CONNEX SMPS600RS 600W Switching Power Supply Module
New
The CONNEX SMPS600RS is a 48V half-bridge resonant switching power supply, designed for amplifiers requiring a high-current single-rail supply. It delivers up to 12.5A, i.e. 600W continuous and 720W peak, with a main voltage adjustable from 46 to 50V and a regulated 15V / 500mA auxiliary output. Its zero-voltage switching helps limit losses and allows efficiency of up to 94%, while overcurrent protection safeguards operation under load.
Reference : 22706
129,00 €tax incl.
107,50 € tax excl.
Connex SMPS600RS 600W 48V 12.5A Switching Power Supply Module
CONNEX SMPS600RS: Front view
The Coonex SMPS600RS is a 48V half-bridge resonant switching power supply, designed for amplifiers requiring a high-current single-rail supply. It delivers up to 12.5A, i.e. 600W continuous and 720W peak, with a main voltage adjustable from 46 to 50V and a regulated 15V 500mA auxiliary output. Its zero-voltage switching helps limit losses and allows efficiency of up to 94%, while overcurrent protection safeguards operation under load.
Technical specifications
Product typeSwitching power supply module
InputTerminals
OutputsMain: Terminals
Auxiliary: PCB connector
Input voltage230V (196-254V)
Main output voltage48V (45.3-51.2V)
Auxiliary output voltage12V
Main output currentNominal: 12.5A
Peak: 15A
Auxiliary output current500mA
No-load power consumptionMin: 1.5W
Max: 2.7W
Efficiency at 50% load93.9%
Max output ripple10% load: 16mVpp
70% load: 68mVpp
Weight520g
Dimensions108 x 108 x 53mm
PackageSold individually
InputCosses
OutputCosses
OutputPCB Connector
Output voltage (V)48.0
Output current (A)12.5
Input voltage (V)230.0
Power SupplySMPS
CONNEX SMPS600RS 600W 48V 12.5A Switching Power Supply Module
The CONNEX SMPS600RS is a 48V half-bridge resonant switching power supply, designed for amplifiers requiring a high-current single-rail supply. It...
