The Topping B4XM-150 is a balanced 4.4mm TRRRS jack male to dual XLR male interconnect cable designed to connect an audiophile digital audio player, DAC, or headphone amplifier featuring a balanced 4.4mm output to an amplifier, DAC, or active speakers equipped with XLR inputs. Measuring 150cm in length, it features OFC (Oxygen-Free Copper) conductors combined with highly effective shielding to ensure balanced signal transmission with extremely low noise and interference. Its connectors feature gold-plated contacts for excellent electrical conductivity and outstanding resistance to oxidation, while their robust construction ensures excellent durability. The flexible outer jacket makes installation easy while reducing mechanical stress during use. The Topping B4XM-150 is therefore an ideal solution for taking full advantage of the performance of a balanced audio connection between a portable or desktop source and a HiFi or studio system.
Technical Specifications
| Specifications | |
| Product type | Balanced interconnect cable |
| Connectors | 1x 4.4mm balanced jack 2x balanced XLR |
| Connector contact material | Gold plated copper |
| Cable conductor | OFC copper |
| Conductor cross-section | 0.23mm² / 24AWG |
| Cable diameter | 3.5mm |
| Shielding | Aluminum foil and copper braid |
| Length | 150cm |
| General | |
| Package contents | 1x Topping B4XM-150 |
| Length (m) | 1.5 |
| Shielding | Yes |
| Section (mm²) | 0.23 |
| Connector | XLR |
| Connector | Jack 4.4mm |
| Conductors Plating (Cable) | None |
