ANENG AC28 Socket / Phase and Electrical Safety Tester
This socket and circuit breaker tester allows you to test your installation safely. This product allows, among other things, to indicate a missing earth, a phase reversal, or a missing phase or neutral. It features a small LCD LED screen displaying the voltage.
Reference : 22229
6,90 €tax incl.
5,75 € tax excl.
Aneng AC28 Socket / Phase and Electrical Safety Tester 250V 50Hz/60Hz
Aneng AC28
Warning: if the wall socket is connected to a residual current circuit breaker, press the "LEAKAGE TEST" button to test the function. When you press the button, the residual current circuit breaker should trip; otherwise, check the installation.
Product typeSocket tester
TestMissing earth wire
Missing neutral wire
Missing phase wire
Neutral and phase reversed
Earth and phase reversed
Leakage current test 30mA
Rated voltage250V 50Hz / 60Hz
Temperature range0°C~40°C
Dimensions56 x 56 x 45mm
Weight49g
PackagingSold individually
ANENG AC28 Socket / Phase and Electrical Safety Tester 250V 50Hz/60Hz
This socket and circuit breaker tester allows you to test your installation safely. This product allows, among other things, to indicate a missing...
