
Pierre N.
SMSL C100 DAC AK4493S XMOS XU316 Bluetooth 5.0 32 bit 768kHz DSD512 MQA The SMSL C100 presents itself as a compact and affordable DAC, but with the same care given to the more expensive models of the brand. Its components are indeed specially...
DAC audiophile a prix mini
C’est mon troisième DAC Smsl. J’ai commencé par un Su9 couplé à un ampli casque. Puis un C200 couplé à un ampli classe D pour des enceintes bibliothèque. Et maintenant ce C100 pour la tv. Donc en gros prix 400€ / 200€ / 100€. Clairement le SU9 est beaucoup plus précis et défini. Mais le C100 a des graves impressionnants (différence puce AK versus ES ?). C’est le moins cher des Dac que j’ai trouvé avec une entrée optique, une télécommande et des composants audiophiles. Dans les inconvénients : alimentation non fournie, prévoir un chargeur USB. Alors que ses grands frères ont un câble secteur. Les aigus sont aussi moins bon mais le boîtier est plus compact. 5 étoiles pour les performances versus le prix mais selon le besoin le modèle au dessus peut être plus adapté… ou pas !
Samuel D.
Heureux avec mon TPR-2
Reçu rapidement et il fonctionne très bien dans les deux modes. J'ai du chercher un peu le bon positionnement des dip switches pour obtenir une sortie son fort et chaleureux du signal provenant de ma platine sinon très simple à installer. Le son s'est ouvert un peu depuis que je l'ai reçu. Les basses sont bien présentes et le reste aussi d'ailleurs, les voix ressortent bien. Je vais voir pour changer le stock tube 12au7 vers un n.o.s. mais le son est déjà plus ouvert qu'avec mon preamp phono précédent qui est tombé en panne. J'en profitetai pour masqué la led rouge qui sert à rien. Le plus avec cet appareil, c'est que je peux renvoyer toute mes entrées connectées à mon ampli intégré vers un autre ampli via la sortie tape out et le TPR-2 et profitez du son tube sur les deux ampli grâce à son au bouton de volume. Seul bémol, les boutons rotatif en particulier celui du sélecteur phono/line sautait les crans, j'ai remédié à ce problème en calant de petites cales de plastique entre le bouton et la tige du sélecteur.
Jakub M.
Total crap
Both Tidal Connect and Airplay options are unstable (and sometimes unusable). If I want to broadcast my audio output from MacBook via Airplay to Wiim Pro, then at first it will connect and stream audio, but after a short time the connection will break, being preceded by some kind of crack or audio distortion. Then I will not be able to reconnect. It makes Airplay totally unusable and annoying. Tidal Connect is also problematic. Despite many upgrades this device got (it upgrades itself automatically) there are still problems. I regret buying this. I thought that this will be ready out-of-the-box, stable and robust solution compared to my raspberry pi installation, but I was wrong. I do not recommend this.
FRANCOIS R.
Excellent récepteur Bluetooth pour enceintes actives.
Effectivement fixation a revoir car juste un trou, j'ai utilisé des supports TCEHCBS-8-01.
Alimentation DC séparée avec un bloc DC/DC 15v PQME1-S15-S15-S pour isolée la masse car j'avais du 15vdc disponible.
Bonne reception, pas de souffle ni de bruit.
ATTENTION:
J'utilise l’entrée analogique audio du module, comme il a déjà été mentionné si rien n'est raccordé sur cette entrée vous capterez pas mal de HF. Pour résoudre ça j'ai fabriqué des bouchons avec un résistance de 1k qui se connectent directement sur mes prises RCA d’entrée.
PS: Malheureusement je ne peux pas envoyer de photo avec cet avis
Jean-Marie L.
Le voltage exact
Bien fichu, ce voltmètre, avec son bel affichage bleu, très visible même depuis le fond du salon ! (Bon, ce n'est pas non plus la Galerie des Glaces !) Mais le point le plus important : il est exact. (Voltage secteur contrôlé simultanément avec un multimètre professionnel Chauvin-Arnoux ). Donc il vaut son prix, qui n'est pas excessif.
Nicolas A.
Pointes découplage enceintes
Utilisées comme pointes de découplage entre mes Triangle Comete 25th et le meuble sur lequel elles sont posées.
Clarifie les passages un peu fort, surtout dans les basses, qui avaient tendance à être brouillons.
Pour une stabilité optimale je n'ai installé que 3 pointes par enceinte. Du coup j'ai enlevé la bague de réglage et n'ai plus que le corps avec la pointe (fixé à l'enceinte avec l'adhésif double face fourni) et la contre pointe posée tel quel sur le meuble.
David K.
FGA-202 Stereo Line Transformer Ground Loop XLR / Jack 6.35mm This professional stereo line transformer FGA-202 effectively reduces signal interference and hum, which can occur, for example, when connecting PC sound cards to HiFi systems...
Boitier DI FGA-202
Utilisé pour isoler la sortie d'une console yamaha MG10XUF vers les deux entrées d'un splitter audio symétrique, le fonctionnement y est parfait. Pas de perte de signal, très satisfait du produit, je recommande.
Krzysztof B.
Znakomity DAC!
Tak jak pisał kolega poniżej, uzależniające granie, aż chce się słuchać. Myślę, że mój sprzęt nie wykorzystuje do końca możliwości tego DAC. Mam UR Unico Nuovo + Monitor Audio Silver 500 6G.
Christophe M.
Excellent rapport Q/P
Câble utilisé pour liaison Octavio Stream/DAC Ayon Skylla, très beau résultat qui valorise l'univers "tubes". Belle qualité de fabrication, tous les composants sont de haut niveau. Je pense investir petit à petit dans le renouvellement de mes câbles avec cette marque au très bon rapport Q/P.
Jean-Michel N.
AUDIO-GD Vacuum HE1 XLR balanced Tube Preamplifier 6H2N-EB / 6U4N-EB Audio-GD's Vacuum HE1 XLR is a 100% tube preamplifier in a full balanced achitecture. The power stage and preamp / buffer stage are exclusively constructed from vacuum tubes,...
concerne le service d'Audiophonics
Je ne peux à ce jour donner un avis,je le ferai probablement,après quelques semaines, pour que tout se mette en place.
Mais en ce qui concerne le service D'audiophonics, il est de premier ordre.
Kerem N.
Excellent!
I was using cheap china made connectors before.
I bought this brand to try and you can tell the difference at first glance even when you get the product in your hands.
I will use it with a belden brand cable that I am a fan of. Im thinking of ordering again
Benoit d.
fonctionne avec JAB2 V2
Une fois qu'on suit à la lettre dans le mode d'emploi la partie dédiée au fonctionnement avec le JAB2 V2 cela fonctionne.
Les réglages fait sur le DSP sont biens conservés sur la carte JAB2 même quand la carte ICP5 est débranchée. Je n'ai pas encore testé la qualité des filtres mais un premier essais en equaliseur 10 bandes a provoqué un bruit haute fréquence. Tout est rentré dans l'ordre en remettant les réglages par défaut, je reposterai un avis suivant ce que j'obtient en testant un peu plus les fonctions.
FRANCOIS FANELLI S.
Dimensions
Attention, ne convient pas aux transfos de 90mm de diamètre, avec la sortie des câbles du transfos ça ne passe pas ..
Didier a.
Beau boitier
C'est un très beau boitier esthétiquement et mécaniquement parlant.
Dommage que deux équerres internes ne soient pas à la bonne dimension. Heureusement, elle ne sont pas absolument nécessaires et une adaptation peut être envisagée.
Benoit d.
parfait avec JAB2 V2
parfait avec JAB2 V2, j'ai aussi apprécié qu'il y ai un voyant indiquant le fonctionnement.
Nikolaus S.
Great base for a DIY distributor
Nice surface, perfect fit. If you want to build your own distributor, this case is a good base to start.
Benoit d.
indispensable
permet une installation propre et le potar est même indispensable à mon avis (posté sur JAB2V2)
Benoit d.
WONDOM JAB2 AA-JA32171 V2 Amplifier Board Class D Bluetooth 5.0 DSP 2x50W 4Ω Wondom's JAB2 V2 is an integrated Class D amplifier module, integrating a DSP and a Bluetooth reception function (aptX HD). This version of the JAB2 V2 is capable of delivering...
très bon et installation très propre avec le kit supplémentaire
En ajoutant le kit de cablage et le support aluminium, on obtient une solution très propre, avec bouton de volume très proprement cablé pour être efficace (le volume agi après le mix des entrées bluetooth et line-in et le processing DSP et avant l'étage d'amplification). Dans ce cas la le mute automatique sur silence fonctionne très bien alors que si on n'installe pas le potentiomètre du kit et qu'on baisse trop le niveau des entrée le mute automatique se déclenche trop souvent dans les silences de la musique.
Nikolaus S.
NEOTECH NC-P303RH IEC Connector IEC Rhodium plated UP-OCC Ø24mm Fiche secteur IEC femelle très haute performance, idéal pour la constitution d'un câble secteur Audiophile sans compromis. Les contacts sont en Cuivre...
Great metal work
I own a 3m "Wireworld Electra 7" power cable, which never completely convinced me. Now I changed the OEM plugs against the NEOTECH plugs. What shall I say, big improvement. Plastics are not the same level as Furutech, but metal work seems to do a great job.
Yordan K.
NEOTECH NES-5001 Speaker Cable UP-OFC Copper 2x4mm² Ø15mm The Neotech NES-5000 series incorporates UP-OFC Ultra Pure Copper conductors while ensuring an affordable price. The NES-5001 consists of two conductors with a cross-section of...
Йордан Кузмов
Great cable, very fast delivery and very good communication with the audiophonics team.
Benoit d.
Très bon résultat
J'ai été agréablement surpris par le poids, la qualité des finitions et des matériaux. Le mode d'emploi aide à une installation facile (avec même une astuce pour localiser les obstacles invisibles avant de tout percer).
Il n'y a pas de recommandation sur le volume arrière, et j'en ai installé un dans un surmeuble de cuisine d'a peu près 100 litres et la courbe obtenue est très régulière (chute dans les graves progressive et propre vers 80 Hz comme attendu sur ce diamètre de HP). J'en ai installé un autre dans un faux plafond de salle-de-bain de gros volume (40cm de hauteur) et la par contre les graves tombent un peu trop vite et de manière chahutée entre 100 Hz et 80Hz, ce que je ne pourrai pas rattraper car la pièce est petite et en partie carrelée ce qui donne de multiples résonnances. Les 2 tweeters intégrés sont un peu trop sensibles par rapport au médium/grave : il y a une marche de plus de 5 db sur tout le spectre au dessus de 5khz, mais à l'oreille dans des locaux ou les medium sont trop présents a cause de surfaces proches en verres ou carrelage cela se passe très bien à l'oreille !
Je l'es ai alimentés avec des modules JAB2 V2 stéréo qui donnent 2x25W sur 2x8ohms et la marge de puissance est très importante même pour une pièce de 12m2. La diffusion stéréo rendue par les 2 tweeter cote à cote n'est pas très marquée ce qui n'est pas étonnant, mais cela évite le son plat du mono quand la musique est diffusée dans une seule pièce tout en se fondant très bien dans l'ensemble quand je diffuse en multi-room.
Benoit d.
très bien adapté
Contrairement à ce que peut laisser croire la description, il y a bien les 4 vis boulons pour fixer le JAB2 sur ce support, il est de plus livré bien protégé et emballé.
Wayne M.
Jantzen Z-Caps
did exactly what i wanted these to do used in crossover with fantastic results, really brought my vintage speakers alive onced more to live on
Wayne M.
Jantzen Z-Caps
Wayne M.
Jantzen Z-Caps
Peter W.
Great Unit
Good build quality. All metal with rubber feet. Even the selector knob is metal. I think though the ABCD letters above the selector should be more clear. Perhaps in red? The unit was well protected in the shipping box. Recommended!
Andrea M.
AUDIOPHONICS DA-S125NC Class D Integrated Amplifier NCore NC122MP DAC ES9038Q2M Bluetooth 2x125W 4 Ohm 32bit 768kHz DSD256 Versatile and powerful, we offer you with DA-S125NC an integrated amplifier with digital inputs to which you can add speakers to enjoy your music in the best possible way....
Great product
Purchased to pair with B&W bookshelf speakers in my bedroom system.
Fantastic DAC + ampli combination for both sound and ease of use (small footprint and clean, no frills industrial design) at a very attractive price. Connected to a DVD player and an Apple TV using coax and optical (Apple TV is also used to stream music from Qobuz app). Power is more than adequate for the room and speakers used, which never sounded so good. Highly recommended.
Very good service by Audiophinics (advice, fast shipping, support), as always.
Andreas P.
SMSL PO100AK USB Interface XMOS XU316 DAC AK4493S 32bit 768kHz DSD512 MQA The SMSL PO100AK is an extremely powerful and incredibly compact USB interface with integrated DAC. Despite its small size, the PO100AK is based on an architecture using high...
As a dac
The first impression is that it has a serious problem with the stereo cross talk;huge difference between left and right and generally not the warm sound you would expect from an asynchronus usb dac.Also do not use the included cable as it makes the problem worst.
Jean Marie L.
TOPPING E30II
Très content de ce DAC, paraît encore plus analytique que le D50s Reste que cela nécessite une très bonne source sonore, sinon mieux vaut du plus coloré...
Pour ceux qui n'ont pas besoin de BT c'est top à ce prix
L'entrée USB est bonne et en entrant en coaxial avec un DAP c'est super
En plus l'alim et la Télécommande sont identiques au D50s ce qui m'a permis de d'avoir des pièces de rechange.... Content surtout que la TLC du E30 fonctionne bien, ce qui n'est pas toujours le cas de celle du D50
Merci à Audiophonics pour la qualité de ce qu'ils proposent et sur leur sérieux
Franck P.
TRIANGLE OPERA OS100C Speaker Cable OFC Copper 2x4mm² Developed by Triangle, Opera speaker cables guarantee excellent electrical signal transmission quality. To achieve this, they incorporate braided OFC copper conductors, each...
Pierre-Marin L.
Je pars d'une barette Sopra avec filtre, le remplacement par la stealth (non filtrée) a clairement muté le son, mais je pense que la raison fondafentale en est que les Ifi AC purifier font mieux leur boulot sur une barette non filtrée, je pense aussi que mon Audio GD Master 7 Singularity préfère aussi ne pas être filtré. Bref un saut de qualité extremement important du à l'abandon de la barette filtrée, et sans doute aussi à la qualité de cette barette.
Philippe H.
Musicalité avant tout
A peine le montage sur Viborg pur cuivre terminé, installé sur mon DAC Hegel HD30 ça sonne déjà, naturel, extrêmement nuancé dans le jeu, très différencié dans les timbres … quelques jours après, la scène sonore est stabilisée, davantage profonde que large, le retour en arrière sur Zavfino Majestic est tout simplement impensable.
Guillaume B.
très très bien
Les amplis ronflent un peu trop fort par moment, j'ai donc acheté 2 DC Blocker, le bidule y marche bien, dit donc! y ronflent plus les n'amplis!! super!!
Merci à Audiophonics d'exister pour nous proposer des produits utiles et de qualités, bravo!!
Guillaume B.
Quel très bon conducteur neutre ET entier!
Choisi pour son architecture et ces matériaux, avec 2 x 7m de longueur entre des JBL 260TL(entièrement refiltrée) et les blocs mono XA-220 Advance, l'ensemble de la bande de fréquence est entendu et ressentie!
Pas de déséquilibre désagréable ou flatteur, je n'y trouve pas de défaut rédhibitoire ou légèrement gênant, la puissance et le message passent avec quiétude de la mélopée lyric au concert de boeufmetal, tout ce tiens sans bousculade, un véritable élément hifi.
Je recommande vivement!!
Pierre N.
AUDIOPHONICS TPA-M50 Class D Mono AmplifierTPA3116 1x60W 4 Ohm Black The Audiophonics TPA-M50 is a compact amplifier with a low price but very good sound performance. The TPA-M50 is based on an amplification chip TI TPA3116D2 capable of...
Deuxième nuance
J'ai changé le câble RCA vers mini jack entre le DAC et l'ampli par un câble de 0,5 m au lieu de 2 m et cela a très nettement diminué le bruit de fond.
David S.
1877PHONO FUSION PURE RCA MKII Modulation Cable PC-OCC RCA-RCA (Pair) 1.5m The Fusion cable series is the perfect integration with pure silver strands and Japanese monobrin PC-OCC copper. Designed with rigour and great precision, this Fusion series has...
très bon câble RCA
Utilisé en sortie d'un préphono, la liaison vers l'amplificateur est à mon avis primordiale. Câble neutre, transparent et détaillé, sans perte d'énergie, avec beaucoup plus de définition dans les graves que mon câble précédent.
Excellent rapport Qualité/Prix, la rigueur de fabrication se retrouve à l'écoute, sans tomber dans une tranche de prix délirante.
Julien R.
SOVTEK 12AX7LPS Twin Triode Tube (Unit) This Sovtek 12AX7LPS dual triode tube is a dual triode offering high linearity, making it an excellent replacement for a 12AX7 tube.
Un bon tube avec une tonalité linéaire et précise.
Vincent D.
WONDOM JAB5 AA-JA33286 Amplifier Module Class D Bluetooth 5.0 DSP ADAU1701 4x100W 6 Ohm The JAB5 is an integrated 4-channel audio amplifier board with Bluetooth 5.0 (aptX HD support) and DSP ADAU1701, offering a true all-in-one audio solution. It delivers 4x100W of...
Very powerfull amplifier!
This is a very good and powerfull amplifier. The integrated DSP allows you to tune your speaker very nicely. For programming the DSP please use SigmaStudio and not their own Miumax software. The Miumax software cannot write the config to the amplifier itself but only store it in the ICP5 programming module. So you have to keep it connected which causes a very loud pop when you turn on the amplifier and causes crackling/popping noises at a louder volumes.
If you use Sigmastudio, you can write the config to the amplifier so it will be saved if you turn off the amplifier.
The amplifier itself is build very nicely. I can't hear any hissing noise when it is turned on! It also does not give a feedback signal when you connect to it via bluetooth or power on the amplifier. For me this is a good thing, since i don't like the feedback tones and voices that most chinese amplifiers have.
Overall, for the money this is a very good amplifier board with a lot of functionalities!
Ken P.
Absolute reliability
My dealings with audiopnoics: Australia to France, have been reliable in every way possible, Thanks.
Lubos S.
HoloAudio Spring 3 level3
So this is the second best DAC I've heard. The first is an order of magnitude more expensive MSB.
This thing plays way better than my own Accuphase DP750.
And I really didn't expect that.
It excels with HQPlayer on DSD 256-512 via USB, but is also excellent on 44.1/16 via coax.
It is good to play Holoaudio for a few days, the sound improves.
FURUTECH Alpha-S14 Speaker Cable µ-OCC Copper Alpha Treatment 2x2mm² Ø8.9mm This FURUTECH Alpha S14 speaker cable in multi-strand OCC copper with Alpha treatment (anti-magnetic, cryogenic) is an elegant solution. Here's a simple, effective loudspeaker...
Je laisse mon avis pour confirmer l'avis précédent. Sa section de 2mm ne l'empêche pas de délivrer un message plein avec une belle scène, riche en timbres, détaillé, et avec une belle dynamique jamais fatigante. Dommage qu'il soit si cher ici, je l'ai trouvé à 2 fois moins cher mais je vous le recommande.
GILLES G.
Nette amélioration de la qualité sonore
Envoi rapide et soigné. La qualité sonore de mon système (Atoll DAC200 Signature et IN200 Signature + JM Reynaud Cantabile Jubilée) a été nettement améliorée. Meilleure présence des basses, ainsi que plus de clarté et de détails dans l'ensemble du spectre sonore. Je recommande fortement cet investissement.
