SMSL VMV P2 Balanced Preamplifier Headphone Amplifier
The SMSL VMV P2 is a high-performance preamplifier - desktop headphone amplifier, capable of delivering high power and extremely accurate sound reproduction. It is based on a carefully designed balanced architecture, enabling it to deliver 2x6W at 32 Ohm or 2x350mW at 600 Ohm. The whole unit is housed in a magnificent aluminum chassis, as robust as it is stylish.
By buying this product you get 97 loyalty points
Reference : 18249
979,00 €tax incl.
815,83 € tax excl.
SMSL VMV P2
Balanced Preamplifier - Headphone Amplifier
SMSL VMV P2 Amplificateur Casque Symétrique
Selectable gain
The rear of the SMSL VMV P2 displays three selectors. The first selects the input, the second the output, and the third adjusts the gain level. The latter switch has three positions. Adjusting the gain makes the amplifier particularly versatile, enabling it to adapt to both high-impedance headphones and high-sensitivity earphones.
Balanced architecture & High-end components
The SMSL VMV P2 benefits from a totally balanced architecture with an ultra-low distortion 4-way PLFC circuit. No less than 99 low-noise OPAs are integrated in a parallel design. The specially designed volume potentiometer greatly reduces crosstalk. The whole system is powered by a high-efficiency, low-noise power supply, providing a clean electrical signal to all circuits.
1Touch button
2LED
3Button
4Jack 4.4mm balanced headphone output
5Jack 6.35mm single-ended headphone output
6XLR 4 pins balanced headphone output
7Single-ended RCA input
8Input selection
9RCA pre-out
10Balanced XLR input
11Gain switch
12Output selection
13XLR pre-out
Modern, luxurious design
The SMSL VMV P2 boasts a sublime CNC-machined aluminum casing, giving it a modern yet luxurious aesthetic. Its front panel features a sturdy tempered glass panel, a high-quality rotary knob and a touch-sensitive ON/OFF button.
Inputs1* Balanced stereo XLR
1* Single-ended stereo RCA
Outputs1* Balanced Jack 4.4mm headphone output
1* Balanced XLR 4 pins headphone output
1* Single-ended Jack 6.35mm headphone output
1* Balanced XLR pre-out
1* Single-ended RCA pre-out
Output power2x12W @ 16 Ohm
2x6W @ 32 Ohm
2x700mW @ 300 Ohm
2x350mW @ 600 Ohm
SNR133dB
Dynamic range133dB
THD+N-123dB, 0.00006% (1kHz, 32 Ohm)
Input impedance47kOhm
Amplifier output impedanceNear 0 Ohm
Preamp output impedanceBalanced: 44 Ohm
Single-ended: 22 Ohm
Frequency response20Hz - 100kHz (-0.5dB)
GainSingle-ended: low = -9dB / mid = 0dB / high = 18dB
Balanced: low = -3dB / mid = 6dB / high = 24dB
Consumption< 60W
Dimensions280*235.7*51mm
Weight3.25kg
Package1* SMSL VMV P2
1* Power cable
SMSL VMV P2 Amplificateur Casque Symétrique SMSL VMV P2 Amplificateur Casque Symétrique SMSL VMV P2 Amplificateur Casque Symétrique SMSL VMV P2 Amplificateur Casque Symétrique SMSL VMV P2 Amplificateur Casque Symétrique
InputXLR
OutputJack 6.35mm
OutputJack 4.4mm
ClassN/A
The SMSL VMV P2 is a high-performance preamplifier - desktop headphone amplifier, capable of delivering high power and extremely accurate sound...
