The SMSL PH-1 is a phono preamplifier for MM turntables, providing a very accurate gain of 46dB to reach a signal level of 1Vrms at output, where most phono preamplifiers provide a gain of only 38-40dB for an output signal of just 300mW. This high gain brings better dynamics, and the overall structure of the device offers ultra-low distortion. Added to this is a headphone amplifier circuit with a 6.35mm jack output on the front panel. The PH-1's rear-panel connectors include the essentials, with an MM phono input on RCA connectors and an RCA line output. The whole unit is powered by an isolated power supply circuit, avoiding all kinds of interference and guaranteeing clean, clear reproduction.
1 | ON/OFF button |
2 | Status LED |
3 | 6.35mm jack headphone output |
4 | Headphone output volume control |
5 | Phono RCA input |
6 | RCA output |
7 | DC jack connector for 5V power supply |
Product type | Phono preamplifier |
Input | 1x RCA phono |
Outputs | 1x RCA line output 1x 6.35mm jack headphone output |
Headphone output power | 2x 90mW @ 32 ohm |
Frequency response | 20Hz-20kHz |
THD+N | 0.008% |
Chanel separation | -77dB (1kHz) |
Gain | 46dB |
SNR | 84dB |
Power consumption | 1W |
Power supply | 5V DC 500mA |
Dimensions | 94 x 30 x 96mm |
Weight | 0.205kg |
Package | 1x SMSL PH-1 phono preamplifier |
