It works fine, it Connect a fine, I like the app, but it says that it support HD audio, and it is true but it out put only CD quality.
Receiver WiFi 2.4G Bluetooth 5.0 to I2S SPDIF Multiroom 24bit 192kHz
The Arylic Up2Stream Pro V3 is a module that acts as both a WiFi and Bluetooth receiver. Particularly practical, it will allow you to simply broadcast your music remotely from a smartphone, a computer, a NAS or many streaming services and to set up a real multiroom system. Supporting a wide variety of transmission protocols, such as DLNA, UPnP, AirPlay and Spotify Connect, it will adapt to most needs to offer great flexibility to your existing audio system. The module also features a full range of connectivity including I2S and SPDIF output, GPIO port, 3.5mm line in/out, USB-A and expansion ports.
In this version V3, the Up2Stream Pro is equipped with additional features and optimizations:
Comparatif Up2Stream Mini V3 & Up2Stream Pro V3
Up2Stream Pro V3
Up2Stream Mini V3
WiFi
IEEE 802.11 b/g/n 2.4G
Bluetooth
5.0
5.0
LAN
Yes
No
USB Storage
Yes
No
Line input
Jack 3.5mm, 4 pins connector
No
3D Surround Sound
Supported
No
Arylic provides the 4Stream control application, available for Android and iOS smartphones. It allows total and easy control of your receiver and music playback. It is also via this interface that you will be able to manage your multi-room integration.
The Up2Stram Pro V3 supports many music streaming services. You will be able to enjoy Spotify, Deezer, Tidal, Qobuz, Napster, Pandora, Amazon Music, iHeart Radio or Internet radios. You will also be able to play your music directly from your NAS connected to the local network or USB storage device.
Product type | WiFi Receiver / Bluetooth |
WiFi Network | IEEE 802.11 b/g/n 2.4G |
Ethernet | RJ45 10/100M |
Bluetooth version | 5.0 |
Bluetooth codecs | SBC AAC |
Bluetooth transmission distance | 10m |
Inputs | 1x USB-A (USB Host) 1x Micro USB 1x Jack 3.5mm / 4 pins connector 1x RJ45 Ethernet WiFi Bluetooth |
Outputs | 1x Jack 3.5mm / 4 pins connector I2S SPDIF |
Frequency response | 20Hz - 20kHz |
SNR | 91dB |
THD | 0.03% |
Supported formats | FLAC, MP3, AAC, AAC+, ALAC, APE, WAV |
Supported sampling rates | Jusqu'à 24bit 192kHz |
Streaming protocols | AirPlay, DLNA, UPnP, Spotify Connect, QPlay |
Power supply | 5V 1A via Micro USB or 2 pins connector |
Dimensions | 87.6 x 49.6 x 15mm |
Accessories | 1x Arylic Up2Stream Pro V3 1x PH2.0 4 pins cable 22cm 1x WiFi Antenna 22cm 1x PH2.0 7 pins cable 22cm 1x 2 pins power cable 22cm |
Input | Bluetooth |
Input | WiFi |
Input | Jack 3.5mm |
Input | RJ45 |
Output | I2S |
Output | Jack 3.5mm |
Output | SPDIF |
DAC / ADC Chip | NC |
Max sampling rate | 192kHz |
Streaming services & Network protocols | AirPlay |
Streaming services & Network protocols | Tidal Connect |
Streaming services & Network protocols | Qobuz |
Streaming services & Network protocols | Amazon Music |
Streaming services & Network protocols | DLNA |
Streaming services & Network protocols | Spotify Connect |
Streaming services & Network protocols | Spotify |
Streaming services & Network protocols | Tidal |
Streaming services & Network protocols | Web radios |
Average votes 4.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Galeb S.
