DAYTON AUDIO SSMB24 Speaker Stands (Pair)
New
The Dayton Audio SSMB24 are steel speaker stands designed to position bookshelf speakers at listening height and provide them with stable support. Their three-tube structure, two front tubes of Ø3.81cm and one rear tube of Ø7.62cm, combines rigidity with discreet routing of the speaker cable inside the rear tube.
Reference : 22535
172,90 €tax incl.
144,08 € tax excl.
Grantie 5 ans
Dayton Audio SSMB24 Speaker Stands Speaker Stands 34kg Steel Black (Pair)
DAYTON AUDIO SSMB24 Speaker Stands: Front view
The top plate, measuring 16.82cm × 20.95cm and 9.5mm thick, features neoprene pads that help hold the speaker in place. The bottom plate, measuring 20.95cm × 27.94cm with a tapered profile to 12.7cm at the rear, incorporates adjustable spikes to facilitate levelling of the stand and its decoupling from the floor. With a height of 62.86cm, each stand supports up to 34kg and features a durable textured black finish, suited to both stereo and home cinema installations.
Technical specifications
Product typeSpeaker stands
MaterialsSteel
Height62.86cm
Top plate dimensions16.82cm × 20.95cm
Cable management
Spikes
Weight supported per stand34kg
Weight12.7kg
PackageSold as a pair
DAYTON AUDIO SSMB24 Speaker Stands 34kg Steel Black (Pair)
The Dayton Audio SSMB24 are steel speaker stands designed to position bookshelf speakers at listening height and provide them with stable support....
