These wood screws made of Steel 8.8 / Carbon alloy with black nickel surface treatment have a curved head with hexagon socket. They ensure good strength and durability.
This Hirschmann touch point is made of nickel-plated stainless steel. It has a Ø4mm cable insertion diameter with a polypropylene (PP) insulating sleeve. Its contact resistance is 50 mOhm for a rated voltage of 60V DC.
Very practical, the domino allow quick and easy connections thanks to a screw system. No soldering required to connect two elements. This model has copper alloy screws and 10 ports that accept conductors up to 6.5mm in diameter.
Very practical, the domino allow quick and easy connections thanks to a screw system. No soldering required to connect two elements. This model has copper alloy screws and 5 ports that accept conductors up to 6.5mm in diameter.
Very practical, the domino allow quick and easy connections thanks to a screw system. No soldering required to connect two elements. This model has copper alloy screws and 7 ports that accept conductors up to 6.5mm in diameter.
KF F2 aerosol is an excellent cleaner, deoxidizer and lubricant for all mobile electrical and electronic contacts. It offers a protective action over time, penetrates and removes oxide and sulfide deposits on contacts while lubricating the surfaces in contact and allowing optimal passage of electrical current.
KONTAKT Solvent is a label-removing spray which enables you to remove paper labels cleanly and without leaving a trace. In fact, it removes all traces of the glue or tar used to hold labels in place.
This mains noise tester allows to measure the interference and therefore the noise on a power network and to compare filtered and unfiltered systems. It operates over a frequency range of 300kHz to 700kHz. Below or above these values, an LED lights up to indicate that the value is out of range.
This magnetic holder is ideal for holding screws and metal objects, so that they are held securely and are not lost. The container has a diameter of 110mm for a depth of 20mm.
This multi-function nose Clamp can also be used to crimp terminals or strip cables. It accepts terminals from 0.75 to 6mm², and cables to be stripped from 1.5 to 6mm².
This twist metal drill bit is made from a high speed steel alloy (HSS) and 5% Cobalt. This design ensures excellent wear resistance and protection against heat. Taking advantage of a double helix structure, the drill bit can be used longer than a conventional drill by promoting chip evacuation.
This twist drill is made of high speed steel (HSS). This design ensures high hardness and therefore excellent wear resistance and protection against heat. Taking advantage of a double helix structure, the drill can be used longer than a conventional drill by promoting chip evacuation.
This PH2 Phillips screwdriver takes advantage of good manufacturing quality to ensure great durability. Its perfect shape and the sandblasting of the tip allows it to perfectly hang the impression of your screw so as not to damage it.
