SOMMERCABLE SINUS Single-ended Modulation Cable 3x0,35mm² Ø6mm
The Sommercable Sinus can also be used in a home HiFi system or for Car Audio. This one enjoys an excellent reputation from connoisseurs for its unbeatable quality/price ratio. It is particularly appreciated by Car Audio enthusiasts since the cable incorporates an effective shielding composed of a Copper mesh and an Aluminium / Polythophene sheet that considerably reduces the impact of RF and NF interference on the signal.
4.3 / 5
Reference : 4061
3,70 €tax incl.
3,08 € tax excl.
Shipping date: 20-10-2026.
Câble au mètre
Sommercable Sinus
Single-ended modulation cable 3x0.35mm² Ø6mm
Sommercable Sinus Câble de Modulation Asymétrique 3x0.35mm² Ø6mm
The Sommercable Sinus can also be used in a home HiFi system or for Car Audio. This one enjoys an excellent reputation from connoisseurs for its unbeatable quality/price ratio. It is particularly appreciated by Car Audio enthusiasts since the cable incorporates an effective shielding composed of a Copper mesh and an Aluminium / Polythophene sheet that considerably reduces the impact of RF and NF interference on the signal. In addition, thanks to its insulation composed of foam and polyethylene, Sommercable Sinus has a low capacity. A control wire is also integrated in this cable, so that other devices such as a CD player can be controlled. The latter can also be used as a ground wire for a turntable.
Product typeSingle-ended modulation cable
Conductor materialOFC Copper
CompositionLI2Y(ST)CY2x0.35mm²+1x0.35mm²
Conductor section0.35mm² (22AWG)
Sheath materialPVC
Number of conductors2 + 1
Conductor diameterØ0.67mm
Shielding materialCopper mesh + Aluminium / PT foil
Shielding factor100%
Number of strands per conductor11
Copper strand diameterØ0.2mm
Insulation materialFoam + PE
External diameterØ3mm
Weight per meter86g
Min / Max temperature-20°C / +70°C
Width15mm
Thickness6.2mm
Conductor / Shielding capacitance per emter75pF
Conductor resistance per kilometer53Ω
ColorBlue
QuantitySold per meter
Diameter (mm)6.0
Length (m)Sold by length
Number of conductors3
Insulation materialOther
ShieldingYes
Section (mm²)0.35
Ground / ShieldingYes
3 reviews
Good quality/price ratio
Built Sommercable Sinus interconnect between DAC and amplifier using also 3201, 17820, 9148, 9147 and 5268. Excellent result even with 3m long cable because of the decent impedance characteristics of the Sinus cable. Sounds, looks and feels good. Sinus has very good build quality and materials with a reasonable price.
This review has been posted for SOMMERCABLE SINUS Single-ended Modulation Cable 3x0,35mm² Ø6mm
Un peu rigide
Utilisé pour recabler des platines vinyles, un peu rigide mais d'excellente qualité !
Un peu rigide pour faire un cable phono
J'ai acheté ce câble pour faire un cordon pour connecter ma platine au pré-ampli. Bien que ses caractéristiques physiques soient correctes pour cet usage il est malheureusement un peu rigide.
The Sommercable Sinus can also be used in a home HiFi system or for Car Audio. This one enjoys an excellent reputation from connoisseurs for its...
