Find in this category all our vinyl turntables and CD players, as well as all the accessories allowing the maintenance of the latter as well as your records.
With its SCD1.3, Shanling unveils a high-end SACD CD player featuring the AKM AK4499EX + AK4191EQ DAC chip combo, XMOS XU316 USB interface and TPA6120 headphone amplification. Multifunctional, the Shanling SCD1.3 offers many other possibilities in terms of Hi-Fi configuration.
The SMSL PL100 CD player is the perfect way to enjoy your CD collection. It's essentially based on a CS43131 DAC chip and a PLL (Phase-locked Loop) circuit for sound reproduction as close as possible to the original source.
The SMSL PL200 is a high-quality CD turntable/player featuring an AKM AK4499EX DAC coupled with an AK4191EQ digital filter. This CD player is both high-performance and versatile. It is equipped with quality components such as the P.A.S.S (Precision Acces Servo System) servo playback system developed by...
The SMSL PL200T is a high-performance, versatile CD transport. It's based primarily on a P.A.S.S. (Precision Access Servo System) playback system developed by SMSL, plus an XMOS USB interface on a USB-C connector. The playback system natively supports MQA CD and USB interface up to PCM 32bit 768kHz, DSD512 and MQA.
The SMSL VMV T2 is part of the brand's high-end product range. It's an MQA CD player that also acts as a digital interface, and features an optimized clock system. It is equipped with a P.A.S.S (Precison Access Servo System) playback system that natively supports MQA-CD. The SMSL VMV T2 also supports high-resolution PCM 32bit 768kHz and DSD512 streams, as...
This acrylic spirit level will allow you to put your turntable just horizontally. This is an important parameter for maintaining the accuracy of the stage arm settings. An indispensable accessory for vinyl lovers.
The Syitren R300 is a small CD player with a nice retro design. Equipped with a Toslink optical output and a Jack 3.5mm headphone output, it will allow you to enjoy your CD collection at home as well as on the road. It also features Bluetooth 5.3 transmission capability, allowing it to automatically pair with Bluetooth headphones or speakers.
The Thinkya JA-310 is a compact, attractive CD player that also acts as a USB file player. With its blend of vintage and modern aesthetics, it is both an excellent audio device and a beautiful decorative object, which will blend effortlessly into any living room.
The Thinkya R01 is a CD and audio file player with a retro look. It features a SILAN SC6137D processor and a precise laser head. In addition to allowing you to play your CD library via a 3.5mm jack line output and Toslink optical output, a 3.5mm jack headphone output is also available. This headphone output is driven by a G Class amplifier stage capable...
The Tonewinner TY-1CD CD player benefits from attractive aesthetics and quality components for superior CD playback performance. It features an ES9028 DAC chip as well as OPA1632 AOPs and an enhanced playback system, all incorporated in an anti-vibration chassis for optimum sound reproduction of your favorite CDs. It supports a wide range of formats...
The Tonewinner TY-30 is a beautifully integrated CD player, based on the use of quality components for efficient CD playback. The chassis is perfectly damped in order to limit considerably the vibrations that could affect the playback and its stability.
The Lunar 1 turntable from Triangle is a manual turntable designed to play 33 and 45 rpm vinyl records. It features excellent build quality and is assembled in Europe in partnership with Pro-ject Audio.
Triangle offers a beautiful manual vinyl turntable with belt drive. This one has been specifically developed by the famous Pro-Ject brand and allows the playback of 33 and 45 rpm records. Its straight aluminum arm and its low vibration motor ensure a smooth and flawless playback. The arm as well as the Ortofon 0M-10E cell are pre-set for a quick and easy...
This LP658B Viborg vinyl stabilizer significantly reduces vibration and stabilizes the rotation speed of the tray. A bubble level ensures that the latter is perfectly horizontal. A double 50Hz marking with strobe effect allows an efficient adjustment of the rotation speed of the plate in 33 and 45 rpm.
This LP628B Viborg vinyl stabilizer significantly reduces vibration and stabilizes the rotation speed of the tray. A bubble level ensures that the latter is perfectly horizontal. A double 60Hz marking with strobe effect allows an efficient adjustment of the rotation speed of the plate in 33 and 45 rpm.
This kit integrates all the accessories allowing a good maintenance of your vinyls, the diamond of your turntable as well as your CDs. It includes a cleaning liquid and gel for vinyl, a cleaning product for CDs, a brush with a cleaning product for diamonds, a goat hair brush, two microfiber cloths and a user's manual.
Winyl One-Touch is a platinum vinyl diamond cleaner containing the latest generation of solid Polyurethane (PU) polymer and specially designed to provide optimal diamond cleaning.
This Winyl kit contains 2 bottles specially designed to preserve the purity of the cleaning and rinsing solution. These products are a complete and effective solution to properly clean the needle of your turntable. They remove dust and impurities to extend the life of the needle on your turntable.
The W-Mat from Winyl is a rigid acrylic turntable cover with a beautiful glossy finish and an extremely smooth texture. It is designed with great precision using a CNC (numerical control) and can replace any platter cover thanks to its 3mm thickness.
