[GRADE S] FURUTECH FP-S022N Power Cord Cable OFC Copper (Alpha) Ø12.9mm 95cm
-31%
Refurbished product - Grade S
95cm long pre-cut cable
Reduced price!
Reference : 22792
71,25 €tax incl.
-31%
49,00 €tax incl.
40,83 € tax excl.
Last items in stock !
Shipping date: 01-12-2026.
Cable offcut with a length of 95cm
A very high-performance 3-conductor power cable designed for uncompromising audio applications, the FP-S022N demonstrates a level of craftsmanship and technical sophistication that leaves no doubt as to the high-end positioning Furutech intends for it.
Each conductor consists of a central core comprising 1 bundle of 37 strands of Alpha α OFC copper with a diameter of 0.26 mm and 2 bundles of 37 strands of silver-plated copper.
Each of these bundles is individually insulated within a polyethylene sheath with a diameter of 3.4 mm.
The assembly is then provided with dual protection consisting of a 12-mm PVC inner jacket and a braided copper shield. This braided shield consists of 9x24 strands of 0.12-mm Alpha α-type conductors.
As is customary with this manufacturer, all metals have undergone the proprietary Alpha α anti-magnetism process, which consists of two steps:
1 - Cryogenically treating metals at -250°C using liquid nitrogen, in order to strengthen their molecular structure and significantly improve their conductivity.
2 - Exposing these same metals to a powerful magnetic field created by magnets arranged in rings, the strength of which is continuously monitored to ensure that no magnetic residue remains at the end of the treatment.
This second stage, developed in collaboration with the Japanese firm SEKIGUCHI MACHINE SALES, helps make FURUTECH cables exceptional signal carriers for any electrical signal used in audio reproduction.
Specifications:
  • Very High-Performance 3-Conductor Power Cable.
  • 3 Conductors, Each with a Cross-Sectional Area of 1.93 mm², Consisting of a Total of 3 x 37 μ–OFC (Alpha) Copper Strands.
  • Polyethylene insulation, 3.5 mm in diameter.
  • High-flexibility black PVC inner jacket.
  • Total cable diameter: 12.9 mm.
  • High-strength midnight blue (dark blue) PVC outer jacket.
  • Color code: Brown = Phase / Blue = Neutral / Green with yellow stripe = Ground.
  • Length: 95cm
Diameter (mm)12.9
Length (m)0.95
Number of conductors3
Insulation materialPE
ShieldingYes
Section (mm²)1.93
ConnectorN/A
Refurbished GradeGrade S
Ground / ShieldingYes
Refurbished product - Grade S 95cm long pre-cut cable
