This power supply module takes a voltage input of between 5V and 25V AC and outputs a voltage of ±3V to ±20V DC, depending on the setting of the variable resistors. The module is equipped with high-performance LT1083 voltage regulators mounted on heat sinks.
Product type | Power supply module |
Input voltage | 5-25V AC |
Output voltage (adjustable) | ±3V to ±20V DC |
Regulators | 2x LT1083 |
Capacitors | 2x 3300µF 35V 2x 470µF 35V |
Dimensions | 107.7 x 56.9 x 54.7mm |
Input | Screw terminals |
Output | Screw terminals |
Output voltage (V) | 7.0 |
Output voltage (V) | 4.0 |
Output voltage (V) | 10.0 |
Output voltage (V) | 5.0 |
Output voltage (V) | 13.0 |
Output voltage (V) | 16.0 |
Output voltage (V) | 17.0 |
Output voltage (V) | 18.0 |
Output voltage (V) | 3.0 |
Output voltage (V) | 15.0 |
Output voltage (V) | 8.0 |
Output voltage (V) | 9.0 |
Output voltage (V) | 11.0 |
Output voltage (V) | 12.0 |
Output voltage (V) | 14.0 |
Output voltage (V) | 6.0 |
Output voltage (V) | 20.0 |
Output voltage (V) | 19.0 |
Output current (A) | NC |
Input voltage (V) | 19.0 |
Input voltage (V) | 12.0 |
Input voltage (V) | 5.0 |
Input voltage (V) | 21.0 |
Input voltage (V) | 14.0 |
Input voltage (V) | 7.0 |
Input voltage (V) | 23.0 |
Input voltage (V) | 16.0 |
Input voltage (V) | 9.0 |
Input voltage (V) | 25.0 |
Input voltage (V) | 18.0 |
Input voltage (V) | 11.0 |
Input voltage (V) | 20.0 |
Input voltage (V) | 13.0 |
Input voltage (V) | 6.0 |
Input voltage (V) | 22.0 |
Input voltage (V) | 15.0 |
Input voltage (V) | 8.0 |
Input voltage (V) | 24.0 |
Input voltage (V) | 17.0 |
Input voltage (V) | 10.0 |
Power Supply | NC |
Average votes 5.0 / 5 6 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Zdenek B.
Michel a.
Michalis B.
Patrick d.
