2.8m long pre-cut cable
Refurbished product - Grade S
Cable offcut with a length of 2.8m
Neotech's NES-3001G is a speaker cable incorporating 16 G-UPOCC composite conductors, a combination of OCC copper and graphene, with a total cross-section of 8.3mm² (8AWG). This new conductor marks a significant advance, both in terms of research and industrial applications. The addition of graphene improves the stability of electrical signal transmission at high temperatures, while preserving the exceptional conductivity of OCC copper, so that performance remains intact, even at high voltages.
A multimeter in continuity test mode is required to assemble the cable:
Positive: 6x Red wire + 2x Transparent wire
Negative: 6x Blue wire + 2x Transparent wire
| Specifications | |
| Product type | Speaker cable |
| Number of conductors | 16 |
| Conductors material | Graphene copper G-UPOCC |
| Total section | 8.3mm² |
| External diameter | Ø15mm |
| Internal sheath | PVC |
| Conductors insulation | PTFE |
| External sleeve | Braided nylon |
| General | |
| Color | Black and White |
| Length | 2.8m |
| Diameter (mm) | 15.0 |
| Length (m) | 2.7 |
| Insulation material | PTFE |
| Shielding | No |
| Section (mm²) | 8.30 |
| Conductors material (Cable) | Graphene |
| Conductors Plating (Cable) | None |
| Refurbished Grade | Grade S |
| Ground / Shielding | No |
