By buying this product you get 129 loyalty points
Refurbished product - Grade S
Product in perfect condition. Packaging box damaged.
Eversolo presents with its DMP-A6 MASTER EDITION a streamer as powerful as it is intuitive and stylish. It will allow you to stream your music with ease while enjoying excellent sound quality, all controlled via a high-quality LCD screen and an ergonomic interface or from a dedicated mobile application.
DMP-A6
Appearence
Some gold details on the case
Silver
Clock System
2 ACCUSILICON FEMTOSECOND oscillators with noise reduction and improved jitter
2 high precision crystal oscillators
OPA Chips
OPA1612 with ultra-low noise
and low distortion 1KHz 0.000015%
OPA1642
The audio decoding of the DMP-A6 is entrusted to two ESS ES9038 Q2M DAC chips, a high-performance model widely recognized by audiophiles. It also supports high-resolution audio streams up to PCM 32bit 768kHz and DSD512, as well as decoding of MQA files.
The high-definition 6" LCD touch screen perfectly integrated into the aluminum chassis of the DMP-A6 Master Edition allows practical and ergonomic use. The user experience is intended to be as intuitive as possible. Thus, it is possible to access all player options and information through this beautiful interface.
The DMP-A6 Master Edition is equipped with an integrated memory 4GB DDR + 32GB eMMC to be able to use many applications.
A slot compatible with a 4TB M.2 NVME 2280 SSD is provided for installation without removing the cover and allowing you to store your music locally and access it extremely quickly. In addition, the use of an SSD rather than a hard disk makes it possible to reduce the temperature and the vibrations of the device.
The DMP-A6 Master Edition features a low-noise power supply module, several capacitors reduce interference. In addition, the filter circuit is specially designed for AC current input and reduces high frequency noise from 100KHz to 5MHz ensuring continuous power, smoother background noise and clearer musical details.
Particularly versatile, the DMP-A6 Master Edition covers a large majority of integration needs thanks to complete connectivity.
1 | Antenna #1 |
2 | Antenna #2 |
3 | Antenna #3 |
4 | Coaxial input |
5 | Coaxial output |
6 | Stereo balanced RCA output |
7 | Power switch |
8 | Power plug |
9 | Ethernet port RJ45 |
10 | HDMI Output (Adio/DSD) |
11 | USB-A Outputs |
12 | Optical Toslink input |
13 | USB-C Input |
14 | Optical Toslink Output |
15 | Stereo balanced XLR output |
Equipped with DOH processing chips for HDMI, the DMP-A6 MAster Edition can transcribe a DSD master sound signal with high HDMI clock precision.
The DMP-A6 Master Edition is equipped with a third-generation XMOS 316 USB interface ensuring perfect reception and decoding of the USB audio stream. This supports audio streams up to PCM 32bit 768kHz, DSD up to DSD512 and MQA. For optical ports (Coaxial and Toslink), they support DSD 64 (DoP) and PCM 192 24Bit.
The DMP-A6's circuitry also uses two high-precision ACCUSILICON FEMTOSECOND clock oscillators to effectively eliminate jitter and ensure accurate and transparent audio reproduction.
The DMP-A6 Master Edition incorporates an MQA (Master Quality Authenticated) decoder, allowing you to play this type of file and enjoy sound quality as close as possible to the original studio recording. In addition, MQA streams are light enough to be streamed.
The Bluetooth 5.0 reception of the DMP-A6 MAster Edition uses a Qualcomm QCC5125 chip. This supports the SBC, AAC, aptX, aptX LL, aptX HD and LDAC high-definition transmission codecs, allowing you to enjoy high-quality sound reproduction via Bluetooth.
The DMP-A6 MAster Edition is equipped with balanced analog circuitry from the DAC chip to the stereo XLR and RCA outputs. This limits noise and channel separation provides better signal quality.
It incorporates many music services such as; Tidal, Qobuz, HighRes Audio Amazon music. It is also compatible with third-party applications such as Apple music, Spotify, Deezer, Napster, KKbox and support Roon Ready feature.
The DMP-A6 Master Edition's DAC settings offer 7 filters applicable to your music listening preferences. In addition, custom VU meters are available for on-screen display itself built into a sturdy, modern-looking aluminum chassis.
The DMP-A6 Master Edition can be controlled from a smartphone or tablet using the free Eversolo Controller mobile app. This will allow you to simply access your music while enjoying a remote interface for easy use from your sofa.
SpEcifications | |
Product type | Streamer |
Touch screen | LCD 6" |
CPU | ARM Cortex-A55 (Quad-core) |
Internal memory | 4Go DDR + 32Go eMMC Support SSD M.2 NVME 3.0 until 4 Tb (not included) |
DAC Chip | 2x ES9038 Q2M |
Audio decoding | PCM : 32bit 768kHz DSD : DSD512 MQA |
USB Interface | XU316 (3rd generation) |
HDMI decoding chip | 2x DOH chips |
Bluetooth Chips | Qualcomm QCC5125 Bluetooth 5.0 |
AOP Chips | OPA1612 |
Connectivity | |
WiFi | Dual-band 2.4G+5G |
Ethernet | RJ45 (10/100/1000Mbps) |
Input USB port | USB-C 3.0 Systeme compatibility : Windows (7, 10), Mac, Android, IOS Audio compatibility :Stereo DSD512, PCM 768KHz 32Bit, MQA |
Output audio HDMI | Multi-channel : DSD64 Native Raw Multi-channel : PCM 192KHz |
Input Bluetooth 5.0 | QCC5125 Chip Supported Codecs : SBC, AAC, aptX, aptX LL, aptX HD, LDAC |
Digital audio inputs | Bluetooth 1x USB-C 1x Coaxial 1x Optical Toslink |
Digital audio outputs | Bluetooth 1x Coaxial 1x Optical Toslink 1x HDMI 2x USB-A |
Analog audio outputs | 1* unbalanced stereo RCA 1* balanced stereo XLR |
Integrated music services | Tidal, Qobuz, Highresaudio, Amazon, WebDAV, UPnP |
Compatible streaming services | Air Play, DLNA, Roon Ready, Spotify, Tidal Connect, Qobuz Connect etc. |
Supported network protocol | NFS / SMB v1-v2-V3 / UPnP |
Mesurements | |
Balanced XLR output | Output level: 5.2V Frequency Response: 20Hz~20KHz(±0.15dB) Dynamic range: > 128dB SNR: >128dB THD+N: <0.00009%(-120dB) @A-wt Crosstalk: >-125dB |
Unbalanced RCA output | Output level: 2.6V Frequency response: 20Hz~20KHz (±0.2dB) Dynamic range: > 124dB SNR: >124dB THD+N: <0.00011%(-119dB)@A-WT Crosstalk: >-124dB |
Power supply | 110-240V AC 50/60Hz |
Rated Power | 13W |
Dimensions (L*P*H) | 180*270*90mm |
Color | Black |
Package | 1* EVERSOLO DMP-A6 Master Edition 1* Power cable 1* USB cable 1* Screwdriver 1* User manual |
Input | SPDIF |
Input | Bluetooth |
Input | WiFi |
Input | USB |
Input | Optical |
Input | RJ45 |
Output | RCA |
Output | Coaxial SPDIF |
Output | Bluetooth |
Output | Optical Toslink |
Output | XLR |
Output | HDMI |
Output | USB |
DAC / ADC Chip | ES9038Q2M |
Max sampling rate | DSD512 |
Max sampling rate | MQA |
Max sampling rate | 768kHz |
Color | Black |
Streaming services & Network protocols | AirPlay |
Streaming services & Network protocols | Tidal Connect |
Streaming services & Network protocols | Qobuz |
Streaming services & Network protocols | Amazon Music |
Streaming services & Network protocols | DLNA |
Streaming services & Network protocols | Spotify Connect |
Streaming services & Network protocols | Spotify |
Streaming services & Network protocols | Roon / Roon Bridge / Roon Ready |
Streaming services & Network protocols | Tidal |
Streaming services & Network protocols | Web radios |
Refurbished Grade | Grade S |
