![[GRADE S] IBASSO DX240 Digital Audio Player DAP DAC ES9038Po Balanced Bluetooth 5.0 WiFi 32bit 768kHz DSD512 MQA Black](https://www.audiophonics.fr/53668-thumb_default/-grade-s-ibasso-dx240-digital-audio-player-dap-dac-es9038po-balanced-bluetooth-50-wifi-32bit-768khz-dsd512-mqa-black.jpg)
 ![[GRADE A] AUNE S9C PRO DAC 2x ES9068AS Discreet Headphone Amplifier 5W Bluetooth 32bit 768kHz DSD512 MQA Back](https://www.audiophonics.fr/64487-thumb_default/aune-s9c-pro-dac-2x-es9068as-discreet-headphone-amplifier-5w-bluetooth-32bit-768khz-dsd512-mqa-back.jpg)
 This product has been replaced by the new version, the DD TC35I 2021 DAC Adapter Male Lightning to Female Jack 3.5mm.
DAC Adapter Male Lightning to Female Jack 3.5mm 32bit 384kHz
This TC35I adapter consists of a female 3.5mm jack connector and a Lightning male connector. It will allow you to connect a 3.5mm Jack to an Apple device with only a Lightning connector, as it is the case on the latest iPhone. The components are integrated in a compact and robust 316 stainless steel case. The TC35I automatically detects and activates when a headset is connected to it. The adapter can also be used with headphones/headsets with built-in controls and microphones.
| Specifications | |
| Product type | Jack 3.5mm / Lightning adapter |
| Connectors | Jack 3.5mm femelle Lightning |
| THD+N | < -92dB |
| DNR | > 110dB |
| SNR | > 120dB |
| Output power | 30mW @ 32Ω |
| Recommended headphone impedance | 16-200Ω |
| Frequency response | 20Hz - 20kHz |
| Supported sampling rates | PCM up to 32bit 384kHz |
| General | |
| Case material | Stainless Steel 316 |
| Color | Silver |
| Input | Lightning |
| Output | Jack 3.5mm |
| DAC / ADC Chip | NC |
| Max sampling rate | 384kHz |
| Color | Silver |
| Networking | No |
| Remote Control | No |
| Contacts Material (Connector) | Copper Alloy |
| Contacts Plating (Connector) | None |
