IAN CANADA LINEAR PI SOLO MKIII Linear Power Supply Module
The Ian Canada Linear Pi Solo MKIII is an ultra-low noise linear power supply module delivering high-quality, high-current power that is both versatile and scalable. It is one of the best linear power supplies for Raspberry Pi or any other digital audio application, offering a noise level of only 0.8µV. Multiple LinearPi modules can be combined to create a larger power supply system. This module can also be easily upgraded to a supercapacitor power supply by combining it with the IanCanada UcConditioner.
Reference : 21263
139,00 €tax incl.
115,83 € tax excl.
Shipping date: 01-12-2026.
Ian Canada Linear Pi Solo MKIII Ultra-Low Noise Linear Power Supply Module 5V / 3.3V / 12V 3A
Ian Canada Linear Pi Solo : Front view
Ian Canada Linear Pi Solo : Nouveauté de la version MKIII
  • 3A continuous output current
  • Ultra-low output impedance of 3.5 mΩ (1 kHz).
  • 4-layer printed circuit board with double copper thickness for higher current density and additional shielding layers.
  • Total filtering capacity of 15,080 μF.
  • Enhanced Kelvin Sense input to reduce output impedance for improved performance.
  • Polymer output capacitors with ultra-low ESR (Equivalent Series Resistance).
  • New Schottky rectifiers with soft recovery, high speed and high current.
  • USB-C output connector
Ian Canada Linear Pi Solo : board diagram
Product typeLinear power supply module
Output voltage12V DC
5V DC
3.3V DC
Output current3A
Noise0.8µV
AC input voltage3.3V/5V : 6-9V AC
12V : 12V AC
DC input voltage3.3V/5V : 9-12V DC
12V : 15V DC
Output impedance3.5 mΩ
Dimensions140 x 56mm
Mounting holes114 x 46.5mm
Package1x Ian Canada Linear Pi Solo MKIII
1x PCB cable
InputScrew terminals
OutputScrew terminals
OutputUSB
Output voltage (V)12.0
Output voltage (V)5.0
Output voltage (V)3.3
Output current (A)3.0
Input voltage (V)15.0
Input voltage (V)6.0
Power SupplyLinear
IAN CANADA LINEAR PI SOLO MKIII Ultra-Low Noise Linear Power Supply Module 5V / 3.3V / 12V 3A
The Ian Canada Linear Pi Solo MKIII is an ultra-low noise linear power supply module delivering high-quality, high-current power that is both...
