80cm long pre-cut cable
Refurbished product - Grade S
Cable offcut with a length of 80cm
Neotech's NEP-3003G is a power cable incorporating 3 G-UPOCC composite conductors, a combination of OCC copper and graphene. This new conductor marks a significant advance, both in terms of research and industrial applications. The addition of graphene makes it possible to improve the stability of electrical signal transmission at high temperatures while preserving the exceptional conductivity of OCC copper, enabling performance to remain intact, even at high voltages.
The conductors have CL3 PVC insulation, preventing any transmission of electrical discharge created by the double Mylar/aluminium shielding and braided tinned copper. The whole assembly is encased in a robust, flexible PVC sheath.
| Specifications | |
| Product type | Power cable |
| Number of conductors | 3 |
| Conductors material | Copper with graphene G-UPOCC |
| Cable diameter | Ø12mm |
| Insulation material | PVC CL3 |
| Cross section | 3 x 2.5mm² / 13 AWG |
| Shielding | Aluminised Mylar Braided tinned copper |
| General | |
| Color | Silver |
| Length | 80cm |
| Diameter (mm) | 12.0 |
| Length (m) | 0.8 |
| Insulation material | PVC |
| Shielding | Yes |
| Section (mm²) | 2.5 |
| Conductors material (Cable) | Graphene |
| Conductors Plating (Cable) | None |
| Refurbished Grade | Grade S |
| Ground / Shielding | Yes |
