Refurbished Product - Grade A
Torn cardboard box
Dayton Audio's Design Series has been designed to give loudspeaker designers access to high-quality drivers. Featuring a cast aluminum frame, an anodized aluminum cone and polyimide coating, they can deliver a wide range with incredibly low distortion.
The smooth, extended frequency response of this Dayton Audio loudspeaker guarantees accurate reproduction of the entire audio spectrum, from the lowest notes to the highest frequencies. This well-balanced frequency response delivers a natural, immersive listening experience, allowing you to hear every detail and nuance of your favorite music or movies.
The speaker's design, materials and meticulous engineering work in harmony to minimize distortion, ensuring crisp, clear sound even at high volumes. By achieving low distortion, this speaker provides an accurate representation of the original audio signal, enabling audiophiles to enjoy a truer-to-nature listening experience, with exceptional clarity and precision. It is also subjected to rigorous Klippel testing throughout the design process, a state-of-the-art analysis method that achieves optimal performance, consistency and reliability by precisely measuring and optimizing the speaker's mechanical magnetic properties.
Thanks to the innovative use of an aluminum ring, this loudspeaker delivers unrivalled audio performance. This Faraday ring, precisely positioned around the speaker's pole piece, not only stabilizes the magnetic field, but also significantly reduces distortion for perfectly coherent sound.
Diffraction caused by the abrupt edge of the suspension is minimized by the use of an indexed junction. This feature creates a smooth transition between diaphragm and suspension, which improves frequency response, while enhancing diaphragm rigidity, thus reducing distortion at high excursion.
Copper-clad aluminum wire (CCA) reduces moving mass, improving overall sound quality and driver efficiency. A raised spider and vented design increase airflow to the voice coil, keeping the whole unit cool during long periods of use.
The aluminum construction of the diaphragm is light, rigid and reduces distortion, contributing to more accurate sound reproduction. The anodization processus is optimized to contribute to diaphragm damping, while giving the loudspeaker a modern aesthetic.
The cast aluminum frame isolates diaphragm movement, enhancing low-frequency performance and providing additional heat dissipation. The stainless steel badge completes the speaker's sleek aesthetic.
| Specifications | |
| Speaker driver type | Woofer Midbass |
| Nominal diameter | Ø165.1mm (6-1/2") |
| Output power | RMS : 80W Max : 160W |
| Impedance | 4Ω |
| Frequency response | 40Hz - 4000Hz |
| Sensitivity | 91dB @ 2.83V/1m |
| Voice coil diameter | Ø31.75mm (1.25") |
| Weight | 1.63kg |
| Total outer dimensions | Ø180*86.3mm |
| Magnet weight | - |
| Thiele-Small parameters | |
| Resonant Frequency (fS) | 40.5Hz |
| DC resistance (RE) | 3.7Ω |
| Voice coil inductance (LE) | 0.47mH |
| Mechanical Q (QMS) | 5.19 |
| Electromagnetic Q (QES) | 0.41 |
| Total Q (QTS) | 0.38 |
| Compliance Equivalent Volume (VAS) | 23.22L (0.82ft³) |
| Mechanical Compliance of Suspension (CMS) | 0.81mm/N |
| Force factor(B·l) | 6.6T·m |
| Mechanical resistance (RMS) | - |
| Moving mass + airload (MMS) | 19.2g |
| Moving mass (MMD) | - |
| Max linear excursion (XMAX) | 5mm |
| Volume of air displaced at Xmax (VD) | - |
| Efficiency (η₀) | - |
| Bandwidth efficiency (EBP) | - |
| Surface area of cone (SD) | 143cm² |
| Materials | |
| Cone | Aluminum |
| Surround | Rubber |
| Voice coil wire | - |
| Voice coil former | Kapton® / Polyimide |
| Frame | Cast aluminum |
| Magnet | - |
| Mounting informations | |
| Outer diameter | Ø180.34mm (7.1") |
| Cutout diameter | Ø144.78mm (5.7") |
| Depth | 86.11mm (3.39") |
| Bolt circle diameter | - |
| Number of mounting holes | 6 |
| Optimum cabinet size | |
| Sealed volume | 9.91L (0.35ft³) |
| Sealed F3 | 75Hz |
| Vented volume | 19.08L (0.674ft³) |
| Vented F3 | 41Hz |
| Speaker Power (W RMS) | 80.0 |
| Speaker Type | Woofer |
| Speaker Type | Midbass |
| Impedance (Ω) | 4 |
| Loudspeaker diameter (mm) | 165.0 |
| Diaphragm type | Aluminium |
| Efficiency / Sensitivity (dB) | 91.0 |
| Max Linear Excursion (Xmax) (mm) | 5.0 |
| Lowest frequency (Hz) | 40 |
| Highest frequency (Hz) | 4000 |
