[GRADE S] RAMM AUDIO AMADEUS 5 MK2 Speaker Cable OCC Copper 6x1.5mm² Ø16mm 95cm
-30%
Refurbished product - Grade S
95cm long pre-cut cable
Reduced price!
Reference : 22781
75,05 €tax incl.
-30%
52,90 €tax incl.
44,08 € tax excl.
Last items in stock !
Shipping date: 01-12-2026.
Cable offcut with a length of 95cm
RAMM Amadeus 5 Mk2
ramm-audio-amadeus-5-mk2-cable-hp-cuivre
Designed according to extremely strict specifications, the Amadeus 5 Mk2 cable is dedicated to wiring (& bi-wiring) loudspeakers and to power cables.
This speaker cable / power offers superior performance thanks to the use of materials and manufacturing methods that are rare in this price range.
The conductors are six core pure copper OCC and its insulating structure (Air Geometry Design) uses air with a pattern designed by the mark itself.
Structure%20c%C3%A2ble%20AMADEUS%205%20M
The connectors are arranged so that the wiring of your devices according can be "tuned" according to their strengths and their weaknesses. One can dedicate 2x2 conductors to the positive and 2x1 conductor to the negative to obtain a rich and balanced sound stage in a bi-wiring context. Conversely, less symmetrical arrangements may also be made for filter / crossover.
In addition to the six main strands of 16AWG there is a seventhdriver designed to connect the mass and thus avoid most noise.
Definitely audiophile, Amadeus cable 5 Mk2 offers pure performance through high quality multiple conductors and a protective screen shield Aluminum / PP / PVC.
All conditions are met for optimal resistance to interference with minimal distortion.
Bi-wiring amplifier
Amadeus 5 wiring diagram
Wiring for AC outlet
Amadeus 5 wiring diagram sector
Length95cm
ConductorsPure copper OCC 11AWG (4.17mm²)
Cores6 cores made from 6x7 conductors
InsulatingDesigned by Ramm / air geometrical structure and polypropylene
Diameter per conductorApprox. 2mm
Total Diamtètre16mm
Common useSpeaker câble / Double speaker cables / power cable
PVC bodyBraided Nylon & PVC Body Blue
Diameter (mm)16.0
Length (m)0.95
Number of conductors6
Insulation materialPE
ShieldingYes
Section (mm²)1.5
Refurbished GradeGrade S
Ground / ShieldingYes
