IAN CANADA ISOLATORPI II Galvanic Insulation Module for Raspberry Pi / Odroid
-10%
This IsolatorPi II module in HAT format proposed by Ian Canada allows to provide a Raspberry Pi or ODROID SBC with total galvanic isolation for I2S, I2C and power supply between the SBC and the digital interface / DAC. This ensures that the EMI noise transmission from the SBC is cancelled via ground and audio signal.
Reduced price!
Reference : 13824
Limited special offer
64,90 €tax incl.
-10%
58,41 €tax incl.
48,68 € tax excl.
This product has now been replaced by the Ian Canada IsolatorPi III.
Ian Canada IsolatorPi II Module Isolation Galvanique pour Raspberry Pi / Odroid
Cancelling this noise allows your audio modules to operate optimally for clear and accurate sound reproduction. This improvement is all the more obvious when you use quality power and clocks for your audio modules.
The IsolatorPi II supports I2S 768kHz and DSD512. Its intelligent and bi-directional architecture allows it to work with audio modules in slave or master mode. In addition, the board incorporates a second 40-pin GPIO connector (not isolated) to allow the integration of additional modules, such as an IR receiver or rotary encoder, while preserving the isolated circuit for the audio modules.
Ian Canada IsolatorPi II Module Isolation Galvanique pour Raspberry Pi / OdroidIan Canada IsolatorPi II Module Isolation Galvanique pour Raspberry Pi / OdroidIan Canada IsolatorPi II Module Isolation Galvanique pour Raspberry Pi / Odroid
Product typeDigital Galvanic Insulation Module 150MHz 2.5KV
CompatibilityRaspberry Pi / ODROID
Supported sampling ratesPCM : up to 768kHz
DSD up to  DSD512
ArchitectureBidirectionnal (working in slave and master modes)
Power supply (sold separately)Isolated circuit : 5-6V DC on screws terminal
Non isolated circuit : via Raspberry Pi / Odroid
Isolated ID EEPROM Memory-
Inputs1x Isolated female 40 pins GPIO
1x Non isolated male 40 pins GPIO
Outputs1x Isolated male 40 pins GPIO
1x 7 pins I2S connector for Odroid
1x Isolated SCK/BCK on U.FL connector
1x Isolated LRCK/DL on U.FL connector
1x Isolated DATA/DR on U.FL connector
1x Isolated MCLK for Odroid on U.FL connector
Dimensions66 x 66mm
Fixation holes spacing58 x 49mm
InputI2S
OutputGPIO
Max sampling rateDSD512
Max sampling rate768kHz
This IsolatorPi II module in HAT format proposed by Ian Canada allows to provide a Raspberry Pi or ODROID SBC with total galvanic isolation for...
