IAN CANADA TRANSFORMER I/V PCB Output Stage Kit for Lundahl LL1544A
Transformer I/V PCB mini KIT
Reference : 13978
24,90 €tax incl.
20,75 € tax excl.
Shipping from France
Billing in France
Technical support in France
This product has been replaced by the new version, the IAN CANADA TRANSFORMER PCB Kit V2 output circuit.
Ian Canada kit Transformer I/V
Output Stage module for audio transformer kit
This kit from Ian Canada allows you to mount your own output stage for ES9038Q2MPi and Es9028Q2MPi DAC. Its input connection is in fact based on a XH (2.54mm) 2x5 connector.With suitable connector it may also be mounted on any  digital / analog conversion stage devoid of output stage.
It consists of a single PCB with two slots for accommodating the pair of audio transformers Lundahl LL1544A.
The connectors and other electronic components (resistors) are supplied by default with the kit and must be installed by the user. This arrangement requires a soldering iron and some knowledge in electronics.
On the PCB one can find two pairs of pads for installing additionnal capacitors. This step is optional and the capacity of capacitors is to be determined by trying and testing.
Dimensions & distances
TypeOutput stage module
InputIn analog stereo (2x5 Pin XH2.54)
OutputsBalanced Stereo XLR
Stereo Unbalanced RCA
Supported audio transformerLundahl LL1544A (non-included)
Package Contents
PCBx1
Dale resistors CMF60 510Ω 1%x2
2x5 PCB Connector (XH 2.54mm)x1
XLR PCB Connectorx2
RCA PCB Connectorx2
