55cm long pre-cut cable
Refurbished product - Grade S
Cable offcut with a length of 55cm
Interconnect Cable Pure Silver Shielded PTFE Ø11mm 55cm
The Neotech NEI-2001 cable consists of 3 pure silver conductors with shielding. It is perfectly suited for the design of high-end, high-performance XLR or RCA cables. Each of these conductors is composed of 3 silver wires and 4 PTFE wires, all covered with another PTFE sheath for a diameter of 2.65mm. Each silver strand has a different diameter and cross-section: 0.4mm 26AWG, 0.51mm 24AWG and 0.65mm 22AWG. The 3 conductors are placed in a PP filling. Around this filling, a shield composed of an Aluminium-Mylar sheet considerably reduces EMI/RFI interference and can be welded simply with a 0.57mm diameter wire with a 23AWG cross-section. Finally, a thick 2mm PVC sheath and a braided sheath finish this cable with a total outside diameter of 11mm.
| Specifications | ||
| Product type | Interconnect cable | |
| Conductors material | Pure silver | |
| Number of conductors | 3 | |
| Conductor composition | 4x PTFE strands 1x Silver strand 0.129mm² 1x Silver strand 0.205mm² 1x Silver strand 0.258mm² | |
| Conductors insulation material | PTFE | |
| Shielding material | Aluminium-Mylar Foil | |
| Filling material | PP | |
| External sheaths | PVC sheath + Braided sheath | |
| Total external diameter | 11mm | |
| Color | Black | |
| Length | 55cm | |
| Diameter (mm) | 11.0 |
| Length (m) | 0.5 |
| Insulation material | PTFE |
| Shielding | Yes |
| Section (mm²) | 0.129 |
| Section (mm²) | 0.205 |
| Section (mm²) | 0.258 |
| Conductors material (Cable) | Silver |
| Conductors Plating (Cable) | None |
| Refurbished Grade | Grade S |
| Ground / Shielding | Yes |
