Refurbished product - Grade A
Damaged / torn cardboard box. Product in perfect condition.
This Dayton Audio BST-1 exciter transmits the vibrations of the low frequencies to any supports on which they will be fixed. it will multiply tenfold the immersion of films with great spectacle. Under your sofa, your armchair, the Bass Shaker BST-1 is an indispensable accessory for any home theater lover and blockbusters.
The Dayton Audio BST-1 will also be effective for video games and simulators. Several "Bass Shaker BST1" can be connected in parallel or series depending on the desired impedance.
Warning: Do not exceed 50 W RMS on 4 Ohm by BASS SHAKER multiplied by the number of Shaker: 50 x 4 = 200w RMS.
For a Bass Shaker, Class D amplifiers are ideal for increasing performance in a compact format.
Features:/ Strong>
| Speaker Power (W RMS) | 50.0 |
| Speaker Type | Exciter |
| Impedance (Ω) | 4 |
| Loudspeaker diameter (mm) | 147.0 |
| Diaphragm type | N/A |
| Efficiency / Sensitivity (dB) | N/A |
| Max Linear Excursion (Xmax) (mm) | N/A |
| Lowest frequency (Hz) | N/A |
| Highest frequency (Hz) | 80 |
| Refurbished Grade | Grade A |
