DAYTON AUDIO 800-HPF-8 Speaker High Pass Filter 800Hz
The Dayton Audio 800-HPF-8 is a passive high-pass speaker filter with a 12 dB/octave slope centred at 800 Hz. Designed to restrict the bandwidth of a speaker with a smooth, gentle slope, it can be combined with a low-pass filter of the same frequency to form a second-order Linkwitz-Riley filter, ensuring a perfectly neutral response at the crossover point. The use of high-quality components guarantees a stable and predictable response, while the ability to adjust or shift the cut-off frequencies allows the filter to be adapted to the specific response of each loudspeaker.
Reference : 21207
19,90 €tax incl.
16,58 € tax excl.
Shipping date: 19-11-2026.
Grantie 5 ans
Dayton Audio 800-HPF-8 Speaker High Pass Filter 800Hz 12dB/Octave 8 Ohms
Dayton Audio 800-HPF-8 : Front view
The Dayton Audio 800-HPF-8 is a passive high-pass speaker filter with a 12dB/octave slope centred at 800Hz. Designed to restrict the bandwidth of a speaker with a smooth, gentle slope, it can be combined with a low-pass filter of the same frequency to form a second-order Linkwitz-Riley filter, ensuring a perfectly neutral response at the crossover point. The use of high-quality components guarantees a stable and predictable response, while the ability to adjust or shift the cut-off frequencies allows the filter to be adapted to the specific response of each loudspeaker.
Product typeSpeaker filter
Filter typeHigh-pass
Cut-off frequency800Hz
Impedance8Ω
Power handling250W
Series capacitor value12µF
Parallel inductor value3.2mH
Dimensions105mm x 77mm
PackageSold by unit
DAYTON AUDIO 800-HPF-8 Speaker High Pass Filter 800Hz 12dB/Oct 8 Ohm
The Dayton Audio 800-HPF-8 is a passive high-pass speaker filter with a 12 dB/octave slope centred at 800 Hz. Designed to restrict the bandwidth of...
