NEUTRIK NE8FDIS-1-TOP Sealed etherCON RJ45 Chassis Connector
The Neutrik NE8FDIS-1-TOP is a etherCON RJ45 connector feedthrough chassis connector designed to ensure a reliable network link in outdoor environments. It relies on a shielded and sealed TOP construction, allowing signal integrity to be preserved while securing the mechanical connection, while its feedthrough design enables internal connection via a 2x4 pin header through the panel.
Reference : 22199
5,35 €tax incl.
4,46 € tax excl.
Neutrik NE8FDIS-1-TOP Sealed etherCON RJ45 Chassis Connector
Thumbnail of the Neutrik NE8FDIS-1-TOP
Intended for exposed fixed or mobile installations, it combines etherCON locking, environmental protection and front panel integration, allowing simple and secure implementation. This approach enables it to provide a robust connection point within a network infrastructure, while maintaining performance compatible with Ethernet transmissions and Power over Ethernet.
KEY POINTS:
  • etherCON RJ45 feedthrough chassis connector
  • Sealed TOP construction with protective cap
  • IP65 and IP67 protection rating when mated
  • Internal connection via 2x4 pin 2.54mm header
  • Mechanical locking compatible with etherCON
  • Metal housing ensuring shielding and robustness
Diagram showing the structure of the Neutrik NE8FDIS-1-TOP
Technical specifications
Product typeetherCON feedthrough connector
InterfaceRJ45 female / 2x4 pin header
Network categoryCat5e
Connection typeFeedthrough (via internal connector)
Contact materialPhosphor bronze
Contact platingGold
Contact resistance< 100mΩ
Insulation resistance> 0.5GΩ
Dielectric strength1kV DC
Rated current per contact1.5A
Rated voltage≤ 57V
Bandwidth1-100MHz
PoEPoE++ IEEE 802.3bt
Insertion/withdrawal force≤ 60N
Lifetime≥ 1000 cycles
ShieldingMetal housing (die-cast zinc)
StandardsUL94V0
TIA/EIA 568B
IEC 11801
IP65 & IP67
Temperature range-30°C to +80°C
PackagingSold individually
Max cable diameter (mm)N/A
Mounting typeTo connect
ConnecticFemale
ConnectorRJ45
Contacts Material (Connector)Phosphor Bronze
The Neutrik NE8FDIS-1-TOP is a etherCON RJ45 connector feedthrough chassis connector designed to ensure a reliable network link in outdoor...
