[GRADE B] VIBORG VE502 Schuko Type E/F Power Connector Pure Copper Ø20mm
Refurbished product - Grade B
This Schuko Viborg VE502G male power connector is ideal for creating quality power cables. It uses pure copper contacts to obtain a very good conductivity and therefore a cleaner transmitted signal.
Reference : 18868
Refurbished
59,90 €tax incl.
49,91 € tax excl.
Scratched ground contact.
Viborg VE502
Schuko Power Connector Pure Copper Ø 20mm
Viborg VE502 Connecteur secteur Schuko Cuivre Pur Ø 20mm
This Schuko Viborg VE502G male power connector is ideal for creating quality power cables. It uses pure copper contacts to obtain a very good conductivity and therefore a cleaner transmitted signal. In addition, this connector is able to accommodate cables up to 20mm in diameter and will therefore be suitable for both "classic" cables and HiFi cables with a larger diameter. Finally, the connector is covered with an Aluminium alloy body. This allows both to offer the connector a beautiful design but above all to limit EMI / RFI interference that could damage the signal and therefore audio reproduction.
Connector typeMale Schuko
Contacts materialPure copper
Voltage / Current250V AC / 16A
Maximum accepted cable diameterØ 20mm
Max. conductor diameter / cross-section4mm / 12,5mm²
Dimensions98.6 x 40mm
ScrewHexa / Phillips
ColorSilver
Max cable diameter (mm)20.0
Mounting typeTo screw
ConnecticMale
ConnectorPLug CEE 7/7
Rated current (A)16.0
Refurbished GradeGrade B
Refurbished product - Grade B This Schuko Viborg VE502G male power connector is ideal for creating quality power cables. It uses pure copper...
