Refurbished product - Grade A
Product in perfect condition. Torn / damaged cardboard box.
Streamer WiFi Bluetooth aptX HD LDAC 32bit 768kHz DSD512 Black
The S10N represents the next generation of Aune streamer, adopting an architecture based on five core: NXP Freescale™ processor, MediaTek™ WiFi streamer, LDAC / aptX HD Bluetooth receiver, PLL clock and asynchronous FPGA. A quality structure perfectly optimized to deliver high fidelity sound reproduction, both locally and wirelessly. And if the performance is there, the S10N is not left behind on the functionality side and will meet the vast majority of needs.
As a central element of this Aune S10N, the section in charge of WiFi network playback uses a MediaTek™ controller. This one allows a stable and fast broadcast of the audio stream. The S10N is also extremely easy to control remotely using the free iEast mobile app, available on both Android and iOS. The latter allows easy interaction with your device, via an ergonomic and intuitive graphical interface.
The S10N is powered by a powerful ARM Cortex-M7 processor, ensuring fast and reliable data processing but also in charge of hardware decoding of audio streams. It allows the reading of high resolution files, up to PCM 32bit 768kHz and DSD512, ensuring a formidable sound precision.
In addition to its WiFi network connectivity, the Aune S10N is equipped with a Bluetooth 5.0 receiver. It incorporates a Qualcomm QCC5125 chip for high-quality wireless audio transmission, including support for aptX, aptX HD and LDAC codecs.
The S10N's complex PLL clock provides a highly accurate signal. This signal is then fed to the asynchronous FPGA to generate ultra-low jitter digital signals for the most transparent and faithful sound possible. The S10N also allows the use of an external clock through its 10M input.
After decoding the audio stream, the ARM processor passes the signal to the FPGA and its oscillators. The FPGA then uses its own algorithm to regenerate the digital signals with extremely low jitter and provide a signal of absolute precision.
Pour fournir un signal électrique propre et stable à ses différents circuits, l'Aune S10N s'appuie sur un étage d'alimentation avec deux transformateurs à faible bruit et des régulateurs de tension à faible ondulation.
A network player but also a file player, the Aune S10N offers two USB-A ports to connect USB storage devices up to 2TB (not included). An additional way to access your music for maximum versatility.
1 | Previous |
2 | Play/Pause/OK |
3 | Next |
4 | IR receiver |
5 | Screen |
6 | ON/OFF LED indicator |
7 | 10M clock input |
8 | Coaxial output |
9 | Bluetooth antenna |
10 | WiFi antenna |
11 | Balanced XLR output |
12 | Single-ended RCA output |
13 | I2S HDMI output |
14 | AES/EBU output |
15 | Optical Toslink output |
16 | USB-A inputs |
17 | Power button |
18 | Power input |
Product type | Streamer |
Inputs | Bluetooth 5.0 WiFi 2.4G 2* USB-A 1* 10M clock input on BNC connector |
Outputs | 1* Balanced stereo XLR 1* Single-ended stereo RCA 1* I2S via HDMI 1* AES/EBU 1* Coaxial 1* Optical Toslink |
Connectivity | WiFi 2.4G Bluetooth 5.0 |
Supported sampling rates | I2S / RCA: PCM up to 32bit 768kHz, DSD up to DSD512 Coaxial / AES: PCM up to 32bit 384kHz, DSD DoP up to DSD128 Optial: PCM up to 24bit 192kHz, DSD DoP up to DSD64 |
THD+N (digital output) | -147.6dB |
Jitter (digital output) | 181ps (700Hz-100kHz) |
Frequency response (analog output) | 20Hz-20kHz ±0.5dB |
Output level (analog output) | 4.39µV |
Noise floor (analog output) | 0.00068% |
Supported Bluetooth codecs | SBC, AAC, aptX, aptX HD, LDAC |
Dimensions | 288*211*63mm |
Color | Black |
Input | USB |
Input | WiFi |
Input | Bluetooth |
Output | XLR |
Output | I2S |
Output | RCA |
Output | Coaxial SPDIF |
Output | AES/EBU |
Output | Optical Toslink |
DAC / ADC Chip | NC |
Max sampling rate | 768kHz |
Max sampling rate | DSD512 |
Color | Black |
Streaming services & Network protocols | Deezer |
Streaming services & Network protocols | Tidal |
Streaming services & Network protocols | Web radios |
Streaming services & Network protocols | Spotify |
Streaming services & Network protocols | Qobuz |
Streaming services & Network protocols | Amazon Music |
Streaming services & Network protocols | DLNA |
Refurbished Grade | Grade A |
