Refurbished product - Grade A
Slight trace of tightening on the screws.
This IEC Furutech DI-11 connector uses the manufacturer's patented alpha cryogenic process and also demagnetizes the contact pins. This is a reference product at Furutech. Thus, adding this high-quality copper IEC plug to the power cable of your hi-fi system will improve sound reproduction for a limited expense. In addition, it allows thick cables to be easily installed.
| Max cable diameter (mm) | 18.0 |
| Mounting type | To screw |
| Connectic | Female |
| Connector | IEC C15 |
| Contacts Material (Connector) | Copper Alloy |
| Contacts Plating (Connector) | Gold |
| Rated current (A) | 10.0 |
| Refurbished Grade | Grade A |
