900M-T-2.4D Soldering Iron Tip
The 900M-T-2.4D is a D-type soldering iron tip, equipped with a 2.4mm tip and designed for soldering operations requiring a relatively large contact surface.
Reference : 22571
2,90 €tax incl.
2,42 € tax excl.
900M-T-2.4D 2.4mm Soldering Iron Tip
900M-T-2.4D Panne de fer à souder
The 900M-T-2.4D is a D-type soldering iron tip, equipped with a 2.4mm tip and designed for soldering operations requiring a relatively large contact surface. Its multilayer construction combines an oxygen-free copper substrate, providing good thermal conductivity, with several protective layers including an iron alloy layer, a rust- and corrosion-resistant nickel layer, as well as a surface plating designed to limit solder migration. The assembly incorporates a heating element allowing rapid temperature rise and benefits from a plating treatment announced with a 72-hour processing time. The contact area of the tip is precisely machined to facilitate the positioning and application of solder during soldering operations.
Technical Specifications
Product TypeSoldering iron tip
Compatible Iron Type900M
ShapeD
Tip Width2.4mm
Inner Diameter4mm
Outer Diameter6.5mm
Tip Length17mm
Package1x 900M-T-2.4D Soldering Iron Tip
900M-T-2.4D Soldering Iron Tip Ø2.4mm
The 900M-T-2.4D is a D-type soldering iron tip, equipped with a 2.4mm tip and designed for soldering operations requiring a relatively large...
