VIABLUE NF-S5 T8 Phono Cable
The VIABLUE NF-S5 is a phono cable designed to transmit very low-level analogue signals between a turntable and a phono preamplifier. It features silver-plated OFC copper conductors combined with a capacitance of approximately 50 pF/m, to limit load effects on the cartridge and preserve the frequency response from the tonearm output.
Reference : 21873
44,91 €tax incl.
37,42 € tax excl.
Shipping date: 20-11-2026.
Cable sold by the meter
Viablue NF-S5 Phono Cable Silver Plated OFC Copper 5x0.5mm² Ø9mm
Photo of the Viablue NF-S5 T8 Black cable
The Viablue NF-S5 is a phono cable designed to transmit very low-level analogue signals between a turntable and a phono preamplifier. It features silver-plated OFC copper conductors combined with a capacitance of approximately 50pF/m, to limit load effects on the cartridge and preserve the frequency response from the tonearm output, whilst the DIN connection ensures native channel and ground separation. The internal structure is built around a central polypropylene core and polyethylene insulation with low electrostatic charge, which helps to stabilise the cable’s electrical parameters over time.
Designed for phono setups, it features multi-layer shielding combining braided and foil shielding, extended all the way to the connectors to prevent any breaks in continuity.
Viablue NF-S5 : Conductor Architecture and Electrical Behavior
The silver-plated OFC copper conductors reduce line resistance, preserving the subtle variations in the signal from the cartridge, whilst the capacitance of 50pF/m limits interaction with the preamplifier’s input impedance, preventing any distortion of the high-frequency response.
This approach is extended by an internal design that separates the channels and ground planes, reducing crosstalk, whilst the continuous shielding ensure controlled dissipation of interference. Together, these features maintain signal integrity right up to the phono stage, under conditions suited to the low-level signals from a cartridge.
Schéma
Diagram showing the different layers that make up the VIABLUE NF-S5 cable
1Soft cable sheath
2Banding, fleece
3Spiral shield, tinned OFC strands
4Foil shield, ALU PET silver
5Soft filler
6Inner conductor, silvered OFC strands
7Ground wire, silvered OFC strands
Product typePhono cable
Cable conductor materialSilver-plated OFC copper
Conductor capacitance50pF/m
Shield capacitance100pF/m
Conductors section5x0.5mm²
DiameterØ9mm
PackageSold by the meter
Diameter (mm)9.0
Number of conductors5
Insulation materialPolyurethane (PUR)
Insulation materialPolypropylene (PP)
ShieldingYes
Section (mm²)0.50
Ground / ShieldingYes
VIABLUE NF-S5 T8 Phono Cable Silver Plated OFC Copper 5x0.5mm² Ø9mm
The VIABLUE NF-S5 is a phono cable designed to transmit very low-level analogue signals between a turntable and a phono preamplifier. It features...
