1.5m long pre-cut cable
Refurbished product - Grade S
Cable offcut with a length of 1.5m
Shielded UP-OCC Silver Interconnect Cable Ø10mm
The NEMOI series from the manufacturer Neotech is the result of extensive research in the field of audio cable. The Neotech NEMOI-1220 modulation cable, combining PTFE insulation and UP-OCC Silver conductors with rectangular cross-section, has a special architecture that significantly reduces the inductance and capacitance effect.
If you are looking for a very high quality modulation cable with a flawless design, the Neotech NEMOI-1220 is for you. The result is surprising, combining with listening often contradictory qualities such as sitting in the bass and a readable, natural sound scene with high definition in the medium, without auditory fatigue.
| Specifications | ||
| Product type | Interconnect cable | |
| Matériau conducteurs | Cross-Section UP-OCC Silver | |
| Number of conductors | 2 | |
| Conductors section | 0.33mm² | |
| Shielding | Copper-Mylar Foil + Braided Copper | |
| Insulation | PTFE + PE + PVC + Cotton | |
| External sheath | PE + PVC | |
| Resistance | 0.054 Ohm/m | |
| Capacity | 38.19pF/m | |
| Inductance | 0.86µH/m | |
| External diameter | 10mm | |
| Color | Blue | |
| Length | 1.5m | |
| Diameter (mm) | 10.0 |
| Length (m) | 1.0 |
| Insulation material | PTFE |
| Insulation material | PVC |
| Insulation material | PE |
| Shielding | Yes |
| Section (mm²) | 0.33 |
| Conductors material (Cable) | Silver |
| Conductors Plating (Cable) | None |
| Refurbished Grade | Grade S |
| Ground / Shielding | Yes |
