1.7m long pre-cut cable
Refurbished product - Grade S
Cable offcut with a length of 1.7m
Neotech's NEP range consists of high-end power cables using only the purest UP-OCC copper conductors. The NEP-3200G is no exception, with 16 Graphene + UP-OCC Copper conductors with a total cross-section of 9AWG (6.63mm²). The 16 17AWG (1.5mm diameter) conductors are individually sheathed, insulated and shielded with PTFE and Mylar-Aluminium.
This cable is particularly effective for high-current amplifiers, power strips or line conditioners. This cable, sold by the meter, will enable you to design very high-quality power cables, and is also perfectly suited to carrying high currents for demanding HiFi systems. In addition, the excellent transmission quality of the electrical signal enables these cables to deliver excellent sound reproduction with enhanced dynamics.
| Specifications | |
| Product type | Power cable |
| Number of conductors | 16 |
| Conductor material | G-UPOCC copper (Graphene + UPOCC) |
| Conductor cross-section | 9AWG (6.63mm²) |
| External diameter | Ø15.6mm |
| Insulation | Teflon + Mylar- Aluminum |
| External sheat | PVC |
| General | |
| Color | Night blue |
| Length | 1.7m |
| Diameter (mm) | 15.6 |
| Length (m) | 1.7 |
| Insulation material | PTFE |
| Insulation material | PVC |
| Insulation material | Al-Mylar |
| Shielding | Yes |
| Section (mm²) | 6.63 |
| Conductors material (Cable) | Graphene |
| Conductors Plating (Cable) | None |
| Refurbished Grade | Grade S |
| Ground / Shielding | Yes |
