Schiit MANI Phono Preamp for MC and MM Cartridges
Reference : 9205
199,00 €tax incl.
165,83 € tax excl.
Schiit MANI Adjustable Phono MM / MC Preamplifier
The latest addition to Phono's excellent product range, this Phono preamplifier is characterized by rigorous manufacturing, amazing value for money and a plethora of adjustments.
This versatility not found in this price range makes it possible to adapt it to all types of cells (as demanding as they are).
By simply changing the original switching power supply, you can easily get a top-of-the-line device for a very attractive budget
Characteristics :
  • Input impedance: adjustable from 47 ohms (Typical for MC cartridges) or 47k ohms (Typical for MM cartridges)
  • Accuracy RIAA: +/- 0.2dB, 20-20kHz
  • Output impedance: 75 ohms
  • Topology: RIAA 100% passive preamplifier with gain stage ADA4897 and AD8066, resistors and film capacitors.
  • Power Consumption: 4W
  • Power supply: Switching transformer 16VAC (delivered)
  • Dimensions:
  • Weight:
Settings:
  • Gain 1 = L, Gain 2 = L (Decca Mode)
    Gain: 30dB
    THD: <0.005%, Class A, 1V RMS
    Signal Noise Ratio:> 90dB, Class A
    Crosstalk: -75dB, 20-20kHz
    sensitivity: 9mV for a 300mV output
    Overload margin:> 20dB
  • Gain 1 = L, Gain 2 = H (Mode MM)
    Gain: 42dB
    THD: <0.008%, Class A, 1V RMS
    Signal Noise Ratio:> 82dB, ClassAT
    Sensitivity: 2.3mV for a 300mV output
  • Gain 1 = H, Gain 2 = L (Low MM Output / High Mode Output MC)
    Gain: 48dB
    THD: <0.01%, Class A, at 1V RMS
    SNR:> 80dB, Class A
    Sensitivity: 1.3mV for an output of 300mV
  • Gain 1 = H, Gain 2 = H (MC mode)
    Gain: 59dB
    THD: <0.03%, Class A, 1V RMS
    SNR:> 70dB, Class A
    Sensitivity: 0.3mV for 300mV output
