FURUTECH FP-908 (R) PCB RCA inlets Rhodium plated Pure Copper (Pair)
By buying this product you get 20 loyalty points
Reference : 10417
109,00 €tax incl.
90,83 € tax excl.
These Furutech bases in pure copper machined in the mass and Rhodium plated offer an exceptional level of conductivity.
The vast majority of audio connectors are made from brass or bronze / phosphor alloy with a conductivity typically less than 28% IACS (International Annealed Copper Standard).
By way of comparison, the high purity copper (OFC) used in most interconnection cables at a conductivity rate of 100% IACS.
EBecause of the use of these "low" conductivity alloys, the majority of even expensive RCA sockets tend to decrease the performance of the cables to which they connect.
Features:/ Strong>
  • Contacts in pure copper treated Alpha machined in the mass
  • Rhodium plated
  • Insulation: Nylon + fiberglass
  • Welding
  • Application: PCB / printed circuit board
  • Max. Diameter of the base: 17 mm
  • Length of the base: 34.5 mm
  • Height: 21.1 mm
Mounting typeTo weld
Max panel thickness (mm)3.5
