Streamer ES9038Q2M WiFi DLNA AirPlay 2 Bluetooth 24bit 192kHz
The Arylic Up2Stream HD DAC presents itself as a network player with integrated DAC, both versatile, practical and scalable, which will allow you to set up a complete and powerful streamer, including in multi-room. Thus, its digital to analog conversion stage uses an ESS ES9038Q2M chip, allowing it to provide accurate sound reproduction, while supporting audio streams up to PCM 24bit 192kHz. Furthermore, the Up2Stream HD DAC can be extended with a number of optional modules (sold separately), such as a display, control buttons or even an acrylic case.
The Up2Stream HD DAC is compatible with the recent Apple AirPlay 2 transmission protocol. This makes it possible to stream music easily and quickly from an iOS smartphone.
The Up2Stream HD DAC is also compatible with Spotify Connect and Tidal Connect protocols. These allow you to stream your music directly from these services, without having to use an application such as 4Stream.
Several Up2Stream HD DAC modules can be used together to create a true multiroom environment, allowing you to stream and control your music in any room of your home. They can also be combined with other Arylic modules to create a complete DIY multiroom system.
The Up2Stream HD DAC is compatible with many music streaming services: Qobuz HD, Tidal HiFi, Spotify, Deezer, Amazon Music, Napster, but also many web radios are thus at your disposal.
It's extremely easy to control the Up2Stream HD DAC remotely, thanks to the free 4Stream mobile app. Available for Android and iOS, it will allow you to manage your music playback, access your playlists or even set an alarm.
| Specifications | |
| Product type | Streamer |
| Connectivity | WiFi IEEE 802.11 b/g/n 2.4G / 5G Bluetooth 5.0 (support aptX HD) |
| Inputs | 1x Ethernet RJ45 10/100Mbps 1x Digital input on PCB connector 1x AUX input on PCB connector |
| Outputs | 1x Stereo RCA 1x Coaxial 1x Optical 1x I2S Output on PCB connector 1x AUX Output on PCB connector |
| Supported streaming protocols | AirPlay 2 DLNA UPnP Spotify Connect Tidal Connect Qplay |
| DAC Chip | ESS ES9038Q2M |
| Supported sampling rates | PCM up to 24bit 192kHz |
| Supported file formats | FLAC, MP3, AAC, AAC+, ALAC, WAV |
| Compatible streaming services | Tidal HiFi Qobuz HD Spotify Deezer Amazon Music TuneIn Napster iHeartRadio QQFM |
| General | |
| Supply voltage | 5VDC 2A |
| Dimensions | 110 x 74mm |
| Weight | 81g |
| Input | PCB Connector |
| Input | RJ45 |
| Output | Coaxial SPDIF |
| Output | PCB Connector |
| Output | RCA |
| Output | I2S |
| Output | Optical Toslink |
| DAC / ADC Chip | ES9038Q2M |
| Max sampling rate | 192kHz |
| Streaming services & Network protocols | Qobuz |
| Streaming services & Network protocols | Amazon Music |
| Streaming services & Network protocols | AirPlay |
| Streaming services & Network protocols | Tidal Connect |
| Streaming services & Network protocols | Deezer |
| Streaming services & Network protocols | Tidal |
| Streaming services & Network protocols | Web radios |
| Streaming services & Network protocols | Spotify Connect |
| Streaming services & Network protocols | Spotify |
