DAYTON AUDIO SSWB20 Speaker Stands 60kg Walnut Wood (Pair)
The DAYTON AUDIO SSWB20 is a pair of speaker stands measuring 50.8cm in height with a walnut wood finish, designed to raise your speakers to an optimal listening height.
Reference : 22491
109,90 €tax incl.
91,58 € tax excl.
DAYTON AUDIO SSWB20 60kg Speaker Stands Walnut Wood (Pair)
DAYTON AUDIO SSWB20
The DAYTON AUDIO SSWB20 is a pair of speaker stands measuring 50.8cm in height with a walnut wood finish, designed to raise your speakers to an optimal listening height. Their high-density MDF fiberboard construction provides a stable base while limiting resonances. The column can be filled with a suitable material to improve the stand's isolation and stability. Two upper platforms with different dimensions are supplied to accommodate both small and large speakers.
Isolating foam pads can be placed under the speakers to promote decoupling. The stands are supplied with rubber feet for hard floors and metal spikes for carpets. Cable ties and adhesive supports also help keep cables secured at the rear of the stand. Each stand has a 22.9 × 29.8cm base and supports up to 60kg.
The DAYTON AUDIO SSWB20 therefore provides a stable and versatile solution for positioning your speakers at the correct listening height.
DAYTON AUDIO SSWB20
Technical specifications
Product typeSpeaker stands
MaterialsMDF
Height50.8cm (20")
Base platform dimensions22.9 × 29.8cm
Upper platform dimensionsSmall: 18.4 × 23.5cm
Large: 22.9 × 29.8cm
Ballast compartment
Cable management
Decoupling spikes
Load capacity per stand60kg
Weight23.15kg
Package content2× DAYTON AUDIO SSWB202 speaker stands
2× Large upper platforms: 22.9 × 29.8cm
2× Small upper platforms: 18.4 × 23.5cm
16× Screws
8× EVA isolation pads
4× Cable fastening systems
8× Metal spikes
8× Support feet/nails (for hard floors)
The DAYTON AUDIO SSWB20 is a pair of speaker stands measuring 50.8cm in height with a walnut wood finish, designed to raise your speakers to an...
