XCITE XBS100MK Mounting Kit for XBS100-4 Exciter
The XCITE XBS100MK is a mounting bracket designed specifically for the brand’s XBS100-4 exciter. It is designed to provide a mechanically stable mounting whilst optimising the transfer of vibrational energy to the host structure. It is built on a glass-fibre-reinforced ABS base incorporating copper inserts, which provide long-lasting protection for the threads, whilst the supplied self-locking screws ensure secure fastening under repeated stress. This structural rigidity is complemented by a uniform contact surface incorporating damping foam that distributes contact stresses whilst limiting the transmission of unwanted vibrations to the mount.
Reference : 21885
14,91 €tax incl.
12,42 € tax excl.
XCITE XBS50MK : Front view
In addition to stability, this approach offers extensive mechanical compatibility thanks to multi-format drilling (40, 60 and 80mm), allowing for direct integration onto standard profiles, whilst remaining adaptable to wooden or metal surfaces via M6 to M8 fixings. This versatility allows for flexible mounting orientation, facilitating integration into a variety of configurations.
Technical specifications
Product typeSpeaker support brackets
MaterialsABS
Glass fibre
CompatibilityXCITE XBS100‑4
Package1x XCITE XBS100MK
4x Vis M4x12
The XCITE XBS100MK is a mounting bracket designed specifically for the brand’s XBS100-4 exciter. It is designed to provide a mechanically...
