This module displays a multi-band Vumeter from an analog source. It is quick and easy to implement thanks to its micro USB port (power supply) already soldered on the PCB. The module is thus ready to use upon delivery without the need for soldering nor software configuration.
Advanced users will appreciate the additional XH input (connector & cable supplied) merging stereo signal and power supply for a clean installation with ordered wiring. Similarly, an additional connector meant to connect a 10k logarithmic potentiometer provides an accurate adjustment of the sensitivity of the input signal. This function provides excellent readability to use with the (many) available display settings.
The display of the audio spectrum is divided into 21 bands to cover the entire audio signal with precision. Several display profiles are already pre-configured.
All parameters except the input sensitivity can be adjusted from three simple buttons mounted directly on the PCB. These options include:
| Package Contents | |
| Module Vumeter display | x1 |
| Adapter 1x 3.5 female jack 3.5mm to 2x 3.5 female jack 3.5mm | x1 |
| Male USB-A to male Micro USB cable | x1 |
