DAYTON AUDIO SSWB6 Speaker Stands 60kg Walnut Wood (Pair)
The DAYTON AUDIO SSWB6 is a pair of speaker stands measuring 15.24cm in height with a walnut wood finish, designed to raise your speakers to an optimal listening height.
Reference : 22493
79,90 €tax incl.
66,58 € tax excl.
DAYTON AUDIO SSWB20 60kg Speaker Stands Walnut Wood (Pair)
DAYTON AUDIO SSWB6
The DAYTON AUDIO SSWB6 is a pair of speaker stands measuring 15.24cm in height with a walnut wood finish, designed to raise your speakers to an optimal listening height. Their high-density MDF fiberboard construction provides a stable base while limiting resonances. The column can be filled with a suitable material to improve the stand's isolation and stability.
Isolating foam pads can be placed under the speakers to promote decoupling. The stands are supplied with rubber feet for hard floors and metal spikes for carpets. Cable ties and adhesive supports also help keep cables secured at the rear of the stand. Each stand has a 22.9 × 29.8cm base and supports up to 60kg.
The DAYTON AUDIO SSWB20 therefore provides a stable and versatile solution for positioning your speakers at the correct listening height.
DAYTON AUDIO SSWB6
Technical specifications
Product typeSpeaker stands
MaterialsMDF
Height15.24cm (6")
Base platform dimensions22.9 × 29.8cm
Upper platform dimensions18.4 × 23.5cm
Ballast compartment
Cable management
Decoupling spikes
Load capacity per stand60kg
Weight10.6kg
Package content2× DAYTON AUDIO SSWB6 speaker stands
2× Upper platforms: 18.4 × 23.5cm
16× Screws
8× EVA isolation pads
4× Cable fastening systems
8× Metal spikes
8× Support feet/nails (for hard floors)
The DAYTON AUDIO SSWB6 is a pair of speaker stands measuring 15.24cm in height with a walnut wood finish, designed to raise your speakers to an...
