NEUTRIK NE8FDPS-1-TOP Sealed etherCON RJ45 Chassis Connector
The Neutrik NE8FDPS-1-TOP is a etherCON RJ45 connector feedthrough chassis connector designed to ensure a direct network link through a panel, thanks to a straight female RJ45 to female RJ45 configuration. It relies on a shielded and sealed TOP construction, allowing signal integrity to be maintained while protecting the connection against ingress in outdoor environments.
Reference : 22191
6,51 €tax incl.
5,42 € tax excl.
Neutrik NE8FDPS-1-TOP Sealed etherCON RJ45 Chassis Connector
Thumbnail of the Neutrik NE8FDPS-1-TOP
It integrates a direct RJ45 connection without internal wiring, enabling fast implementation within equipment or a distribution panel, while maintaining compatibility with Ethernet transmissions and Power over Ethernet up to category 5e.
KEY POINTS:
  • etherCON RJ45 feedthrough chassis connector
  • Sealed TOP construction with protective cap
  • IP65 and IP67 protection rating when mated
  • Straight RJ45 female to female feedthrough connection
  • Mechanical locking compatible with etherCON
  • Metal housing ensuring shielding and robustness
Diagram showing the structure of the Neutrik NE8FDPS-1-TOP
Technical specifications
Product typeetherCON feedthrough connector
InterfaceRJ45 female / RJ45 female
Connection typeStraight feedthrough (feedthrough)
Network categoryCat5e
Contact materialPhosphor bronze
Contact platingGold
Contact resistance< 100mΩ
Insulation resistance> 0.5GΩ
Dielectric strength1kV DC
Rated current per contact1.5A
Rated voltage≤ 57V
Bandwidth1 - 100MHz
PoEPoE++ IEEE 802.3bt
Insertion/withdrawal force≤ 60N
Lifetime≥ 1000 cycles
ShieldingMetal housing (die-cast zinc)
StandardsUL94V0
TIA/EIA 568B
IEC 11801
IP65 & IP67
Temperature range-30°C to +80°C
PackagingSold individually
Max cable diameter (mm)N/A
Mounting typeTo connect
ConnecticFemale
ConnectorRJ45
Contacts Material (Connector)Phosphor Bronze
The Neutrik NE8FDPS-1-TOP is a etherCON RJ45 connector feedthrough chassis connector designed to ensure a direct network link through a...
