RASPBERRY PI PICO 2 W
The Raspberry Pi Pico 2 W is a microcontroller board designed for embedded integration, built around the RP2350 chip developed by Raspberry Pi in the United Kingdom. It combines two ARM Cortex-M33 cores clocked at 150 MHz, 520 kB of SRAM, and 4 MB of flash memory to provide deterministic I/O processing in a compact, energy-efficient form factor. In addition to this hardware base, it features integrated Wi-Fi connectivity, allowing embedded projects to be extended to include monitoring, updating, or data exchange functions without the need for external modules.
Reference : 21556
9,90 €tax incl.
8,25 € tax excl.
Shipping date: 25-11-2026.
Raspberry Pi Pico 2 W 520kB SRAM WiFi Bluetooth 5.2
Raspberry Pi Pico 2 W : Front view
The Raspberry Pi Pico 2 W is a microcontroller board designed for embedded integration, built around the RP2350 chip developed by Raspberry Pi in the United Kingdom. It combines two ARM Cortex-M33 cores clocked at 150 MHz, 520kB of SRAM, and 4MB of flash memory to provide deterministic I/O processing in a compact, energy-efficient form factor. In addition to this hardware base, it features integrated Wi-Fi connectivity, allowing embedded projects to be extended to include monitoring, updating, or data exchange functions without the need for external modules.
Beyond improved performance, the RP2350 introduces a dual-core, dual-environment architecture, allowing the choice between a pair of ARM Cortex-M33 cores or a pair of open-hardware cores, enabling the microcontroller's behavior to be precisely adapted to project constraints. Programmable in C/C++ and MicroPython, the Pico 2 W facilitates iterative development while maintaining direct access to digital interfaces: an asset for controlling sensors, actuators, or specialized buses, while maintaining controlled latency.
This specialization extends to security: the integration of TrustZone for Cortex-M, signed boot, 8kB of anti-tamper OTP for key storage, as well as SHA-256 hardware acceleration and a hardware random number generator, provide a reliable foundation for connected applications.
Raspberry Pi Pico 2 W: The perfect candidate for a DIY DSP
This onboard orientation naturally extends to specialized audio applications. The Pico 2 W can be used as the hardware basis for a DIY DSP project such as DSPi, firmware that transforms the card into a USB audio interface with a real-time digital processing engine. In this configuration, the microcontroller provides multi-band parametric equalization, active filtering for multi-channel systems, speaker time alignment, and subwoofer management via PDM output, while distributing the computational load across both cores to maintain low latency.
DSPi interface
Beyond simple processing, this approach leverages multiple S/PDIF outputs and flexible GPIO assignment to directly drive external DACs or design a complete active architecture, while the Pico 2 W's Wi-Fi connectivity paves the way for remote monitoring or control. The result is a compact platform capable of serving as a dedicated audio processor in a DIY system, without the need for a permanently running computer.
DPSi GitHub
Product typeMicrocontroller (MCU)
ProcessorDual Arm Cortex-M33
Dual RISC-V Hazard3
RAM memory520kB SRAM
ConnectorsUSB-C
GPIO 26 pins
NetworksWifi 2.4GHz 802.11n
Bluetooth 5.2
Internal controller2x UART
2x SPI
2x I2C
2x UART
3x ADC 12 bits
16x PWM channels
Storage4MB QSPI Flash
Operating temperature-20°C - +85°C
Mean time between failures (MTBF)182 000 hours
Dimensions21 x 51.3 x 3.9mm
Weight3g
PackageSold by unit
RASPBERRY PI PICO 2 W 520kB SRAM WiFi Bluetooth 5.2
The Raspberry Pi Pico 2 W is a microcontroller board designed for embedded integration, built around the RP2350 chip developed by Raspberry Pi in...
