NEUTRIK NE8FDPU-1-TOP Sealed EtherCON RJ45 Chassis Connector
The Neutrik NE8FDPU-1-TOP is a through-mount etherCON RJ45 connector designed to provide a reliable network connection in outdoor environments. It features a TOP-type shielded and waterproof construction, which preserves signal integrity while securing the mechanical connection, and its through-panel design allows for direct cable-to-cable connection through the panel.
Reference : 22188
6,25 €tax incl.
5,21 € tax excl.
Neutrik NE8FDPU-1-TOP Sealed etherCON RJ45 Chassis Connector
Thumbnail of the Neutrik NE8FDPU-1-TOP
Designed for exposed fixed or mobile installations, it combines etherCON locking, environmental protection, and front-panel integration, enabling simple and secure deployment. This approach allows it to provide a robust connection point within a network infrastructure, while maintaining performance compatible with Ethernet transmission and Power over Ethernet.
KEY POINTS:
  • etherCON RJ45 feedthrough chassis connector
  • Sealed TOP construction with protective cap
  • IP65 and IP67 protection rating when mated
  • Internal outlet angled 90 degrees upward
  • Mechanical locking compatible with etherCON
  • Metal housing ensuring shielding and robustness
Diagram showing the structure of the Neutrik NE8FDPU-1-TOP
Technical specifications
Product typeetherCON feedthrough connector
InterfaceRJ45 female / RJ45 female
Network categoryCat5e
Connection typeFeedthrough
Contact materialPhosphor bronze
Contact platingGold
Contact resistance< 100mΩ
Insulation resistance> 0.5GΩ
Dielectric strength1kV DC
Rated current per contact1.5A
Rated voltage≤ 57V
Bandwidth1 - 100MHz
PoEPoE++ IEEE 802.3bt
Insertion/withdrawal force≤ 60N
Lifetime≥ 1000 cycles
ShieldingMetal housing (die-cast zinc)
StandardsUL94V0
TIA/EIA 568B
IEC 11801
IP65 & IP67
Temperature range-30°C to +80°C
PackagingSold individually
Max cable diameter (mm)N/A
Mounting typeTo connect
ConnecticFemale
ConnectorRJ45
Contacts Material (Connector)Phosphor Bronze
The Neutrik NE8FDPU-1-TOP is a through-mount etherCON RJ45 connector designed to provide a reliable network connection in outdoor environments. It...
