Multi-Strand Litz Wire PU Insulated 30x0.1mm 0.236mm²
Litz wire is a conductor whose strands are insulated from each other by a layer of varnish to eliminate the skin effect. This copper conductor also provides excellent electrical conductivity.
Reference : 5738
0,90 €tax incl.
0,75 € tax excl.
Shipping date: 27-10-2026.
Câble vendu au mètre
Litz Wire
Fil de Litz Multibrins Émaillé Isolé PU 30x0.1mm 0.236mm²
Product typeEnamelled multi-strand Litz wire
Section0.236mm²
Wire diameter30x0.1mm
Heat resistance350°C
Insulating varnishPolyurethane
QuantitySold by the meter
Diameter (mm)N/A
Length (m)Sold by length
Number of conductors1
Insulation materialPolyurethane (PUR)
ShieldingNo
Section (mm²)0.23
Ground / ShieldingNo
Ok
Facile a entamé, il suffit d'un bon fer capable de monter a 400 ° ou plus et etamer comme normal en enlevant le noir du vernis.
This review has been posted for Multi-Strand Litz Wire PU Insulated 30x0.1mm 0.236mm²
Litz wire is a conductor whose strands are insulated from each other by a layer of varnish to eliminate the skin effect. This copper conductor also...
