The ATAUDIO AT-M015 is a USB cable designed to connect devices with USB-C and USB-B ports in a digital audio setup. It uses four 6N OFC copper conductors, each consisting of 40 copper wires, to ensure good conductivity. Its design incorporates a PVC sheath, a cotton cord filler with strain relief reinforcement, an insulating paper layer, as well as tinned copper braided shielding to protect the connection against external interference. The AT-M015 thus combines a multilayer design and dedicated shielding for stable USB transmission, while benefiting from a construction designed to provide good mechanical resistance.
Technical Specifications
| Specifications | |
| Product Type | USB interconnect cable |
| Connectors | 1x USB-C 1x USB-B |
| Cable Material | 6N OFC Copper |
| Conductor Structure | 4x 40 OFC Copper Strands |
| Insulation | PVC |
| Shielding | Tinned Braided Shielding |
| Interference Protection Rings | |
| Connector Housing | Aluminum |
| Connector Plating | Gold |
| Outer Sheath | Braided Nylon |
| Cable Diameter | Ø7mm |
| General | |
| Length | 3m |
| Package Contents | 1x ATAUDIO AT-M015 |
| Length (m) | 3.0 |
| Shielding | Yes |
| Section (mm²) | N/A |
| Connector | USB-C |
| Connector | USB-B |
| Conductors Plating (Cable) | None |
